Replacement for Widowmakers?
Old Nov 7, 2023 | 12:30 PM
  #76
DieselDog409's Avatar
DieselDog409
Good to know, Thanks Stu.
I now have 5 leads instead of just one.
Old Nov 7, 2023 | 12:32 PM
  #77
DieselDog409
One last question, will my backspacing change when i weld in the centers where it shows in the diagram and if it does will that affect anything?
Old Nov 7, 2023 | 12:34 PM
  #78
DieselDog409
One more last question, should i grind or torch off the rivets that hold on the rim center piece?
Old Nov 7, 2023 | 12:52 PM
  #79
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
If you intend to build your own using your WM centers with donated 22.5” rims harvested from some other bolt pattern originals or Daytons you’ll probably be working with rims that are wider than your WM originals. Yes, you can attach your discs along the drop centers of the new rims. They should fit cleanly. Balance any width differences front vs rear and I’d think you’d be okay. Don’t go too big so as not to rub the front fender wells and inner fenders.
Grind or torch is your choice. Stu
Old Nov 7, 2023 | 12:59 PM
  #80
DieselDog409
Okay thank you stu.
Old Nov 7, 2023 | 02:39 PM
  #81
bobj49f2's Avatar
bobj49f2
Bad Chad did an episode of welding up a set of wheels for his '48-50 car hauler. He bought wheels out of a local junkyard. Another reason to check him out.
Old Nov 7, 2023 | 02:52 PM
  #82
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Chad's approach is, um, ah, interesting, and not sure how concentric he got his centers. Well scrutinized here: https://www.ford-trucks.com/forums/1...ck-wheels.html
Old Nov 7, 2023 | 09:08 PM
  #83
bobj49f2's Avatar
bobj49f2
Yeah but good enough for some
Old Nov 8, 2023 | 08:19 AM
  #84
DieselDog409
Yeah my only real chalange with this is alligning the disks in the rims and spacing them all evenly.
Old Nov 8, 2023 | 10:29 AM
  #85
bobj49f2's Avatar
bobj49f2
If I had to do this the way I'd do them is mark where I need to weld them and just tack weld them in and install each on on the front axle of the truck and place some kind of reference marker, like a dial indicator, and spin the rim to see how true the rim is.
Old Nov 8, 2023 | 12:39 PM
  #86
DieselDog409
Never thought of that, things just got much easier.
Old Nov 9, 2023 | 12:37 PM
  #87
cruisetopdown's Avatar
cruisetopdown
Personally I would never consider a modification of this nature, not that it can't be done, and done well, but you are taking on legal liability if anything happens on the road. If you were to get into an accident, the lawyers would have a field day....just my 2 cents.
w
Old Nov 9, 2023 | 01:05 PM
  #88
DieselDog409
Well a grinder and paint makes me the welder i aint.
JK im a very good welder but i will hide the welds so it looks factory.
And if i crash i am going to die anway. so the law cant get me then.
Old Nov 9, 2023 | 01:13 PM
  #89
cruisetopdown
You'll be gone, but the law will get anyone tied to you (if you injure anyone), so think long and hard before you do it.
w
Old Nov 9, 2023 | 01:20 PM
  #90
DieselDog409
if it looks factory then the textbook experts wont suspect a thing since the welds will be ground flat, also this truck lives on the backroads and has gone into town 3 times in the year ive owned it.
i understand your concern but this is my only viable option for rims.
