Took me a while but...
It looks like you can fix it the same way I did with flat sheet metal.
Just need to plan how you can get to the top to weld it in like I did when it was open.
Dave ----
I did manage to score an awesome deal, I bought a brand new radiator core support for $50! I was planning to use the one out of the parts truck that seemed to be in decent shape but when I found this deal it was a no brainer... I'm expecting the original bolts to break so new bolts are going to be in order. I've been searching for the specs on these bolts but no one seems to give details other than FoMoCo part numbers. Does anyone know what size and length these bolts are? I'd rather go to Tractor Supply and get a couple grade 5 bolts and nuts for pennies over spending $100 for a kit online. Yesterday I painted the axle with the first coat of farm and implement paint and today it'll get the 2nd and maybe 3rd coat. I'll also paint the core support with the same paint. Today I'm also going to reinstall the brackets and crossmembers on the frame as well as running the new brake lines & cables and the fuel lines. Rear tank has a couple of small holes so I got the tank repair kit by JB Weld so that's also getting fixed and painted. If time permits I plan to start pulling the old core support out and hopefully tomorrow the new one will go in. Hopefully I'll get to reinstalling the rear axle tomorrow as well. After that, the only things left to do are the front brakes, finish fixing the dashboard, removing the broken valve cover bolt, install new mirrors and transfer the bed from the parts truck. Hard to believe but phase 1 is almost complete! If all goes to plan, I should be driving Ol' Red on Wednesday... Sadly I know how all of my plans usually go so I expect something to happen. We shall see...
Also PB Blaster is good for helping to remove old rusty bolts, or if you have the $$, Aero-kroil is really good.
1) Finish painting the axle... Decided it only needed a second coat. CHECK!
2) Paint the core support... Still needs a second coat. Couldn't move it for about 4 hours after painting. Partial Check.
3) Reinstall spring hangers, shock brackets and crossmembers. CHECK!
4) Repair and paint rear fuel tank... Tank repaired but didn't get to painting it.
5) Remove core support. Got all bolts and screws off the support. All but 1. The main nut attaching the passenger side to the frame had rotted away only leaving the flange and a small portion of the hex making it imposable to unbolt. Tried a few different things but nothing worked. I resorted to cutting that section of the support off to remove. I ran out of daylight to finish that so Monday that will be finished.
6) Finish fixing the dash. I got the dash pad painted in the correct color but that's as far as I went. Tomorrow I'll repair the traces on the back of the cluster.
7) Run new brake lines and "E" Brake cables as well as the fuel lines. Didn't get to this but this too will be done Monday.
In regards to the fuel tank mounting diagonal brace. I decided that the rotted brace is still solid enough to put on the other side as only the center section is gone but the sides are still intact. I am still looking for a replacement but for now it'll do.
The gauge cluster looked like a 40 year old cluster with faded needles and the lens didn't look great. The gear indicator cable was also broke and some of the traces have lifted away from the plastic film.
Needles repainted, lens cleaned and polished & cable replaced. I still need to fix the traces and clean the contacts of all bulbs. I did clean the contacts on the seat belt, directionals, high beam, brake and 4X4 lights. I did upgrade the directionals and high beam bulbs to LEDs. The clock adjustment buttons didn't seem to work so I took some 99% IPA and 2000 grit sandpaper to the contacts. After a couple of passes the buttons all work perfectly.
Tomorrow's forecast is rain most all day so no work tomorrow. EZ-UPs only go so far.
I've never had any really good results with PB but I will say KROIL IS THE $#IT!!! I tried it a few weeks ago and will never go to anything else. Yes it's a little pricey BUT you get what you pay for. I'm cheap AF but I will spend extra on something that is proven to work for me.
Sorry no pictures today. I try to remember to take pics but don't remember most times.
As for the cluster traces I would bite the bullet and get a new one from LMC.
And if you got gauges and no tack (yet) get the trace for a tach and later when you find one you can just bolt it in.
What paint did you use on the gauge needles?
I used Testers and got to say they look great in day light but are hard to see at night with my geern LED bulbs.
I have one that flashes on & off as I drive so need to pull the cluster to fix that 1 bulb.
Dave ----
Dave ----
I was looking into getting a new trace but mine only has a couple of traces that have lifted and nothing is broken. I'm trying to keep this build on the cheap so if I can re glue the lifted traces safely and save money...
I already do have the tach so that's a plus. I was actually happy to see the factory digital clock and tach when I got it.
The needle paint I got was from a seller called "White Gauges" on eBay. Cost for a small bottle (0.5 oz) of fluorescent orange was $8 and the LEDs were from the same seller and they were about $5 each. I was expecting the LEDs to be brighter than the stock bulbs and they are but not by much. I got 2 of their green LEDs for the directional and a blue LED for the High Beam indicators.
Before...
After...
I may or may not touchup the bottom of the lens... If those scratches are visible then I'll fix them...
Cross your fingers on the rear tank. If it is rusted bad enough to cause holes, then it's rusted on the inside also. Rusty tanks are bad for your fuel system and carb, causing reliability problems. Later on I would plan on a new tank.
Yeah I'm not expecting much more time with that tank. I'm prob gonna rinse it out with hot water and a bunch of nuts and bolts to knock off the loose stuff then maybe buy a can of tank liner. I just want it to last till at least the winter and I'll replace it during phase 2 of this restore.
I also found another issue when I was working on the core support... The battery tray is almost non existent so I need to replace that. It really bothers me that a new one costs anywhere between $80 -$120! How can a small piece of tin cost that much when a new door is around the same price???
https://www.google.com/search?q=batt...client=gws-wiz
There are color domes that fit over the factory bulbs to make them green. They get dirty & frosted and dim the light from coming thru.
Remove the color domes and you get bright lights.
Dave ----
Ahh ok... They are blue in my cluster. I haven't checked them in the dark yet but I did clean them when I referbed the cluster.
