I'm almost there. I've got the dash lights working, temp gauge, and now the last one. My fuel gauge will only read up to 3/4 full. I pulled the sending unit to see if it was in there wrong or hitting anything. Nothing. Also, I will let it get down to 1/16 of a tank and then fill it up. It only takes about 10 gals to fill up. So what I am thinking is that the sweep of the needle is somehow off by 1/4 and so when my gauge reads 3/4 it is acually full and when it reads 1/16 then it is acually a little more than a 1/4. Now, with that being said, how do I fix it. I have a 71 w in cab tank. I'm guessing that the tank holds more than just 10 gallons so I would really like to be able to go farther than 120 miles before filling up again. I don't want to just ignore the gauge to see how far I could go on a tank and see if my hypothesis is right. I would really like to fix it.
Thanks
Austin
For those of you doing to math, yes that is 12mpg out of a stock 460 C6 in a SWB
Im not sure how much this will help. I had a truck that did the same thing yours does. I needed a sending unit in a second truck, so I pulled out my only good one, the one that read 3/4 when full etc. In the new truck, it works just fine, reads normally. I would guess there is a wiring problem between the guage and the sending unit. clean you grounds and check for broken or cracked wires.
GL
Aaron
Dablack,
I have the same exact problem. Sometimes if the needle gets real close to E and I fill up the needle will go all the way full, then fall back again to 3/4. I pulled the tank and checked the sending unit. I gounded the wire and sure enough the needle pegged out at full. I even pulled another gauge out of a junker truck and the same problem. I've begun to wonder if it isn't the instrument panel voltage regulator. The wierd part is that all my other gauges appear to work fine.
My gauge does this, too. Sometimes when I fill it up, it will only go to 3/4, and sometimes it will go all the way to full. I can run it for about 20 miles after the gauge reads "empty". 79 F-150 4x4 All my other gauges work fine, too.
Black,
This sounds like a ground problem, maybe? Is this an aft tank? If so, the ground is in front of the tank and is commonly bombarded the dirt,salt and dead animals for the last twenty+ years. Check it, clean it and you'll be good to go.
good luck, have Fun,
kingfisher
Mine did the same thing for a while. I sure miss that...now it doesn't work at all. I'm not sure what I did. I pulled the dash to replace all of the bulbs, and when I put things back together, the fuel guage wasn't working. All of the wires are well labeled and hard to get in the wrong spot, so I don't know what I did. So I hit the gas station about every 100-150 miles. Unfortunately I'm getting well under 10MPG right now....need some more tuning I think :-)
Greg
69' F250, 390 (Ed RPM Intake, 750 Carb, Crower Power Beast Cam, all MSD ignition, long hedares and short pipes), C6 and dana 60w/4.10s.
man! mine does the same thing. 3/4 when full, still a quarter-tank left when on E. I checked out the grounding too, pulled the wire from the sending unit, and when grounded, the gauge pegs out at full. It's amazing how many of us have this problem.
I 've got the same weird bug. Is all it takes is claening the ground? Or is the new sending unit the answer? It is difficult to tell if anyone here actually fixed the weirdness.
Well at least I'm in good company. My solution to the problem will be to put a mustang tank between the frame in the back. New sender, new tank. I will be good to go. Saddly, there are so many projects on the list before that one that it will be at least a year.
Had the same thing happening for 2 years in my 67, so one day took a extra sending unit, Plug into wiring harness and manual operated float watching gage on dash, cycle it a couple of times, Reinstalled wiring to sending unit in truck and has gone from reading a little over half to reading whats in the tank, for a year now, Sometimes the strangest things work
GWB
