Which AGM Battery?
Old Dec 29, 2024 | 08:44 AM
stryder's Avatar
stryder
Originally Posted by 4wd6.7L
I've read that some of the newer trucks (20-22?) came default at 120% target SOC.
My 2020 was one of those. Lifted the hood to add some washer fluid and was met with strong acid smell. That's when I heard the batteries boiling. Batteries were 3 years old at that point. After hearing about all the failures, I started read all the AGM posts. Bought a couple X2 Power AGMs and hooked up ForScan to make the changes. That's when I noticed the charge rate at 120%! No wonder the batteries were boiling. I changed it to 90% after finding little information about the correct setting.
When looking at all the AGM specs, the warranty was actually the last of my concerns. Sure it is nice to be able to exchange at a store that is located just about everywhere, but I'd rather buy a better battery that is less likely to put me in that situation at an inconvenient time.
Old Dec 29, 2024 | 08:52 AM
HorizontalHunter's Avatar
HorizontalHunter
Originally Posted by OBS460
Probably why the batteries off-gas so bad they have to be wiped after every drive and corrode the hold downs so bad they peel paint and rust.
That’s one of the reasons I am upgrading. I’m starting to get rust spots on the hold downs from the out gassing and they just aren’t holding the voltage levels like they should.
Bob
Old Dec 29, 2024 | 02:32 PM
speakerfritz's Avatar
speakerfritz
that’s what I think
lets Down grade the charge so less gas is produced
Old Dec 29, 2024 | 02:34 PM
speakerfritz
I went thru a second set of flooded batteries since 2019
was going to go with agm but after digging into it…the EFB battery had higher heat tolerance than agm or flooded . So I bought EFB this time around.
Old Dec 29, 2024 | 02:35 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by speakerfritz
that’s what I think
Makes sense except for the fact that prior to 2020, these trucks came default set to a target SOC at 80%....and still had issues with off gassing and corrosion.
Old Dec 29, 2024 | 02:45 PM
speakerfritz
Old Dec 29, 2024 | 03:00 PM
nychan's Avatar
nychan
Originally Posted by HorizontalHunter
Time to replace the batteries in my 2022 F350 SD 7.3L dual battery and I figured I would upgrade to the AGM batteries....
Thanks,
Bob
Bob,
I have the same truck, only with single battery, why do you think it's time to replace the battery? Mileage? Hours?
Thanks,
Chan
Old Dec 29, 2024 | 03:04 PM
HorizontalHunter
When I change the battery profile to AGM do I also need to reset the BMS or will changing the battery type from flooded to AGM take care of that?
One would think that changing the battery type would reset the BMS but I thought I would ask.
Thanks,
Bob
Old Dec 29, 2024 | 03:10 PM
HorizontalHunter
Originally Posted by nychan
Bob,
Thanks,
Chan
The truck is my daily driver and is 3 years old 12k. The reason I am replacing them is that they are sulfating to the point that the hold down brackets are showing rust spots and it isn’t holding voltage like it used to. It also is constantly going into sleep mode.
No trouble starting yet but I hunt and don’t want to be stuck anywhere so I am being proactive. I sure wish these trucks had a voltmeter from the factory. Something I will remedy in the near future.
Bob
Old Dec 29, 2024 | 03:29 PM
nychan's Avatar
nychan
Bob
Thanks for the quick response. Mine is not a daily but I tow a decent amount (avg 1k+ mi/month) and also don't want to get stranded.
Bought it used earlier this yr with 21k and it's got 36k currently. I did notice my battery is sulfating as well.
If these things are programmed to charge at 120% with factory battery and considering comments the AGM should be 80-90%, what % do you intend to set yours?
TIA
Old Dec 29, 2024 | 03:56 PM
HorizontalHunter
TIA
Undecided, I am not sure what it will default to when I change the profile to AGM. I damn sure won’t leave it at 120% if that is what it defaults to. I just re-upped my Forescan membership so I can take care of the programming.
Bob
Old Dec 29, 2024 | 04:26 PM
scraprat's Avatar
scraprat
Top Answer: 5
I'm guessing that you'll be doing a little cleaning maintenance besides the battery replacement? A solution of distilled water and baking soda on the holddowns and battery ends to remove all corrosion and residual acid deposits. A quick sanding & repaint the holddowns with some black rustolem. Give the battery/ cable ends a coating of some NOCO NCP2 battery corrosion preventive.
Old Dec 29, 2024 | 04:48 PM
  #28
HorizontalHunter
For sure. I plan on keeping the truck a long time.
Bob
Old Dec 29, 2024 | 05:02 PM
  #29
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I threw the Interstate AGM's in my 2018 and was very happy with them. I didn't change any Forscan settings.
Old Dec 29, 2024 | 07:52 PM
  #30
WXboy's Avatar
WXboy
Well I set my truck up for AGM battery 700 CCA and also changed charge to 90%. Now have to order the batteries. NO Walmart stores in my area stock the Group 65 AGMs.
