I forgot to add that all of the screenshots taken at any speed other than zero were on cruise control. The 55 MPH shots were in 4th gear and the 65 MPH shots were in 5th gear.
I use control almost all the time. I know some don't like it, but I enjoy it.
I have a 205 thermostat in the IH pump. These are common EOT readings that I have seen for the past 7 years in hot summer weather like we are having now.
No noticeable difference in EGT, boost or acceleration between 80HP and 65HP. Hydra is now set to 65HP and that is where it will stay.
Interesting info Sous. I was surprised to see IAT around 130 while moving down the road. Normally it tends to balance out with ambient while at cruise speed even with the 6637.
Wish I could find the MAT on my CTS. Been wanting to get an eye on that reading for years just out of curiosity.
I used to just zip tie the IAT sensor to something behind the 6637 but I got fancy during the install the other day.
Since I’m using the old base I was able to drill a hole in the backside and add a couple notches. This allowed me to put the IAT sensor right into the plastic base very similar to the original setup. Probably not worth the trouble but I was feeling extra creative.
One “concern” over the placement could be a false lower reading since it will likely be seeing more of the cooler frontal air as opposed to the warmer air the filter will be sucking from up above.
I believe the sensor location makes a difference on the reading as well. I would say that my IAT sensor has very little to no air flow around it due to the plastic cylinder and the dead air space under the fuse panel.
The AC was blasting as well, so I am sure that contributed to the temperature reading.
As you can see, there was very little to no difference between IAT and MAT, which is what I expected to see.
WV Jason, I don't know anything about CTS, but I would think MAT was there somewhere...
I generally zip tie it to relay bases right behind filter. I suspect the sensor location makes a difference.
Yeah that’s where I usually stick it too.
Yes it sounds like yours is not getting much flow at all. My new location may not be the greatest but I liked the “factory” style setup, or at least the concept of it. If we really wanted to get fancy we could plumb it into the intake tube....but then the wire wouldn’t reach. Never mind. I don’t think it’s a big deal anyhow. Does the PCM use the signal for much control or is it more of a gee whiz kind of signal? Same question with the MAT?
Yes very little difference. But you were also having falsely elevated IAT readings from sensor placement I believe. I feel like your actual IAT was more likely around 100*. So we are probably looking at a 30* increase even after intercooler. I have no idea what is normal here. I would expect the MST to have a higher increase in temp than the SXE.
One would think. I have the 1st version CTS so maybe it doesn’t have as many options. You would think it would have tha ability to display any PCM channel. It really doesn’t have that many to choose from. I would consider eventually updating to the CTS 2 or 3 if it has more channels.
So I’m not sure what the PCM does with the IAT and MAT readings. Started wondering how much they would impact things.
For example I know our trucks like OEM sensors, but for the MAT replacement I went with the parts store version. At the time I didn’t think the PCM really used it to make many decisions so figured it didn’t matter.
Can someone point me to a thread on the subject or give me the quick explanation please?
From the MAT pdf attached: A MAT sensor is used to measure intake air temperature after being cooled through the intercooler, used to determine injection timing.
Some info on both IAT and MAT from @cookie88 in the thread below:
i dont think they are that important, alot of guys that live tune these turn those off, eot too.
Several years ago at what I think was one of Bean's first blackout in the country events, a 7.3 with AIS was doing a dyno run. It was a tuned truck with 38r turbo big exhaust but stock injectors. Someone filmed the stock hose going from AIS to turbo collapsing on acceleration. It collapsed and then regained its form very quickly. Could that be an explanation for black smoke and then clearing? It was also talked about as a oil consumption issue and the rash of blown off boots on the I.C. piping. It was posted on D.S. but I can't find it anymore.
Thanks for the link. Interesting read but I didn’t see where they came back for an update after all the testing.
I was also under the impression those sensors weren’t so important. That’s why I went store brand for the MAT.
Interesting....now I need a camera under the hood too. However what I’m seeing is the AIS has LESS smoke than the 6637. This I cannot explain. Granted it is not at wide open throttle. We’re talking 50mph cruise to a half throttle acceleration. Basically the smoke and then clearing is because at that particular rpm it is slightly under the turbo but the auto doesn’t kick down when accelerating. So it smokes a little, spools up, and clears up.
But what you’re taking about could explain the pulled in FM with the AIS under hard acceleration runs.
I’m really tempted to open the AIS box to the fender and test some more. But at this point I’m hoping to wait until some real towing with the current 6637 setup. My battery terminals have been getting a workout with all these changes.
I don’t think the restriction is on the dirty side of the air box...
But I would like to know!!!
I don’t either in reality. That filter is great...but made for a stock truck. Guess I coulda pulled the filter and did a 140hp run to check the FM. Oops. Too late now as I think the AIS portion of the test is on a break.
I know there’s been tons of people do the fender mod but I’ve never seen where it definitively flowed more with the mod.
If I could get the AIS to work for 95% of my driving conditions then I think it’s worth it. Honestly I don’t give a hoot about how it flows with the 140hp tune or on a drag race run. But if it will keep up with a 65 tow tune even when pulling hard then I’m sold. I’d settle for no more than 50% on the FM under the hard tow. Shoot my MST would do that.
Anyone else have an AIS laying around and want to play too? Throw it on with the SXE and tell us what you think.
