as a note my clutch does not seem to engage unless running
It's not supposed to.
also clutch did not cycle while testing.
That would be normal for your conditions.
Your pressures appear to be close to normal. Have you checked the following:
1. Evaporator inlet and outlet temps (use the digital method - your fingertip).
2. Proper operation of the temperature blend door including that it fully closes off the heater core route.
3. Is there ANY cooling evident in the outlet air?
4. Difference between front and rear?
1. Evaporator inlet and outlet temps (use the digital method - your fingertip). both warm if I am checking correctly
2. Proper operation of the temperature blend door including that it fully closes off the heater core route. What is the best way to check?
4. Difference between front and rear? I checked today while in the 90's and found in 70's front and 60's in rear vents (with windows closed and set to max ac)
Hooked up gauges and showing low side 47 and high at 230 in 95 degree phoenix heat
Also, does seem to cool better when driving at freeway speed vs in town .
I find that simply clamping off one of the heater hoses works good for eliminating the heater loop from the equation. A pair of vicegrips with the jaws padded by a couple of carpenter's shims does the job.
When checking the inlet temp of the evaporator, you need to be sure you're checking after the orifice tube which is usually at a joint in the tubing. Off hand, I don't know where it is on your truck so check as close to the firewall as possible.
Ran a test today and found with just the front ac on that the low pressure is about 20 and the high about 180 at idle with ambient temp of 101 degrees also now the compressor is cycling. The evaporator inlet and outlet are cold and warm fast when the compressor cycles off.
Then when turned on the rear ac the numbers go back to low 48 and high 230 and the evaporator lines are not as cold.
2000 F250 SD...A/C compressor not kicking on. Tap with hammer did the trick. Took off cltch plate..worn to rivets and then some. Removed the one spacer and good to go at present. RockAuto has new coil/pulley/plate for $47.00 + S/H so will replace. Presume replacing the pulley which has the face the clutch plate clamps to as the only way to go if plate is as worn as mine.
I'm down to just 1 shim. I wanted to be sure I didn't need at least one shim. If I take out the last shim and I've got the proper air gap then I'm good to go, right?
Thanks.
Yup. You're good to go. When you're out of shims, and the air gap is still too wide, then it's time for a whole-new clutch assembly. They're about a hundred dollars.
Usually, you can replace just the clutch hub if the oil and pulley bearings are still good. A Motorcraft YB-3020, the most common one, is $44 on Amazon. A hardware pack of new shims, bolt, and other clutch hardware parts is $2 at Autozone.
a/c rear vents colder than front ??? - sweating in Arizona
Any assistance on what to check when my front a/c vents are at least 10 degrees warmer than the rear. These 110's degree temps are killing us and summer has just begun.
Thanks for reply. What is the best way to check the blend door. I took offer the motor and it rotates 90 degrees, I also took off the cover behind the glove box and can see it rotating. Also, what is the recommended way to check to refrigerant charge level? My numbers very when rear a/c is turned on:
low 23 high 180 at idle with ambient temp of 101 (just front air on)
vs
low 48 high 230 at idle with ambient temp of 101 (with rear air turned on)
