2004 6.0 issues PLEASE HELP
Old Aug 15, 2023 | 08:53 PM
  #46
Isaiahburling18's Avatar
Isaiahburling18
Trailering
In still confused as to why the problem was cylinder 5 the first time and is cylinder 5 again. Does it have to do with that Icp sensor?
Old Aug 15, 2023 | 10:48 PM
  #47
BryanStein's Avatar
BryanStein
Cylinder 5 the second time is because the tech that installed it should be bagging groceries instead.
Old Aug 16, 2023 | 06:03 AM
  #48
IHateCommieCars's Avatar
IHateCommieCars
If you don't understand, Isiah, that washer is not a washer, it's a gasket, a seal. It can only be used once. If you remove - even loosen - the injector for any reason, you have to replace that crush washer. Leaving it off is very incompetent.
Old Aug 16, 2023 | 02:29 PM
  #49
bismic's Avatar
bismic
That copper washer can also burn up - especially if any mistake was made in the injector torquing, but also if an injector over-fuels.
Old Aug 16, 2023 | 04:17 PM
  #50
IHateCommieCars
Oh my, hadn't thought of that. I guess it has to melt, so not really chunks of copper floating around, just lots of fuel. Prolly needs to change his oil.
BWilcox
Jan 12, 2023 03:38 PM
wrhodes416
Feb 10, 2019 05:24 PM
leo_92040
Dec 25, 2009 12:01 PM
bigrassman
Oct 22, 2009 07:45 AM
Scca_Srf
Aug 18, 2006 11:10 PM
