Keyless Keypad Code
Old Mar 8, 2010 | 06:58 AM
  #496
BigRy's Avatar
BigRy
Its a few pages back, man.
Old Mar 13, 2010 | 02:04 PM
  #497
00Excursion00's Avatar
00Excursion00
Hey VETTDVR, you think I could get in on that "Super Secret Superduty Keypad Code" list? SURE would be helpin' a diesel driver out.
Old Mar 13, 2010 | 06:54 PM
  #498
BigRy's Avatar
BigRy
Geesh, how about you look a few pages back its been posted already.
Old Mar 13, 2010 | 10:26 PM
  #499
EXv10's Avatar
EXv10
I would look around a little bit.
Old Mar 13, 2010 | 10:40 PM
  #500
vettman80's Avatar
vettman80
IT Works
i picked a 2000 EX last week door locks didnt work also no code for the key pad repaired the electric locks using the penny trick then sat my son down on a 5 gallon bucket in front of the key pad i read the numbers he pushed the buttons about a fourth of the way down the list we hit the lotto and the doors unlocked THANK YOU FTE
Old Mar 13, 2010 | 11:29 PM
  #501
OutlawNomad's Avatar
OutlawNomad
Penny trick?
Old Mar 14, 2010 | 11:47 AM
  #502
vettman80's Avatar
vettman80
Penny Trick
I know there is a post on here some where that tells how to repair the door locks using a true copper penny but in short you remove the electric locks and instead of replacing them at 30.00 a piece you drill out the plactic rivets and open the case and remove the motor on one end of the motor you lift two small tabs and pull off the plastic end this end has two brushes in side and also a small resistor which looks like a piece of metal maybe 1/4x3/8x3/32 in size remove this and place it on a penny and hold it in place with a vicegrip then grind the penny down to the same size then deburr the thickness of the penny is perfect so all you are grinding is the 1/4x3/8 put it back in the place of the metal piece put dielectric grease on and around it put the motor back togeather, put motor back in the case the riverts you drilled out before can be replaced using small screws put back in the doors and the locks work perfect i did all five in a 1/2 day and saved 150.00 just make sure you use a true copper penny you will know this after you begin to grind on it
Old Mar 14, 2010 | 09:32 PM
  #503
EXv10's Avatar
EXv10
I did all mine with tin foil a year ago. The penny is too much needless work.
Old Mar 15, 2010 | 07:41 AM
  #504
vettman80's Avatar
vettman80
Tin Foil
your right it is more work using a penny but from experience tin foil will not last as long also one truck we did 5 years ago using tin foil had a burndt smell in the back door we thought it was the window motor traced the problem to the tin foil getting to hot in the electric door lock and it was melting the plasic end of the motor and your right it does take a few minutes longer using a penny but dont know if you can call it needless work though
Old Mar 15, 2010 | 07:58 AM
  #505
vettdvr's Avatar
vettdvr
Note: I never said use a penny because it is illegal to deface public money.
However I did say it cost 1 cent of copper to make the repair. There is no mention of a penny.
Now I have made a further upgrade that cost less than 1 cent but you need to know how to solder. I now use 3/16" piece of solid copper wire wrapped around the end of the thermister and solder it in place. Then I touch it to the belt sander to smooth is off and insure fit back into the motor.
I wouldn't be caught doing anything Illegal to a penny for fear the feds might send Elliot Ness after me.
But technically a copper penny cut to the same shape of the thermister will work and doesn't need to be soldered or sanded, just cut to the proper shape.
Glad it is working for ya'll.
Old Mar 15, 2010 | 10:18 AM
  #506
jdw1's Avatar
jdw1
Touchpad question!
I was looking in my owners manual this morning (for my 02 f-350) and found my security code number, ye hah!
I don't have a touch pad though?
Iam confused!
Old Mar 15, 2010 | 11:27 AM
  #507
OutlawNomad
When entering in this code, my keypad (after the 5th incorrect pin) starts to blink on and off.
Is anyone experiencing this?
Old Mar 15, 2010 | 04:20 PM
  #508
vettdvr's Avatar
vettdvr
Do the locks activate? or unlock?
Old Mar 15, 2010 | 04:22 PM
  #509
OutlawNomad
I'm trying to figure out the door code & I'm entering in the long 300+ number code after the 4th or 5th wrong code the keypad starts to blink on and off.
Old Mar 15, 2010 | 06:17 PM
  #510
vettdvr's Avatar
vettdvr
after each attempt you much depress 4 & 5 to lock the doors. This resets the computer before you enter the next attempt. It took me about 35 attempt before I found my code.
