Keyless Keypad Code
Old Apr 25, 2011 | 10:33 PM
  #586
EXv10's Avatar
EXv10
Originally Posted by cbr1000jeff
Hey Matt I know its been awhile for this thread, but I want to see if you still had this list of codes and if you could send it my way. ashby@bendcable.com
Thank You
Jeff
They are in here! Do a search.
Old Jun 12, 2011 | 04:47 AM
  #587
rockercomputers's Avatar
rockercomputers
MattsExcursion
Would you please this word document with all the numbers and keypad and codes TY..
rockercomputer@yahoo.com
Old Jun 12, 2011 | 10:09 PM
  #588
vettman80's Avatar
vettman80
codes
codes are on page 27 permalink #395
Old Jun 23, 2011 | 08:59 PM
  #589
sandcon's Avatar
sandcon
New to the board and am in need of your help. 2001 excursion 4x4 v10 xlt. Ford key less remote, and it works,but yet no code anywhere for the key pad. I was all over looking, almost pulled the dash as a whole. Tried the de bruijn codes, from this thread and kept setting off the theft light. Any one with a plan please chime in. And matt if you have time for a new best friend , I sure could use a hand. Thanks daniel. Daniellusk13@gmail.com
Old Jun 23, 2011 | 10:37 PM
  #590
robert_l_ross's Avatar
robert_l_ross
I have a 2000 and the code was not printed on any sticker. Search the forum and use the "hack" where you enter the string of numbers to find it. I think they may have not started putting the code on a sticker till 2002.
The hack took me about 10 minutes and was 100% free.
Also, 2000's don't have the ability to "erase" the personal code like newer models (guessing the 2001 is the same), so when you find the code, overwrite it - don't try the erase as it doesn't have that ability (nor the auto-lock...maybe the programming was updated in 2002?).
Old Jun 23, 2011 | 11:01 PM
  #591
robert_l_ross
Just made a new thread with the instructions and the "hack" string that runs through all variations of the 5 buttons to find the factory and personal codes. Free and takes 10-15 minutes to do.
Old Jun 23, 2011 | 11:06 PM
  #592
sandcon's Avatar
sandcon
I'm in for sure. Thanks robert
Old Aug 17, 2011 | 01:41 AM
  #593
alamac's Avatar
alamac
i looked just behind the radio and moved some wires and there was the code on a black box with the white sticker and the code just like the thread said it would be and i have a f250 05 it saved me 85 bucks from my local ford dealer. ohya!
Old Aug 24, 2011 | 04:24 PM
  #594
dukkie's Avatar
dukkie
Originally Posted by xTraveler
OK, for some reason they don't come up on a FTE article search but while searching google I found these instructions which actually come from an FTE article. They are by far the most detailed set of directions I've seen.
Security Keyless Keypad Programming on 2002+ Super Duty and Excursions
(Note: These instructions should work with other Ford's as well. If you have specific locations and supplemental information for other Ford trucks and suv's please let us know).
When your vehicle was newly purchased from the dealer it came with a card in the owner’s manual packet that had the keypad code on it. The packet is often lost over time and as the vehicle trades owners the code to the Keyless Entry is lost. Ford Dealers wants some big money to get the code for you by plugging in their computer to retrieve the code or using the following method. There is a much easier way for you to get the code and you don’t need any tools or automotive knowledge. I’ll show you how and where to find the code and how to reset the Keyless Entry back to the factory code or your personal code number.
There are three ways to find to it. One is a lot easier than the other but less work if you have a good eye and great flashlight. There are some Excursions, F250 and F350s that have a different wiring system so the first location to look is just above the right front kick panel; the RAP module is black in color with the numbers on the front the same as the white module. If you look above the kick panel you can see it really clear without taking anything apart. If it is not at this location please follow the next step.
This part is not hard to do you will need to remove the front cover under the steering wheel that says fuse box. (It has 4 plastic screws to remove) under the dash, the five (5) digit code is on the Cream/white box behind the radio, look to the top right of the open fuse box cover through the wires. (Towards the fire wall look through where my finger is pointing). At the back firewall, look for a 5 digit code on a sticker on a cream/white box. This is not easy but if you try every angle I promise it will appear don’t forget to use a very powerful flashlight if you want to see it.
The second way is a more time consuming job because you have to remover the stereo and to the rear you’ll be able to see the 5 digit code very easy. This process can take 2-10 minutes.
This is a picture of the Remote Anti-theft Personality (RAP) module. This is the module you are looking for there is nothing that identifies it as the RAP module (Some RAP modules are Black in color & it could also be up side down). It is the only box in the dash with the large bold type set with five numbers on it these is the five (5) digit code you will need from the module. Write this number down this is the factory code for your Keyless Entry.
