Keyless Keypad Code
Old Oct 12, 2014 | 09:54 PM
  #706
Stewart_H's Avatar
Stewart_H
Originally Posted by Tom
Or you could find a helpful guy with AutoEnginuity. If you were local I could pull your code in less than 5 minutes.
Tom, post the instructions so I can add it to the tech folder.
Stewart
Old Oct 12, 2014 | 09:55 PM
  #707
Tom's Avatar
Tom
Stewart
Sure, I'll hook up to the old Lincoln tomorrow and take some screenshots.
Old Oct 12, 2014 | 10:03 PM
  #708
Stewart_H's Avatar
Stewart_H
Thanks bud!
Stewart
Old Oct 21, 2014 | 09:16 PM
  #709
savagefan's Avatar
savagefan
Originally Posted by Mark 42
From Keyless entry and keypad code update? - Ford Powerstroke Diesel Forum
On a pre-2002 you have one 20 minute option..
The De Bruijn sequence!! It's 3125 numbers that WILL unlock your door..
Once it's unlocked backtrack 5-10 numbers and start from there until you figure out
what 5 digits did it.. Not fun, but you can do it quicker then going to the dealer.
Here's the link to the number and info you need to do this!
Weak security in our daily lives - Everything2.com
Thank you so much for posting Mark42. It worked just as you said on my 2000 Excursion. Of course my code had to be in the third quarter of the list and just as I was beginning to lose hope, clunk! Worth the small investment in time and I will toast your health with some single malt bought with the money you saved me. Cheers!
Old Jan 22, 2015 | 10:52 AM
  #710
Goat Rancher's Avatar
Goat Rancher
Does this information also apply to the 2010 models too? We bought a 2010 Expedition last Fall and the wife's been bugging me to find out how to get this fixed.
Thanks.
Old Jan 22, 2015 | 11:26 AM
  #711
Apocalypse's Avatar
Apocalypse
I'm going to venture and say no, but I could be wrong...
Old Jan 22, 2015 | 02:45 PM
  #712
robert_l_ross's Avatar
robert_l_ross
Thanks.
If you are referring to the code...if it's a 5 digit panel and the code is 5 digits, the string will work (there are only so many ways to enter a 5 digit code from a 5 digit keypad, and that string accounts for all of those possible combinations).
If for some reason the code is more than 5 digits then no. Also, once you get the code in and unlocking, the process to change the code may be different (consult the owners manual).
If you are referring to the stickers, not sure if they'd be in similar locations or not (my gut says not).
Old Jan 22, 2015 | 03:08 PM
  #713
LivingLarge's Avatar
LivingLarge
Thanks.
When I purchased my current Ex, I went to ford for an oil change and asked for the code. They gave it to me without charging the normal $99. You could try that
Old Jan 22, 2015 | 04:13 PM
  #714
jspence105's Avatar
jspence105
Thanks.
Going to throw this out there again, check your owners manual. Unless the original owner tossed it it will have a card in it with the code on it.
Old Aug 23, 2015 | 02:13 PM
  #715
Stevekron1's Avatar
Stevekron1
I swung down the "ash tray" compartment to the left of the trash bag hook and looked straight at the sticker/numbers on my black RAP in my 05 F250. Took me 30 seconds once I read all your feeds and knew what to look for and where it was located.
Old Oct 10, 2015 | 07:46 AM
  #716
Sloberdog's Avatar
Sloberdog
Trailering
Code for 2006 F250 - behind drivers side storage bin
Just purchased a new to me, used 2006 F250, read tons here, took off a lot of panels, and ended up with a sore back. Searched YouTube and finally found the code behind the drivers side storage bin. Had to look way back there, by moving the white foam/insulation out of the way. Got it! Programmed it! And it worked!
See this super helpful video:
Very easy....once you know where to look.
Old Oct 10, 2015 | 08:33 AM
  #717
Tom's Avatar
Tom
Great find Sloberdog, thanks for posting!
Old Oct 11, 2015 | 07:40 PM
  #718
man-o-war's Avatar
man-o-war
01 excursion
Luckily my door code was in the early/mid sequence, got it figured out following the list of progressive codes.
Thanks FTF
Old Oct 11, 2015 | 07:53 PM
  #719
Heavy G's Avatar
Heavy G
See this super helpful video: https://www.youtube.com/watch?v=tZ4V_vfm-6M
Here's a video for the Excursion.
Old Oct 15, 2015 | 12:38 PM
  #720
Pele's Avatar
Pele
Is there a way to enable a brute force lockout on the older models? I KNOW my code. I'd like to somehow make it so that someone can't come up and enter the 3000 number combination to open the door.
Also, is there a way to change the master code? I know you can add an additional "personal" code, but the master code still stays in there.
