Sponsored by: Real Truck
AC problems
Old Jun 25, 2012 | 09:57 PM
  #106
KINGDAR's Avatar
KINGDAR
clutch engages sporadicly
hi all, temps in colorado been over 100* every day for a week and my a/c is on the friz. Even after rechargein the system my compresser clutch only engages for a second or 2 and then disengages for 2-3 min. I tapped on it with a plastic handle which did engage the clutch for a moment and then quit. I checked the air gap and got .060 now my problem is getting that little bolt out. How do I hold the clutch firm while turning that bolt?
Old Jun 25, 2012 | 10:32 PM
  #107
SpringerPop's Avatar
SpringerPop
That specific thing is covered here:
SpringerPop's Compressor Clutch Air Gap
Pop
Old Jun 26, 2012 | 12:46 AM
  #108
KINGDAR's Avatar
KINGDAR
Thanks springerpop, my problem is that the clutch wont stay engaged for any amount of time. Any other ideas?
Old Jun 26, 2012 | 06:38 AM
  #109
0013's Avatar
0013
Hi Kingdar,
If you are referring to turning “the ignition switch to "On" (not "Start"), and the air conditioning also to "On". This pulls in the clutch so that the serpentine belt holds it all from turning.” I used a large set of pliers to hold the clutch plate snug while removing the bolt. It didn’t require much effort to get it loose.
Good luck…
Old Jun 26, 2012 | 04:09 PM
  #110
KINGDAR's Avatar
KINGDAR
Thanks double o 13 thats what im gonna do
Old Jun 26, 2012 | 04:29 PM
  #111
projectSHO89's Avatar
projectSHO89
Go to AutoZone or one of the other stores and "rent" one of these:
A/C Clutch Holding Tool | AutoZone.com
Old Jun 26, 2012 | 05:46 PM
  #112
KINGDAR's Avatar
KINGDAR
thanks again, didnt know such a tool exists
Old Jun 26, 2012 | 08:19 PM
  #113
gatr2000's Avatar
gatr2000
Hi if you are asking me i could use a 2004 expy 4.6 wiring diagram..i have tha haynes version which is ...not a good version.
thx
Old Jun 26, 2012 | 08:48 PM
  #114
SpringerPop
Do you have the automatic or manual A/C?
Any rear A/C?
Pop
Old Jun 27, 2012 | 08:28 AM
  #115
PwerStroke99's Avatar
PwerStroke99
I would check the pigtails on.the high pressure side or low pressure side. Sometimes the go bad. Shake the wiring right at the pigtail and see what the clutch.does. when i.did that. It would engage and I let go it would disengage. U can get the pigtails from Ford. Easy fix
Old Jun 27, 2012 | 01:48 PM
  #116
gatr2000's Avatar
gatr2000
a/c 2004 expy
Any rear A/C?
Pop
hi ..no air in the back and this is 2004 4x2 4.6l automatic. the blower is working fine
thx
Old Jun 28, 2012 | 09:41 AM
  #117
SpringerPop
Just so there is no confusion, I was NOT referring to an automatic transmission in my question, but to "automatic controls for the A/C system".
What does the "automatic" in your answer mean? Transmission?
The appropriate schematic will be different, depending on the type of A/C controls, not the trans.
Pop
Old Jun 30, 2012 | 07:07 PM
  #118
tidexp's Avatar
tidexp
I have a question for ya.
My ac blows warm while idling.
My compressor seems to engage and disengage as normal.
I removed the only shime i had behind the clutch plate.
It seems like it works a little better, but still blows hot after idling for a min or two.
I checked the freon level and it at 55psi and it roughly 100 degrees outside.
Checked electrical connections on compressor and nothing seems loose.
The air blows about 85 degrees which isnt even cold, then the compressor will all of a sudden disengage
and start blowing heat.
the temp will get to 97 or so then ac will kick back in and cool down to roughly 88 then start blowing heat again.
It steadly does this every min or 2.
It is a 2002 7.3 f250
Please help i dont have the funds to spend at the dealer.
Thanks Greg
Old Jul 1, 2012 | 12:48 PM
  #119
projectSHO89
You probably have two problems, one which is aggravating the other.
First, it sounds like your temperature blend door is not operating correctly. You can check this by operating the temp control in vent mode and seeing if the outlet air is changing from around ambient to really, really hot.
The other problem sounds like the clutch is cycling due to the high pressure cutout switch instead of the low pressure switch. This is vary serious and is usually indicative of a blocked condenser or some similar problem on the high pressure side. You really need to have both high and low pressure readings to properly identify and diagnose this type of problem.
Old Jul 19, 2012 | 08:04 AM
  #120
Branson M's Avatar
Branson M
The ac on my truck is great its ice cold......but it will only come out up next to the windshield ......the same goes for the heat...it works fine but will only come out up next to the windshield......any ideas on how to fix this ?
