Bent leaf spring? Bent frame?
He has a 1999 leaf spring design.
A 2001 model has a different front leaf spring design.
We actually have been over this whole leaf spring thing, not just a little ways back, but a long ways back too.
My 2000 model year springs have gaps between the upper and lower leaves just as large as Hyakkimaru's.
Subsequent model years did not.
here is my 2001 and my 1999. Both have identical leaf sprig design. One is a x code one is a v code. Ford may of made a design change mid year but in no way was there a absolute like you stated. My 2001 is all stock. My 99 has had its sprigs replaced but the original ones were identical in every way with the exception of the rating. I went from v to x code and that was only because I I put a huge winch bumper on it and it was sagging the at the time 20 year old sprigs.
I have not seen one F series that had that huge a gap between sprigs. Maybe it’s a trim line specific option. We dot even know the rating of the sprigs. He coke have two different rated work my codes for all you know. Every one I worked on and it’s been a few has always had the tight end sprig pack.
Considering his truck is pieced together from multiple trucks we don’t even know if the sprigs are from the same truck. That bent sprig clamp can be a issue also. Both my trucks have clamps holding the ends and both leaf packs are tight.
Either way there is obviously something wrong if his truck is doing what it’s doing and I’m simply trying to help the guy out. If he has bent suspension components they will never get that truck aligned right.
2001 rear of spring
2001 front of spring
1999 rear of spring
1999 front of spring
2001 mid spring axle mounting
2001 rear of spring
1999 rear of spring
As for the leaf springs, I understand your confusion and why you're worried but please do not worry about the leaf springs because there is nothing wrong with the way they are. They are off of a early 99 truck. If you know anything about the early 99 super duties, you will know it didn't last long before they updated to new things.
I just want to put out there that my truck was not pieced together from multiple trucks I took the front end off of one truck and put it on mine. The springs came off of the same truck as the front axle. I actually got it from Georgia and we took the entire front end off of the truck in one piece. Put it in the back of my truck and drove it home. The leaf springs were still attached to the axle along with all the brackets and bolts they were all assembled in the back of my truck. I have pictures on my phone somewhere. It was quite a sight to see the entire assembled front end sitting on the ground on blocks.
Nobody is upset at you in any way and I am very grateful that you are helping. If you watched either of the two videos I posted you will see that I found my lift kit bracket and spring hanger bent. I'm sure that is part of my problem. I think I'm going to start with that pmf lift bracket kit to delete my bent lift bracket and the OEM spring hanger because I'm having trouble finding one anyway. I think that is a good course of action to take at my current point in time. I've never messed with pmf parts before so I will do some research first but I think that is my best course of action at the current moment. Thank you for your help!
i only worked on one early 1999 in 20 years and it was a buddy’s. I dont remember anything about the leaf sprigs even though I rebuilt his whole front axle.
if yiu were closer I would throw that thing on my rack and start pushing and pulling on thugs and see what we find.
ill look for those front sprig hangers. I can’t remember if they ended up in the scrap pile. I can’t see my 99s cause the bumper covers them. But if I throw it on the rack I can get a pic of the backside to see if that bend is there. I don’t think that’s your issue though.
as far as PMF those products are good. I bought a set of blocks for a buddy who wanted more lift on the back and I didn’t wanna stack blocks and a set of their air bag plates for a service truck I was tearing out the crappy axle bolted airbag mounting kit .
their stuff is stout
it may not be the problem but it is a problem. I know for a fact the lift kit bracket is bent. I can't tell if the factory hanger is bent or not. But either way that pmf kit completely removes the factory stuff so I won't have to worry about it anymore if I go with that option. I've had that side of my cab leaning down an inch lower than the passenger side for a while now thought I was seeing things. Is the bent lift kit bracket causing my alignment to be off? I don't know. But I do know it is a problem. I have to replace it eventually anyway so I will start there and probably just have an alignment done after that and see how things go. Other than that unless I have a bent axle or tie rod or something like that I don't know what else could be messing my alignment up so bad. I've already replaced the hubs and all the seals, ball joints, from what I can tell the axle is not bent, the knuckles seem fine, other than this bent corner on the bracket, I don't know what else could be wrong. I do think it's a good place to start though don't you?
I have a picture of the donor truck somewhere, but the driver side frame took a head-on collision bending the driver side frame outwards a bit. So it's not surprising that the hanger/lift kit setup got bent on that corner because it totaled the frame.
sorry I don’t know the history of the vehicle so if im hashing our old stuff just pm me the cliff notes
I could send you a link to the 4x4 conversion forum that I started when doing this conversion but, I think it got to some ridiculous number of pages. I feel like it was 60 to 80 pages long or something. Definitely not the longest on our FTE forums but it was quite long and I don't think you want to sit and read through the whole thing unless you want to have a laugh and read through a bunch of information.
https://www.ebay.com/itm/154915327215
https://www.ebay.com/itm/162172692720
Edit: one of those is not on PMF's website. I'm gonna order from them. Should I get a bash bar?
Is it pulling to the right on all roads? Remember the crown of the road varies alot but generally slopes to the right. If your able to find a less traveled road have you tried running over the middle of the crown to see if its still pulling?
