Warming up a PSD
Old Oct 31, 2006 | 05:33 PM
  #106
mattsf250's Avatar
mattsf250
Originally Posted by kw5413
IMO, it is because of the generally poor quality of diesel fuels. At least until ULSD becomes prevalent. Soot build up is the single worst cancer that can infect a 6.0.
I have read on informed sites that the 6.0 was designed for optimum performance utilizing diesel fuel with a minimum 46 centane rating. The National average, as I recall, is less than 42 cetane. This is why many folks highly recommend the use of quality diesel fuel additives at every fuel up.
The 9 nine county N. Texas area has been somewhat fortunate that, a while back, the EPA mandated that local distributors offer fuels with a minimum cetane rating of 48. It is my belief this is the reason our trucks here seem to have fewer fuel / EGR Valve related issues...though some have.
I have a # of friends in the trades and they idle their trucks a good part of the day...with no 6.0 issues...each of them have followed my lead and depend heavily on fuel additives to keep them soot free.
this may indeed be correct..... now, add 5.99 per fillup on top of 2.79 A GALLON.... holy crap.
Old Nov 4, 2006 | 08:56 PM
  #107
Dads 66's Avatar
Dads 66
I let mine warm to about 120 f to alow the oil to circulate and all metals come up to temp evenly and at a controlled rate. Differant metals have a tendancy to thermally grow at different rates causing unusual wear, ie; bearings and valves, rings ect because of slight misalignment while cold. Also it is proven that moisture and heat create carbonic acid that leads to unsual wear and scoring of the cylinder walls. The wear may be ever so slight but reduces the economical life of the engine. I let the engine cool to 140 F to prevent wear.
I have a remote start that i use for warming the engine/cab and cooling the cab/engine.
Old Nov 6, 2006 | 02:24 PM
  #108
paulkeith's Avatar
paulkeith
quick question, ('02 7.3)the other night i was out camping and it dipped down to about 28 or 29, my rig had been sitting for about 5 or 6 hours...i started it up and let it idle while i loaded some chairs and tables in the bed, and the idle was jumping up to ~900rpm. tapping the gas would bring it back. kept doing it after driving for 5-10 min at a time and letting it idle again.
normal?
paul
Old Nov 6, 2006 | 03:13 PM
  #109
ryaneverk2's Avatar
ryaneverk2
Yes, that is normal. That is the Cold Ambient Package acting like it's designed to, raising the idle and closing the EBPV (you can hear it through the exhaust as a sort of hissing/shrieking sound) to put a bit of a load on the engine. Whenever the oil and intake air temps get low, that kicks in to keep things warm. You'll notice that tapping the brake will also disengage it.
Old Nov 6, 2006 | 10:35 PM
  #110
jfirstford's Avatar
jfirstford
Originally Posted by pimpedrsrage
i have a 7.3psd..and when i start it up when its below 45 degrees...there is a puff of blue smoke...the colder it is the more it smokes and the closer it is to 45 degrees the less it smokes...but it only puffs out one little puff of smoke. wondering if anybody else's does this..oh and by the way my truck is a 02
If you don't have an additive in your diesel fuel it may be gelling in colder temeratures. When gelled diesel fuel makes its way to the engine you'll get a thick white/slightly-blueish puff of smoke. Here in the Mid-South we don't usually get diesel with additives from the pump, so I add PowerService (in the white bottle) when I fill up, especially in the winter. Pick some up next time you're at Walmart. Hope that helps.
Old Nov 7, 2006 | 08:57 AM
  #111
TheFist's Avatar
TheFist
I've been letting mine idle for about 5 minutes and then taking the long way to the freeway from my house and cruising real slow through the neighborhood. Seems to be working pretty good.
Old Nov 7, 2006 | 10:58 AM
  #112
schjssj's Avatar
schjssj
I do the exact same thing and it works well for me too.
pwrstroketx
Feb 26, 2008 07:15 AM
kupiec20
Jan 23, 2008 07:37 PM
captbobNY
Jul 14, 2006 03:43 PM
EPDP99
Jan 5, 2006 08:03 PM
chris akey
Jun 23, 2002 08:55 PM
