Keyless Keypad Code
Old Oct 15, 2015 | 05:54 PM
  #721
Stewart_H's Avatar
Stewart_H
The master code can't be changed, and the only way I know of to keep anyone from doing the string/number combination is to disconnect the pad wiring so it doesn't work.
Stewart
Old Oct 15, 2015 | 07:50 PM
  #722
Tom's Avatar
Tom
Originally Posted by Pele
Is there a way to enable a brute force lockout on the older models? I KNOW my code. I'd like to somehow make it so that someone can't come up and enter the 3000 number combination to open the door.
Some folks unplug the keypad from inside the door.
Also, is there a way to change the master code? I know you can add an additional "personal" code, but the master code still stays in there.
I don't think that's possible without reprogramming or replacing the BCM.
Old Feb 9, 2016 | 09:44 PM
  #723
Garman3's Avatar
Garman3
Ok let me throw a wrench into the mix! I have an 00 F350, that did not come with this option. I bought the truch several months ago and it didn't even have a radio! I bought the interior and doors from a wrecked 05. I replaced my old doors with the new ones.
Is there a way to get the master code for my doors without the truck they came from being available?
Old Feb 10, 2016 | 06:35 AM
  #724
NewXer's Avatar
NewXer
The best I can think of is try the sequence to see if there is one in the system.
https://www.ford-trucks.com/forums/5...ml#post6937477
Old Feb 10, 2016 | 07:50 AM
  #725
Tom's Avatar
Tom
Yours may not work at all. I believe the keyless entry is controlled by the body control module which is hidden somewhere under the dash. Without swapping the BCM of the donor truck I don't think you're going to have any luck.
I'm no expert on these things though, so I may be wrong. But the code is typically found buried in the dash on that module. Paging @Toreador_Diesel, he may be able to help you out with his AE scan tool. He's in the Houston area.
Old Feb 10, 2016 | 08:45 AM
  #726
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
The good Doctor is here
Based on the situation, I'm not sure we'll be able to get it, but we can definitely try!
Old Feb 10, 2016 | 02:42 PM
  #727
vettdvr's Avatar
vettdvr
I used the spread sheet with options codes and after 20 min of punching doors opened and I have my code for my 2000
Old Feb 10, 2016 | 10:18 PM
  #728
Ace_boy2786's Avatar
Ace_boy2786
Correct me if I'm wrong but isn't the door keypad JUST an input device, all the code storage and such should be in the BCM right, so it shouldn't matter what doors you have as long as they're wired correctly??
Old Feb 11, 2016 | 07:59 AM
  #729
vettdvr's Avatar
vettdvr
That's the way I would think it works. I had my BCM fail and had to replace it. Programing the BCM for the PATS system was required to have all the parts recognize each other. Nothing was done to the key pad.
Old Feb 13, 2016 | 12:23 AM
  #730
Commander421's Avatar
Commander421
Great info once again. Thanks to you all for taking the time.
Old Feb 14, 2016 | 07:44 PM
  #731
Toreador_Diesel
I used the AE to pull the code on a 2001 Excursion, not my Rudolph, but another project truck
Old Feb 14, 2016 | 07:58 PM
  #732
Tom's Avatar
Tom
I've used AE to pull it from a few different vehicles, and would be happy to pull the code for anyone in the area.
Old Feb 19, 2016 | 09:45 AM
  #733
01FordEx's Avatar
01FordEx
After locking myself out of my Ex recently I figured it was time to figure out the keyless keypad code. I used the info from this thread and found the code in about 15 minutes using the matrix others have used. The bummer was that I knew my door lock actuator was weak, and once I had the code the assembly would move, but not enough to actually unlock. Replaced the actuator and good to go.
Thanks to all for the info on how to get this figured out, hopefully I won't have to pay a locksmith next time...
Old Apr 11, 2016 | 10:21 AM
  #734
Mavrickman84's Avatar
Mavrickman84
Hey
Mods Edit: This is the Excursion forum, however, you can find what you're looking for in the tech folder sticky thread listed in the READ FIRST thread list on the Excursion forum page, as I've posted just two posts above.
Thanks
Old Apr 11, 2016 | 09:25 PM
  #735
ExPACamper's Avatar
ExPACamper
When I pull the code from AE, it says "1"
Of course that number doesn't work.
I have a Hydra with Gearhead tunes that disable PATS and the THEFT light flashes for a while.
Think that prevents AE from pulling the correct code?