Now that you’ve got the code I’ll tell you how to use the Keyless entry and set-up your own code.
Make sure when pressing the controls on the keyless entry keypad you press the middle of the buttons to ensure good contact with the controls.
Programming Your Own Personal Entry Code
1. Enter the factory-set code (keypad will illuminate when first digit is pressed).
2. Press the 1/2 control within five seconds of step 1.
3. Enter your personal 5-digit code. Enter each digit within five seconds of the previous one.
Your personal code does not replace the factory-set code. You can use either code to unlock your vehicle. Each time you set a new personal code the module will erase the previous one in favor of the new code. The factory-set code can not be erased.
Erasing Your Personal Code or A Prior Owner's Code
1. Enter the factory-set code.
2. Press the 1/2 control within five seconds of step one 1.
3. Press the 7/8 and 9/0 controls at the same time within five seconds of step two.
The system will now only respond to the factory-set code.
Unlocking the Doors
1. Enter either the factory-set code or the personal code (Each digit must be pressed within five seconds of the prior digit). The interior lights will illuminate as soon as the first valid digit is pressed.
2. To unlock all the doors, enter the factory set code or a personal code and press the 3/4 control within five seconds of the drivers door unlocking.
Locking the Doors
1. Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered to lock the doors.
Deactivating/Activating Auto-lock
1. Enter the five 5-digit code.
2. Press and hold 7/8 control.
3. Press and release 3/4 control while holding 7/8 control.
4. Release 7/8 control.
The horn will chirp once if auto-lock was deactivated or twice if auto-lock was activated.
I dont know if this is normal but my 05 Superduty has a felt/cotton baffling along the firewall and you have to move this out of the way to see the code (after removing the whole dash and radio)
Size:  49.8 KBName:  CIMG0128c.jpg
Old Sep 6, 2011 | 12:41 AM
  #595
trotdvm's Avatar
trotdvm
Keyless code
I am new to this forum. Bought my first Ex recently 2011-09-02). I'm sure glad I found this forum!! This thread was helpful but the location of the numbers was quite difficult to totally visualize. Regardless of how I approached the area I could not get the job done. A good light, lots of patience and a mirror is what it took to view just the first 3 numbers.
I am an equine veterinarian and have an endoscope to view the throat and trachea of horses that has now found another use. It took about 30 seconds to view all 5 numbers----thanks!... you Ex guys are as super as my Ex (not the one that got my last diesel).
Old Nov 23, 2011 | 07:31 PM
  #596
shaylink's Avatar
shaylink
door lock code on 04 excursion limited 6.0
Thanks for all the posts with the info I was able to find my code. the control box was on the fire wall behind a piece of white insulation. there was also a plastic tube that went across it making it near impossible to see. So I peeled the sticker off with lots of body contortion, found the code and was able to reprogram a personal code. it was not way up behind the radio like in other models. hope this helps some of the newer owners.
Old Dec 1, 2011 | 04:43 AM
  #597
Showboat911's Avatar
Showboat911
ISSUE Some vehicles may experience a concern with the
keyless entry keypad. In order to properly diagnose
the concern with the keyless entry keypad, it is
important to identify whether the keypad is a factory
installed style (wired) or a Genuine Ford Accessory
(GFA) radio frequency (RF) style keypad.
ACTION Use the following Service Procedure to identify GFA
RF keypads and provide diagnostic service tips.
SERVICE PROCEDURE
IDENTIFICATION:
1. Production installed keyless entry keypads are
mounted flush with the surface of the vehicle
and are wired directly to the module controlling
the vehicle’s keyless entry system. This style
keypad can be diagnosed using the appropriate
Workshop Manual (WSM), Section 501-14.
2. Dealer installed GFA RF keypads are adhesive
backed and protrude approximately 1/2² (13
mm) from the surface of the vehicle and there
are no specific diagnostics available in the
WSM (Figure 1). Article 06-15-8
NOTE
THIS RF KEYPAD WAS ALSO USED IN
PRODUCTION ON 2004 F-SUPER DUTY
VEHICLES BUILT PRIOR TO 12/3/2003. REFER
TO WSM, SECTION 501-14 FOR RF KEYPAD
DIAGNOSTICS FOR THESE VEHICLES.
GENUINE FORD ACCESSORY KEYPAD
DIAGNOSTIC TIPS
1. The keypad operates similarly to a remote
keyless entry (RKE) transmitter and is
programmed using a similar procedure.
