Clutch adjustment help…please
Old Feb 21, 2024 | 01:32 PM
  #106
Max Capacity's Avatar
Max Capacity
Yours should look like these, I'll let Karl or Dave make recommendations on adjust yours. It's been almost 50 years since I played with Holley's.
https://www.google.com/search?q=1985...t=gws-wiz-serp
Old Feb 21, 2024 | 01:33 PM
  #107
Max Capacity
Hard starting when warm,
Old Feb 21, 2024 | 02:18 PM
  #108
BigBlue2's Avatar
BigBlue2
Originally Posted by Larry115
I should probably start another post but I’ll ask anyway and if I should tell me. My truck almost always starts except in -20 weather. Having said that even in warm weather or when the engine is hot I have longer than normal crank times before the engines starts…is this normal on old truck or is there something I can do to correct this?
larry
Larry it is a good idea to start a new thread because it keeps pertinent items under a new title. That helps you attract knowledge to your issues because guys that don't do clutches but are knowledgeable on cold/hot starts might read your post. Plus it helps others find solutions that have similar issues. But all that said there's no hard and fast rules here. I did read the posting guidelines. But that was years ago. The only thing I recall as prohibited was politics. I probably should read them again. I think they say the purpose of these pages is exchanging truck info.
Old Feb 21, 2024 | 02:30 PM
  #109
Max Capacity
Larry, the more info you can give, the better the response you'll get. I think I asked some good questions to start with.
Old Feb 21, 2024 | 05:34 PM
  #110
FuzzFace2's Avatar
FuzzFace2
Yes do start a new thread as it can get long but as said if someone dose a search they dont have to go thru all the clutch stuff.
Dave ----
Old Feb 21, 2024 | 05:50 PM
  #111
Larry115's Avatar
Larry115
I’ll take pictures as u suggest. I’ll try and make a short video of a start. It does this hot or cold
larry
Old Feb 21, 2024 | 05:52 PM
  #112
Larry115's Avatar
Larry115
That’s not a bad idea! I’ll call around…thanks
Old Feb 21, 2024 | 05:53 PM
  #113
Larry115's Avatar
Larry115
10-4 I’ll do it now…
Larry
Greasemonkee
Jul 23, 2020 05:57 AM
phoneman91
Feb 24, 2012 01:48 AM
mudmaker
Apr 28, 2010 11:03 PM
brosko80
Mar 8, 2006 08:35 PM
dvw70
Nov 16, 2005 08:36 PM
