New to me - 2005 Excursion
I have been on this FTE forum for many years. After a few years of not owning a 7.3, I bought a 2005 6.0 Excursion yesterday. Many thanks to Razzi & Mike for helping me with the search and decisions. Looking forward to spend a lot of time on this sub-forum reading the posts, tech folder etc. and hopefully contributing to the awesome expertise and experiences that this forum brings.
Short Intro - I am an IT guy by profession, but love to work on my own autos. Not scared to get my hands dirty. Play a lot of golf, ride a lot motorcycles as well
and have a great affinity to the Excursion platform!!Really important to know what the temperature (oil and coolant) behavior is. Fuel pressure is also an important thing to monitor, but that requires an add-on sensor AND gauge.
It is an 05 6.0.
I doesn't seem that you realize (although you may know this already) that all the early '05 Excursions (2005 Model Year Excursion manufacture dates from mid '04 to January '05) actually came with the late '04 engine. It is very important (for parts purchasing at a minimum) to know what you have.
Post a picture of the top of the engine and we can help you learn a few things about it.
The SCT livewire can display multiple engine parameters nicely. Just be aware that it doesn't retrieve codes very thoroughly (if in the future you need to do some troubleshooting). Also, I am not sure if it accurately displays the EBP value accurately or not. Just can't recall atm. I have an outdated DashDAQ monitor for watching engine parameters and troubleshoot with FORScan and FORScan Lite.
Thanks, good pointers. Keep them coming. I have a lot of reading to do here. Some more info on my Excursion & things that I have to get fixed first.
- Door tag says Mfg date is 09/04.
- P0401 - EGR has been lightened, 2 owners before me. But no tuner installed on the vehicle.
- Needs 2 glow plugs
- Needs new-er batteries. I have a code from the ABS.
- Need to figure why the Water in Fuel indicator keeps coming intermittently
I used to run Torque Pro on a tablet on my 7.3. Maybe I will do the same
- CEL Codes & dash lights
- P0401 - I have a new Motorcraft EGR valve ordered for this. While I read that the old one can be cleaned and used, I preferred to get a new one. I'll clean the old one and store it as a spare.
- P0562 - System voltage low. Though motorcraft batteries on the truck are only a few years old, I am getting new Interstate AGM batteries from Costco. I've had good results using this battery in many vehicles.
- P0676 & P0678 - 4 New Motorcraft glowplugs have been ordered. 2 will be installed, 2 will be spares. The old one will be discarded
- B1676 - The PO had replaced the +ve terminal on the passenger side cable as it had broken. I suspect that there are other breakages in the cables. While the truck does fire up easily, it does feel like the starter needs some more ooomph to tun the engine over. A new complete cable set has been ordered from Performance Custom Cables. I have ordered a new voltmeter and will monitor the health of the batteries to see it it warrants a new alternator.
- WIF light is on. Will drain the HFCM and also clean it thoroughly. Should I buy a new housing & replace it, just for sanity?
- Engine Oil & Filter Change - PO had the oil changed at a Firestone shop about 2k miles ago. I always like to do my own immediately after I buy a vehicle and then in multiples of 5k there after. Ordered 3 gallons Rotella T6 5w40 from Amazon. Also bought Motorcraft Oil filter & cap, Fuel filter, and Air filter from Diesel Filters Online. It is on the brown truck now. Currently has a Napa Gold oil filter & cap on it.
- Ordered Archoil 9100. I have used Hotshots Stiction eliminator in the past with good results.
- Ordered a vLinker OBD reader. I couldn't find my old OBD readers from my 7.3 ownership days
I have FORScan on the phone & Torque Pro on the tablet. Should be a good start to be able to read and monitor the engine data. - Transmission, Transfer case - Flush & Fill: What is the recommended oil for this? Need to search the forum too.
- Coolant flush and refill - This will get prioritized higher based on the engine data that comes out. I would like to combine this with replacing the oil cooler from BPD at a later time if possible.
- Ordered a set of 17+ style tow mirrors from Boost auto. I've had a great experience using the Trail Ridge mirrors from 1AAuto in the past. Just want to give this style a try.
- Leaf Spring & shock absorber Kit - Either a set from ATS or will do the Pirate Procomp setup (it is detailed on the Excursion sub-forum). The front springs are almost horizontal now and there aren't any bump stop on either side.
- 20" Wheels and new tires. The current set on the truck is old (0216 date code). I am eventually going to need newer springs which will probably raise the truck. So debating whether to get new tires for existing wheels or get a whole new set. I prefer the OEM style wheels with appropriate spacers. My spare tire is the original spare from factory. Neither of the previous owners have opened that cover. The steel rim is all shiny
Debating between Michelin LTX and General Grabber HTS. I had these on the two 7.3 trucks before this one and liked them both. What's the forum choice? - Hubs - Motorcraft/Warn/Milemarker - what's the forum's choice?
- Seat heater elements & new seat bottom covers. I plan to take it to a local upholsterer first to see what he can come up with. Otherwise, I'll end up ordering from The Seat Shop.
- 10" Android based head unit - Looking for recommendations
@Toreador_Diesel @bismic
Just an fyi - P0401 could ALSO be a dirty (or bad) IAT2 sensor, so you might check that.
It is a toss up on an entire new HFCM vs just clean the old one up. I guess my recommendation would be for you to start cleaning it up - first remove the manifold, and post pictures of what you see.
The only transmission flush that will work is this one:
Don't forget to change that bypass filter on the transmission fluid!! It is the more important one of the two.
