Edge Vs.
Old Feb 22, 2007 | 01:22 PM
  #106
fordtrkpuller's Avatar
fordtrkpuller
FTE *******
No pricing can be discussed on the forum as per the terms and conditions of FTE vendor rules. (and most other professional forums!)
You are welcome to PM any vendors, or go to the vendor site to see the wares that they offer.
The DashHawk is MSD # 13100
It is a OBD2 compliant device and also has manufacture specific capabilities. Not all parameters available in the DashHawk software is available for any specific vehicle, each vehicle has its unique sensors and set up. MSD does provide a list of vehicles that have been succesfully tested with the DashHawk.
You can read and learn more about it here:
http://discountpowerparts.com/catalo...oducts_id=1840
Old Feb 22, 2007 | 01:34 PM
  #107
fordtrkpuller
FTE *******
BTW... There is no pierced wires with an Evolution install...or a Troyer SCT....or a Superchips tuner...or any other OBD2 downloader/Tuner. It plugs into the diagnostic port in front of your right knee (If you are sitting in the drivers seat of the truck). So by removing the tuner after removing the actual tune.....you leave behind a small code (I forget....but I think its a P1000 code) that shows that the PCM was accessed by an outside device. This same code is tripped when using a standard code reader like the ones from the local auto parts store or similar.
Old Feb 22, 2007 | 01:57 PM
  #108
gui88ford's Avatar
gui88ford
ok, so it does leave it's mark on the computer....well, i better ask then cause it's a lease and i don't want to screw that up...
Old Feb 22, 2007 | 03:20 PM
  #109
qadsan's Avatar
qadsan
It does not leave a mark like you may be thinking. The P1000 code simply means that the PCM's monitor testing is not yet complete and requires further driving before this code is cleared from memory. The only way you can clear this code is to complete specific driving operations so the vehicle can learn certain operating characteristics. This code does not have anything to do with the PCM being accessed by another decvice such as the Edge or Xcal2, etc. You'll also get the P1000 code if you leave your battery disconnected long enough to erase the monitor data.
Old Feb 22, 2007 | 04:53 PM
  #110
gui88ford's Avatar
gui88ford
cool, so i can just get it and they will never know....then when it's service time just take it out and i'm good to go....
thanks...
i like the edge a lot...seams like a good unit
Old Feb 22, 2007 | 05:14 PM
  #111
qadsan's Avatar
qadsan
If the dealer sees a P1000 code, they 'could' be suspicious of an aftermarket programmer, but its the same code you'll get if you left your battery disconnected overnight. Make sure you put your PCM code back to stock and remove all traces of the Edge if you want to be safe. If you want the P1000 code to be cleared from memory, then you'll need to complete a drive cycle as defined in the following link...
http://www.obdii.com/drivecycleford.html
Old Feb 24, 2007 | 11:26 AM
  #112
GTPETE's Avatar
GTPETE
got mine from RealTruck.com - $335 out the door
Old Feb 25, 2007 | 03:00 PM
  #113
transam396's Avatar
transam396
I still would like to hear from some ppl who have used some of the other tuners and see what they think
Old Feb 25, 2007 | 05:33 PM
  #114
bluephi1914's Avatar
bluephi1914
I have heard from Xcal 2 users and Edge and those seem to be the top two, although edge seems to be a bit more popular. I just ordered my Bama Chips Xcal 2 from "Jusnes Mods" so i am going to post my likes/dislikes and feedback.
Old Feb 25, 2007 | 05:42 PM
  #115
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
does anyone have a hard date on when the new Xcal is coming out. the one that looks like the edge?
Old Feb 25, 2007 | 08:41 PM
  #116
bluephi1914
the limewire is already out... i couldnt see spending $600.00 (i got to many other expensive hobbies)... but it looks just as cool, if not better than the edge
http://www.jusnesmodified.com/store/
I did however get the xcal 2
Old Feb 25, 2007 | 09:32 PM
  #117
pukemon's Avatar
pukemon
even if a stealership got suspicious of the "p1000" code, you could always say you took it to your local mechanice to see if there was a fault code. he has to use an obdII compliant device to do that, and in return you could just tell the dealer i hear you have a shady reputation or i just wanted to know the problem before i took it in to protect yourself from unnecessary repairs. heck, even say you took it to o'reilly's or autozone or equivalent to check for codes.
Mr.BrrIce
2004 - 2008 F150
Jan 18, 2017 08:03 PM
skidooman
Computer Chips & Tuners
Nov 7, 2009 05:41 PM
GwarForAll1021
2004 - 2008 F150
20
Sep 8, 2009 10:45 AM
ChunderDownUnder
Jul 7, 2009 10:59 AM
SPRPRBGT
Apr 23, 2009 08:15 AM
