Keyless Keypad Code
Old Jun 27, 2019 | 04:04 AM
  #751
heath966's Avatar
heath966
2nd Gear
Keyless Keypad Code
Originally Posted by MattsExcursion
I have a 2000 X, and when I bought it, the owner had no idea of the code. So I looked at article after article... tore apart the WHOLE dash, and looked in all the places... NO CODE... I guess they didn't put printed codes on the '99 SuperDuty and 2000 X.. I wasn't about to pay $100 for some guy to tell me the code, so I looked into it more. I read a forum (not sure where) where someone used Microsoft Word to create a Macro to make all the possible codes... (sounds like something you wouldn't want to do, but you will be surprised) There are 5 buttons on the keypad. So you go into word create this macro that uses all the possible 5 digits numbers it could make with 0 1 2 3 4. It makes about a total of 10 sheets of codes at like 5 or so columns on each page.... TONS OF CODES. You then label the 1/2 key: 0 the 3/4 key: 1 and so on.... so now your keypad looks like 0 1 2 3 4... then you enter codes.... I did this for 10 min. and found my code. Some may be quicker, some may take longer... If anyone would like me to send them this word document with all the numbers, I would be glad too, also if anyone would like me to explain the procedure better I will. I'm so greatful that I found out about this way. I wish I would have remembered who it was so I could give the credit to that person, but it was probably 6 or 8 months ago. Good Luck!
Hi MattsExcursion,
Would you please send me the WORD doc for this?
Thanking you in advance for your time!
Old Jun 27, 2019 | 06:32 AM
  #752
Ffernandez13's Avatar
Ffernandez13
My keypad isnt working, im ordering a new one but im curious. How often are you guys actually using the keypad?
Old Jun 27, 2019 | 07:32 AM
  #753
bearintex's Avatar
bearintex
Virtually every time I get in the truck.
Old Jun 27, 2019 | 07:56 AM
  #754
seijirou's Avatar
seijirou
Originally Posted by heath966
Hi MattsExcursion,
The list is in the 1st post of this thread.
Old May 6, 2021 | 02:28 PM
  #755
FordLady01's Avatar
FordLady01
How many numbers do you put in?
I noticed that all the numbers listed were all close together and doesn’t specify what sequences to use. Any advice?
Old May 6, 2021 | 02:42 PM
  #756
EXSwap's Avatar
EXSwap
I've not done the code sequence. I'd pull the dash apart and find the number before I did all that. It's on one of the modules under where the radio and lower dash is. Some say you can just remove the cup holder and see it. Luckily for me, I had the code when I bought the X.
Old May 6, 2021 | 03:41 PM
  #757
seijirou's Avatar
seijirou
You start from the beginning and just start entering. When the number you hit has the effect, you've hit the final number of whatever your code is. Imagine drawing a box around 5 numbers in the sequence where your number that had an effect is the last number. So if you take the sequence 1 2 2 3 3 4 4 5 5 6 6 7 7 8 8. If your door unlocks on the 2nd 4. Draw the box 1 2 [2 3 3 4 4] 5 5 6 6 7 7 8 8 so your code is 23344.
Old May 6, 2021 | 03:50 PM
  #758
FordLady01's Avatar
FordLady01
Codes
unfortunately that doesn’t work for the 01’s and older
Old May 6, 2021 | 03:52 PM
  #759
FordLady01's Avatar
FordLady01
Codes
ok thank you so much I am about to try that
Old May 6, 2021 | 04:22 PM
  #760
ukmat71's Avatar
ukmat71
I paid my son to do this, within 5 mins he got the code and i lost $20
Old Feb 23, 2024 | 11:42 AM
  #761
MoBill122's Avatar
MoBill122
Papa Smurf
KeyPad Code
[QUOTE=xTraveler;3854349]Ok, reading this forum inspired me to look on ebay for new parts. I found the listing below and realized that I don't even know the keypad code on my X. I was willing to pay the dealership the $100. to figure it out but everytime I'm there "the only guy that can look it up" is out.
So is this guy on ebay full of it or does someone here know the trick he's talking about?
Winner will receive detailed instruction on how to find their master code, Instruction on how to use their keypad entry, How to lock and unlock using the keypad, How to set your own personal 5 digit code, and How to erase previous codes
You need no previous mechanical knowledge, ANYONE can do this!
Been trying to find my code for months off & on.... punched in 4 lines of numbers before my code unlocked the door ! But this works !!
Old Feb 24, 2024 | 06:02 AM
  #762
John in OkieLand's Avatar
John in OkieLand
on the Excursions,
the keypad code is printed on the VSM, which is behind the Radio and slightly to the left.
Old Feb 27, 2024 | 08:28 AM
  #763
yknotgo's Avatar
yknotgo
I recently got a 2000 Excursion and was able to pull the keypad code using FORScan. However I was unable to do so on my 07 F150. Apparently the codes were stored differently (GSM vs VSM or something like that, which I know nothing about or what any of it means, just what I think I recall in my skimming of threads).
Old May 26, 2024 | 02:50 PM
  #764
Pickupmanx2's Avatar
Pickupmanx2
So... VIOLA!! Spent about 10mins pokin in #'s and now have a code for the doors!! Maybe 1st third of the list, may try again after the sun goes down and see if there are any more, but super Thanks to the OP and to whomever broke it down to 5 # so it's easier to do!!
Old May 26, 2024 | 05:53 PM
  #765
01__Excursion's Avatar
01__Excursion
The Excursions only hold 2 codes. Once you have the master you can enter a second one.