• Although the RF keypad is not specifically
addressed in the WSM, the RKE transmitter
programming portion of the WSM, Section
501-14 can be used as a guide
NOTE
THE 7-8 AND 9-0 BUTTONS ON THE KEYPAD
MUST BE PRESSED SIMULTANEOUSLY DURING
THE PROCEDURE IN ORDER FOR THE KEYPAD
TO BE RECOGNIZED AS AN ADDITIONAL
REMOTE TRANSMITTER.•
Since the GFA RF keypad is essentially
another RKE transmitter, the transmitter
diagnostic pinpoint tests in the vehicle’s WSM
can also be referenced even though the
buttons serving the lock / unlock functions will
differ
2. The GFA RF keypad is serviced as an
assembly. The internal battery cannot be
replaced separately.
3.If the master code or owner selectable code is
lost or forgotten, the GFA RF keypad must be
replaced. These codes are not stored in any
vehicle module (with the exception of 2004
F-Super Duty vehicles produced prior to
12/3/2003).
4. The GFA RF keypad and all RKE transmitters
(the number of transmitters allowable will vary
by vehicle) must be reprogrammed together
anytime the keypad is replaced, an RKE
transmitter is replaced, or the module
controlling the keyless entry system on the
vehicle (GEM/SJB/VSM/DDM etc.) is replaced.
PAGE 2
NOTE
THERE IS AN EXCEPTION TO TIP 4 FOR
VEHICLES EQUIPPED WITH INTEGRATED
KEYHEAD TRANSMITTERS (IKTs)
(FUSION/MILAN/ZEPHYR). THE GFA RF
KEYPADS FOR VEHICLES WITH IKTs MUST BE
PROGRAMMED INDEPENDENTLY FROM THE
IKTs. TURN THE IGNITION FROM “OFF” TO
“RUN” 8 TIMES WITHIN 10 SECONDS, WITH THE
8TH TIME ENDING IN “RUN”. THE DOOR LOCKS
WILL CYCLE TO CONFIRM ENTERING
PROGRAMMING MODE. PRESS THE 7-8 AND 9-0
BUTTON ON THE KEYPAD SIMULTANEOUSLY
TO SEND A LOCK SIGNAL. TURN IGNITION TO
OFF. THE LOCKS WILL CYCLE AGAIN TO
INDICATE THE END OF THE PROGRAMMING
MODE.
5. The keypad will normally illuminate for 5
seconds after one or more buttons are pressed,
and the illumination will immediately turn off if
the 7-8 and 9-0 buttons are pressed
simultaneously (lock all doors). The keypad
contains an optical sensor and will not
illuminate under bright lighting conditions. The
keypad may only illuminate briefly in colder
temperatures in order to maximize the battery
power available to transmit a lock/unlock signal.
The temperature at which this occurs will vary
depending upon the keypad battery age and
condition. Both of these conditions are a normal
function of the Power Save Mode and do not
indicate a need to replace the keypad.
6. After entering the keypad code, the system may
unlock the driver’s door, lock it, then unlock it
again, and the keypad will not even briefly
illuminate. This is the Alert Mode and is an
indication that battery power is very low and the
keypad must be replaced.
7. The keypad also contains an Anti-scan feature.
If the wrong code has been entered 7 times (35
consecutive button presses), the keypad is
disabled for one minute and the keypad lamp
will flash during this time.
WARRANTY STATUS: Eligible Under Provisions Of
New Vehicle Limited
Warranty Coverage
DEALER CODING
Old Dec 3, 2011 | 09:20 PM
  #598
Jack Scandia's Avatar
Jack Scandia
Found it 2005 SD CC
I too have a 05 f250 and found the keyless entry code exactly where
they said I would. I got to it by removing the fuse panel under the steering wheel and then got upclose and personal with my gas and brake
pedal. With a bright flashlight I moved some insulation and some wires
and BAM there it was on a white sticker that was attached to a black
box/module. Very helpful thread,Thanks a ton guys.
Old Dec 4, 2011 | 04:09 PM
  #599
HALO1's Avatar
HALO1
Where can you find that sticker at on a 2008 F250 it's a early 08.I have looked behind the radio not there,under the steering wheel not there.
Thanks
Old Dec 13, 2011 | 07:48 PM
  #600
ken1509368's Avatar
ken1509368
2004 F250
Mine was on the box behind the radio. I got comfortable on the floorboard, stuck the gas pedal in my ear, and peeled the sticker off(carefully). Got the code and now its in the glove box. I wish I had it last week when the wife locked the keys in it while it was running.
