Warm oil? I got bad news for you, 20 minuites at driving speed hardly warms the oil.
I think that is really bad information. After 10 minutes of driving my 6.0L even in the coldest Michigan mornings (0 degrees or below), my water temp is almost at 190 degress.
So you are saying that after 20 minutes of running, the oil circulating through a 190 degree engine block, not to mention the heat generated in the oil from the HPOP, that the oil is barely warmed up? That is bonk, pure bonk. Simple thermodynamics proves you wrong.
As far as warming up before driving, I do in my diesels. I have a scangauge so I know my water temp. I drive off when the WT is 80 degrees. In my 2004 F250 the first white mark on the temp gauge is about 120 degrees. So depending on the outside temperature, warm up idling could be 30 seconds, or 3-5 minutes.
I have always let my engines (diesel or gas) idle a bit before driving them, Heck my 1992 F150 had 247,000 miles on the engine when I sold it. She still ran strong and only lost/used 0.5 quarts every 2500 miles.
How long you warm up your motor also depends on how far you will be driving. If you're doing a very short trip in colder weather, you should warm up the motor with a high idle mod at least until the temperature gauge warms up. If you drive short trips a lot and the motor never reaches operating temperature, bad things will happen.
Sound like you and other here are self appointed engineers, I go by the book.
Well, go pull out your Thermodynamics book and prove to me that you are not wrong.
It isn't even worth my time to do the calculations and prove your statement of "20 minuites at driving speed hardly warms the oil," is incorrect.
I am not a self appointed Engineer, I have a Bachelors of Science in Automotive Engineering (specialized Mechanical Engineering), and I have been working in the Automotive field, as an Engineer, for Tier 1 suppliers for last 10+ years.
What the "key&go" theory also fails to address is the other multiple moving components. Your AC compressor, power steering, alternator, etc etc etc. Even the Brake pedal can feel like cement when it's -40. Having Idling time helps warm up everything under the hood. (ever touched an exhaust manifold by mistake after it was "only idling"?) If you have you know what I'm talking about. And whoever made the comment that oil isn't even warm after 20 minutes of driving needs a reality check. Feel your oilpan after 5 minutes, it's hot.
Experience tells me that a gentle approach to starting is ALWAYS best... If you guys that start & drive have had lucky experiences.. I believe it is just that... "lucky"
I lived at 7500' elevation for 15 years, and I can tell you Alberta doesn't have a corner on the cold weather.
It is indisputable that your engine and components will get up to temperature faster if you are driving than if it is sitting idleing. Seems to me that if cold operation is damaging, logic would follow that the sooner you get it up to temperature the better. If cold operation is bad for your engine and components, what is less damaging, letting the engine idle cold for 15-20 minutes, or gently driving it cold for 5 minutes?
ford tell you what to do to cover their **** on warrenty, not what will make your vehicle last the longest it can.
I think I'll take my chances with what the owners manual says and start and go, unless somebody can cite some solid proof that extended idling in cold weather is better. I've heard a lot of opinions but no proof.
I usually let mine idle until the voltmeter comes up to normal range and the glow plugs are done. Mine usually idles around 700 when it's cold, how much
does the high idle mod raise it? Or how much would you raise the idle using the aic? If you are idling at 1000-1200 or driving at the same or slightly higher rpms, is there much difference in wear?
Read the owners manual diesel supplement about warming up the engine. They recommend a 15 second warm-up time and specify not increasing engine speed until oil pressure gauge indicates normal pressure.
Can you post the exact quote where they "recommend a 15 second warm-up time?" I think you'll see that they're not recommending this as a max warmup time, but a bare minimum.... in order to ensure you have sufficient oil pressure. They're instructing you not to drive away for at least 15 seconds, not at most.
The owners manual doesn't say to start and go.
Idling in cold weather is fine... that's what the Cold Ambient Package is for. When the engine oil and/or intake air gets on the cooler side, the CAP raises the idle speed and closes the EBPV partially to fully (more fully when it's colder), which puts a small load on the engine.
The weather doesn't get all that cold on the Central California Coast. However, on the North Slope of Alaska, where the weather does get a bit nippy, whole fleets of trucks are idled 24/7... they're too hard to start. When they are started, they're allowed to warmup for quite a long time... start yours up at well below zero and see how smoothly it's running.
You're entire point is flawed... Kinda like saying, "if it doesn't turn with a a pipewrench when it's cold, just apply more force"
Agreed it will warm faster... but it will do so when it is at it's MOST vulnerable stage.... COLD + COLD lubrication = MINIMUM protection. So the getting a bigger hammer theory wont work.
Well F250Wheels.. now that I've read back through the history of this thread and realize that you're the one that thinks that oil is still cold after 20 minutes... and the other comments....
Making stupid points to fight on the internet is kinda like competing in the Special Olympics.. even if you think you've won, you're still a frikkin retard.
