3rd OIL LEAK......
My truck had has 2 R/M seals go out in the first 6 moths
I don't appreciate your attack on me.
I have had two rear main seals replaced. It doesn't leak now. Replacing a rear main seal is no big deal on one of these trucks. I had my truck back same day both times. No big inconvenience.
You are making things sound worse than they are. I got better things to do than crawl around on my hands and knees for 3 hours. I could whine about all kinds of percieved issues about my truck, but I prefer to enjoy the better aspects of it.
The general impression on this forum (conjecture also) and others is that a handfull of people (same ones, over and over)are having serious problems and Ford is fixing or replacing them ALL.
After I read the rest of the posts in this thread, it looks like you work for Ford. Is that correct, Bob?
No I don't work for Ford either.
The dealer I go to must have an acre of trucks. So does the oil leak checker wear knee pads?LOL....
They may call the dog catcher or the cops if someone was crawling around on the ground by all of there SD / PSD's. As for the RM leaking again it has been several weeks know and it is still leaking and i don't think it is oil left in the BH or around the starter. Actually i just got up and went out and climb undernieth the truck and it is leaking. The bottom of the BH is completely covered and the Tranny's filter pan is covered.
I dont hate these trucks. I will own another 6.0 as soon as i get this one taken care of. Dont get me wrong it is disheartning with all these issue's but it happens sometimes. You deal with them and life goes on.
I will keep you guys posted, if you would like, on how my DSB goes. It is here in 2 or 3 weeks, i think.
Jeb,
Would you mind to let me know how it goes for you? Not trying to be nosy. Just wondering what to expect.
Thanks,
PSDboy
No leaks, no romp, no bad turbo, no nottin'... I keep looking and I keep listening for something to go wrong but it just ain't happening. I'm knocking on wood as we speak.
And I LOVE my truck.
And Again, I thank all of you for the tremendous amounut of information that as a new diesel owner I could never have the time to research.
I gotta tell you though, you guys pull the trigger to quick. You all speak of perceptions but none of you seem to precieve the meaning.
Joe Blow's perception is the world HE lives in. Not yours. If his leak and his experience with his dealer makes half the trucks in the world bad then that's the way it is in his world.
I also feel strongly that as a Ford truck buyer (91, 93, 95, 97, 2000, 2002, 2004) it implies that I have been making wrong decisions all these years. But, don't nuke the guy. Help educate. Ignorance is nothing more than the lack of knowledge.
Knowlegde creates beliefs which in turn creates perceptions.
Give people a chance before you de-humanize them. And after all this hate and discontent that's what I percieve is happening. That's my story and I'm stick'n to it.
The people we have a problem with are those who in venting their anger, make up facts and figures and present them to prove that all our trucks are bad. They would like to punish Ford and the rest of us (because we don't share in their misery)by driving the new buyers away and driving the value of our trucks down. As long as they don't twist the facts and keep to the truth, I'm O. K. with that. If they attack the truck with false facts, why would we be happy with that? Also some are Chevy and Dodge trolls just trying to start a flame war.
by the way, there is a service bulletin on insulation interfering with A/C function.
Jeb,
Thanks,
PSDboy
Well written and truthfull!
just had me wondering.
Did your friend go the DSB route? He is entitled to a hearing. There is always the State and the lemon law. There is also the option of hiring an Attorney. You see what I mean? This is why I say that we don't know of a single case that has not been resolved. Every one that I investigated, had been too busy or lazy to pursue resolution. The poor mileage cases turned out to be people who were griping about mileage but had never actually calculated their mileage. They just "felt" it was bad because the truck tank held so much more than their Acura.
2004 F-Series/Excursion Lack of A/C Cooling:
Trucks built between 12-1-03 to 1-26-04 may have strands of insulation trapped between the compressor and refrigerant line manifold. The system will need to be recovered and the the insulation removed from the joint. The tube and manifold assembly (4C3Z-19D850-CA) may be reused if it is undamaged, but the o-rings (1F1Z-19E889-AB) should be replaced. Broadcast Message 1118.
and ......
Programming update for 2003/04 6.0 PowerStroke: As of 8-8-03 there has been a new calibration for the 6.0 PowerStroke. This calibration was not installed in trucks built before 8-18-03. This update is supposed to address rough idle/surge/smoke at light throttle application, improved A/C performance at idle, minor manual transmission lauch performance, smoother downshift in tow/haul at 20 MPH, improved performance at low altitude/high barometric pressures and diagnostic updates. It also includes all previous calibration updates/fixes. Broadcast Message 0763/SSM 17048
The scan tool update implemented on 8-22-03 will cause a fatal exception error in the scan tool if model year 2004 is selected. Until a fix is released, select 2003 for 2004 models. Currently the calibrations are identical. Broadcast message 0798.
Good luck, I have an early 03 and it will frost you. I am in Central Texas so it is getting hot already.
