Warming up a PSD
Old Oct 5, 2006 | 06:24 PM
  #91
killaford's Avatar
killaford
Originally Posted by Anchorman
It doesn't mean that you have the ultimate engine strategy.
its clear that he does.
my bad, the post is in the 6.0 forum.
Old Oct 5, 2006 | 06:47 PM
  #92
Anchorman's Avatar
Anchorman
LMAO killa
I needed that
Old Oct 5, 2006 | 07:30 PM
  #93
clux's Avatar
clux
That's a well thought out, logical counter point there, killaford. I bet you were on the dabate team, weren't you?
It's great to find someone who can admit when I'm right.
Old Oct 5, 2006 | 11:22 PM
  #94
kw5413's Avatar
kw5413
Since some here seem to be drowning in their own....
...Let's get back on topic ...here it is once again:
Originally Posted by cfd312
Just wondering how long I should be warming up my 06 PSD. Live in northcentral WI and this is my first one. Last couple of days the morning temp has been around 37 and just for the heck of it I started it 5 min. before work. Went outside to leave and it was running about 900 rpm. Put my foot on the brake and it went to idle. Just wondering if I should let it run a little longer. I suppose a remote start would greatly help. Talked to Best Buy and they said they have to use a timer. Will that be bad on the glow plugs if they are threw their cycle before the remote is?
Old Oct 6, 2006 | 01:58 AM
  #95
dieseldoc's Avatar
dieseldoc
Coming from a professional diesel tech. I would limit your idle time, it is tough on your fuel economy and carbons up parts. I would say in the summer, early fall and late spring. Let her run and warm up for five minutes, than start to drive real easy till the gauge gets up into the hash marks around the normal. In the winter, Let it run until you see the needle get to the first mark on the gauge, than same as stated earlier in my post. Plug the girl in when it gets below zero, much easier on the engine. If you get in start it and drive away, especially if it is real cold you run the risk of scoring a cylinder. As for cool down time. I you are towing or carrying a lot of weight, or been running for an extended time on the interstate let her idle for five minutes. This allows the oil to circulate through and cool down the turbo cartridge. The need for this is if you were to just shut it off the oil can boil out or cokes(a soft gooey carbon substance) up. In effect causing a dry start on you turbo bearings. This is what I have done for as long as I have been driving diesels. I have 264,000 miles on my 94 stroke and she is still running strong. That is also what I am doing with my 06' 6.0 and no egr problems yet.
Old Oct 6, 2006 | 02:52 AM
  #96
chili7's Avatar
chili7
I wait about a minute or two, and go, with above freezing temps. Always slowly and under 2K RPM for the first few miles. Isn't that better than idleing for 10 or 15 minutes? I'm not sure when you talk about limiting idle time how 15 minutes can be good, even when plugged in below freezing. Can't argue with F250Wheels. That's quite a commute and I'm in the same area.
Old Oct 6, 2006 | 04:49 AM
  #97
dapgar's Avatar
dapgar
if you do the high idle mod, then you can let it idle for longer periods of time though, with no build ups.
i know a lot of people with diesels. and most let them idle for a while. i know i let my 97 idle more in the winter, like for short stops somewhere, than just shutting it off.
that engine has 125k miles and still runs like a champ. always plugged in below 35 degrees.
i'll do the same with my new truck
Old Oct 26, 2006 | 03:10 PM
  #98
ABN-RGR's Avatar
ABN-RGR
Where I live has pretty much everything to do with how much of a warm-up my PSD gets. I idle it for a minute or less, drive two miles at 35 MPH (posted speed limit), then 4 miles at 55 MPH (posted speed limit) then hit the interstate at 70 to bat-out-of-hell (not the posted speed limit). Of course we don't have too many below freezing days in my neck of the woods. If I had frost on the windshield, I'm sure I'd idle it longer.
A question I've had for awhile is; why can a diesel generator run (at idle) for hours with no adverse effects? I know there's a big difference between a generator and a 6.0 and it's probably a dumb question but I've never really understood it.
Old Oct 27, 2006 | 03:29 PM
  #99
F250tuff's Avatar
F250tuff
A diesel generator doesn't have an EGR valve does it? I believe most of the problems related to idling is because it causes the EGR valve to get "coked".
Old Oct 30, 2006 | 08:05 AM
  #100
ABN-RGR's Avatar
ABN-RGR
Good point. Another reason to deep-6 the EGR valve I reckon. Mine's still connected as I haven't had an issue with it. I run Diesel Kleen every fillup though, maybe that's helping.
Old Oct 30, 2006 | 12:20 PM
  #101
poor15's Avatar
poor15
untill temp gauge moves a littile bit upward
Old Oct 31, 2006 | 05:14 AM
  #102
dapgar's Avatar
dapgar
it's funny how you never hear of anyone saying DON't idle too long with a diesel, until this 6.0 comes out and it's now a bad thing.
my 7.3 had idled for a long time, maybe an hour or more somestimes in the cold. i have never had any issues with it from doing this.
big rigs idle for hours and hours with no issues.
why is the 6.0 so picky about how long it idles. when i think of a diesel, i think it's meant to be idled when you need it, because i was always taught it's bad to start and stop a diesel for short trips in and out to places. so why not let them idle?
i've never let my new one idle much at all, maybe 10 minutes tops, not sure that's really a long idle. maybe for 4 hours that's considered long and maybe there would be issues with wet stacking but for 10-20 minutes, to me, that's normal.
Old Oct 31, 2006 | 02:36 PM
  #103
mattsf250's Avatar
mattsf250
LOL
maybe it's just mine, but after 10 mins of idling, my truck (with the STOCK tune) will NOT go up my 12% grade driveway at more than 1-2 mph..... with the tune, once you can get it over 15mph, it shoot some smoke, sputters, then spins the tires.
tired of this pos.... once they get some miles on em, it's always something. getting very bitter!
and apparently, glow plugs ARE NOT covered in the psd 100k warranty ???? (im on my 3rd bad one)....
that 5500 rebate on f150's is lookin good.
Old Oct 31, 2006 | 04:14 PM
  #104
kw5413's Avatar
kw5413
IMO, it is because of the generally poor quality of diesel fuels. At least until ULSD becomes prevalent. Soot build up is the single worst cancer that can infect a 6.0.
I have read on informed sites that the 6.0 was designed for optimum performance utilizing diesel fuel with a minimum 46 centane rating. The National average, as I recall, is less than 42 cetane. This is why many folks highly recommend the use of quality diesel fuel additives at every fuel up.
The 9 nine county N. Texas area has been somewhat fortunate that, a while back, the EPA mandated that local distributors offer fuels with a minimum cetane rating of 48. It is my belief this is the reason our trucks here seem to have fewer fuel / EGR Valve related issues...though some have.
I have a # of friends in the trades and they idle their trucks a good part of the day...with no 6.0 issues...each of them have followed my lead and depend heavily on fuel additives to keep them soot free.
Old Oct 31, 2006 | 05:13 PM
  #105
jack700's Avatar
jack700
More importantly for where you live Rotella 10w-30 from November till April. Ever see 15w-40 when the temps start to drop below freezing? It's like gel. Check the owners manual for your conditions.
