Fuel Gauge Sending Unit?
Is there a different name for this part or can it even be purchased separate from the tank? Maybe there's something I'm overlooking and it isn't that unit at all.
Anyone help out with this?
BTW, I think I've got the smoking problem taken care of. I put a regular breather cap on it that doesn't have an opening in the top, but still has a filter and breathes through the bottom, along with a new PCV valve. It doesn't smoke near as bad or blow oil, but there are times when I'm going up a hill under load that it will stall out in 2nd gear. That's another issue though.
Any help is appreciated.
As for your stalling, might even be the pickup tube thats on the sending unit.
2 Problems might be 1 fix!
I scanned the two gas tanks pages out of my LMC Truck mag. PM me with you email addy and ill send em right over.
9 times out of 10, the fuel guage problems are bad wiring and poor connections, not the sending unit. Crawl under the pickup and inspect the wiring to the tank, checking for cracks or rubbing. If it looks questionable, replace it. Be sure to solder the splices and use heat shrink tubing - crimp connectors will give you problems down the road. Also check that the connection at the tank is clean and tight and coated with dielectric grease. Also check that the ground to frame is clean and tight - I like to sand the rust off with sand paper and coat ground point with dielectric grease.
Marty
Good luck, Bob
Good luck, Bob
https://www.ford-trucks.com/forums/s...d.php?t=125288
https://www.ford-trucks.com/forums/s...d.php?t=125339
https://www.ford-trucks.com/forums/s...ad.php?t=39235
https://www.ford-trucks.com/forums/s...ad.php?t=39752
https://www.ford-trucks.com/forums/s...ad.php?t=40371
https://www.ford-trucks.com/forums/s...ad.php?t=41128
https://www.ford-trucks.com/forums/s...ad.php?t=42221
https://www.ford-trucks.com/forums/s...ad.php?t=42060
https://www.ford-trucks.com/forums/s...ad.php?t=42387
https://www.ford-trucks.com/forums/s...ad.php?t=42736
https://www.ford-trucks.com/forums/s...ad.php?t=42885
https://www.ford-trucks.com/forums/s...ad.php?t=43904
https://www.ford-trucks.com/forums/s...ad.php?t=43915
https://www.ford-trucks.com/forums/s...ad.php?t=44694
https://www.ford-trucks.com/forums/s...ad.php?t=45048
