Sponsored by: Real Truck
AC problems
Old May 24, 2017 | 10:21 AM
  #256
kbam's Avatar
kbam
Originally Posted by Pitcrw6
Well the only thing I can think of if it doesn't come on then either the blower is bad or their is no power going to the blower to turn it on. Shooting wires is the next step to determine if power is getting to the relay.
I'm about ready to shoot the truck!
OK, you mean test the wires, right?
Old May 24, 2017 | 10:23 AM
  #257
alloro's Avatar
alloro
Originally Posted by kbam
I need to buy one of those things with the probes that you touch the wire with? (I am so sorry, I honestly do not know.) What exactly do I ask for?
It's known by several references such as: multimeter, DVM, voltmeter.
If you have a Harbor Freight around you they have some fairly cheap and sometimes free with a purchase.
Like this one: https://www.harborfreight.com/7-func...ter-90899.html
Old May 24, 2017 | 10:31 AM
  #258
kbam's Avatar
kbam
Originally Posted by alloro
Assume nothing, what happens if you install a 30 amp fuse in the #116 space, does the blower work?
question, I'm looking at the diagram and it says "Central Junction Box" 116 is at the bottom right center. Is that the box that is on the passenger side right of where one would put their feet?
Old May 24, 2017 | 10:34 AM
  #259
alloro's Avatar
alloro
Yes it is.
Old May 24, 2017 | 10:40 AM
  #260
kbam's Avatar
kbam
Yes it is.
I just noticed that there is a slot for front blower relay, is that a fuse? I had a new Relay put in and I thought it was under the hood by the radiator. Is that the same
Old May 24, 2017 | 10:43 AM
  #261
kbam's Avatar
kbam
I had a fire right above that, but under the hood a while back, I wonder if that caused a problem.
Old May 24, 2017 | 10:48 AM
  #262
kbam's Avatar
kbam
Yes it is.
ok, I called home and had someone put the 30 amp in and it did not work. I also replaced the one in RO6
nothing works
I am in a rental car so I can take my daughter to the dr. I guess Ill check on the switch then I just don't know what else to do.
I am in the process of looking for a car. It's so frustrating. I have cried every night over this crap. It's just too much
thanks you so much
Karen
Old May 24, 2017 | 11:14 AM
  #263
kbam's Avatar
kbam
Originally Posted by ExPACamper
Who replaced the blower motor? Was it new?
It sounds like the switch to me. Many have a resistor type switch and might work in other positions (low, med, or high)
Does the fan blow in heat or not-A/C positions?
If not, check for a new switch assembly at a junkyard or wherever.
Beyond that, take it to a mechanic who can follow/trace the wiring and such. There is a limit to what you really want to do on your own.
When you say "switch assembly " are you talking about the entire thing that has the ***** and all on it?
When you said "resistor type switch" I replaced rge Resistor, is there a switch for it? I have been looking at the manual and can't find one. Thanks, Karen
  #264
ExPACamper's Avatar
ExPACamper
nothing works
thanks you so much
Karen
We're trying, Karen, we're trying....
What city and state are you in?
If you had a fire in an area, you very well may have damaged wires in there somewhere?
Don't spend a bunch on a switch. I'm a little "less sure" because of the possibility of melted or damaged wiring and insulation.
Old May 24, 2017 | 11:23 AM
  #265
kbam's Avatar
kbam
I am in Birmingham Alabama, where it feels like you are breathing through hot wet cotton! The humidity is worse than the heat. I told someone before, I have a daughter with cancer and a newborn grandbaby, I HAVE to have air conditioning. I run it even in the winter just to get rid of the humidity!
Old May 24, 2017 | 11:27 AM
  #266
kbam's Avatar
kbam
I think I have one of those!
Old May 24, 2017 | 11:28 AM
  #267
ExPACamper's Avatar
ExPACamper
I'll have to defer to someone more familiar with your particular model for exact details.
Often when at a junkyard, they pull that whole panel out, unplug it, and give it to you. You take it back, pop yours out and unplug it, plug the 'new' one in and pop it back into place.
The switches often have a resistor built into them for the different speeds. But some are mentioning relays, which would imply that is not the case. So I dunno on your truck?
But you will then have a new switch assembly and a new blower. So you'll KNOW the components work.
If it Doesn't work, perhaps someone here can give you a test for the pigtail that runs into the switch? That would get the power 'to' (and likely 'through') the switch.
The only part left would be from the switch 'to' the blower.
A buddy of mine recently had to replace his switch on a similar year F150 for his blow motor, hopefully your luck is good, too
When I went through chemo, hot weather was a real problem. There were times I left the house to sit in the car with the A/C cranked. Things just don't work right when your body isn't up to par
There are many here who have been through, or had their loved ones go through this stuff. You are not alone.
We'll pray for you and your family
Old May 24, 2017 | 11:57 AM
  #268
kbam's Avatar
kbam
Oh dear, I'm crying again... Thank you so much for your reply and taking the time to help me. I can see that you truly understand. She has been through so much, and it is so hard to watch your child go through it. I feel like as her Mom, I should be able to help her, I have all her life. This is much bigger than I am so that is something that I have to turn over to a much higher power!
I try to do things myself as much as I can so I can help her, even with insurance, the medical bills are ridiculous! I appreciate the prayers more that you know. I am dating someone that is also very sick with systemic Lupus, so there's only so much that he can do to help, but he relapsed into a flare by putting in the blower. It took hours in this smothering heat. I felt so guilty, but he wouldn't think of letting me even try it when he saw how hard it was to get to!
Old May 24, 2017 | 12:12 PM
  #269
kbam's Avatar
kbam
It's always so wonderful to meet survivors! It gives me hope.
Old May 24, 2017 | 12:35 PM
  #270
ExPACamper's Avatar
ExPACamper
According to the Drs, I am 7 years beyond my maximum "expiration date" with a mixed version of less than 10% survival rate.
The Good Lord laughs at the plans of men
I've flatlined 3 times and sometimes get knocked down a few months at a time, but then He has more work for me to do
Back to your truck....
Do you know any mechanics or electronics geeks in your area? Anyone who knows how to test with a Digital Meter? Local vo-tech?
You're very far from me, or I'd bring mine for an afternoon. Otherwise, the heat would be nice for a bit. We have the joint-poking damp and cool weather now instead of Summer.
