FTN's T4/SXE Build/Conversion Thread
  #61
Old 07-14-2020, 12:53 PM
FordTruckNoob's Avatar
FordTruckNoob
FordTruckNoob is online now
Identifies as He/Him/Noob
Received 3,027 Likes on 1,997 Posts
The EGTs are still getting stupid high though. Also, it appears the EBP sensor has a FSD (channeling Sous' love of TLAs here) of 55psi absolute. The VGT/VNT comes with its own drive and boost pressure sensors so it will be interesting to see the logs of those.
  #62
Old 07-14-2020, 01:22 PM
Sous's Avatar
Sous
Sous is online now
Received 4,579 Likes on 2,905 Posts
I still stand by my original comments from post #39, which I have noted below...
Originally Posted by Sous
Holy crap look at that EGT gauge go!
Wow...
Despite the boost and RPM climbing, the EGT continues to climb to 1600 where the gauge is pegged.
I think you will be very pleased with the new SXE turbo and hopefully the VGT/VNT is a great performer too.
On a side note, I really like the gauge overlay that you used. I should have done that for my gauges when I was creating some of my videos...
  #63
Old 07-14-2020, 01:51 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
It would be nice to see you do this again with a different tuner! I to run DP tunes, but like every body says I have to watch my EGT's all the time to. Especially when towing. It is going to be nice to see what the sxe does for you with dp. But your boost is now there.
  #64
Old 07-14-2020, 02:58 PM
FinnishStroker's Avatar
FinnishStroker
FinnishStroker is offline
For comparison my custom 63.4mm stock turbo..💪
Notice the zip' tied extra gauges!🤡
  #65
Old 07-14-2020, 08:25 PM
SuperchargedPSD's Avatar
SuperchargedPSD
SuperchargedPSD is offline
I enjoyed reading thru and catching up. That turbonator is a interesting piece. I run a roots blower feeding into a S369. If I was actually still playing with my 7.3 I would look at using one on to spool up my S369 1.0 faster and gain the brake function. I'll be following along.
  #66
Old 07-15-2020, 05:59 AM
FordTruckNoob
Holy cow. Over 3 bar of boost and over 3000 rpm! That is outstanding.
Thanks! The retaining the exhaust brake/EBPV function is what attracted to to the VGT/VNT turbine housing too. I have yet to find your build thread on PSN. I doubt your setup is suffering from lag though.
  #67
Old 07-15-2020, 06:19 PM
SuperchargedPSD
Not really but could be improved upon. The blower also works as a brake as well. You just put it in neutral to coast being a manual truck. It holds itself back pretty good. I posted a summary thread in the OBS section.
  #68
Old 07-24-2020, 04:52 AM
FordTruckNoob
I got set up to bench test the Turbonator yesterday and ran into a hiccup. It seems I might have a wonky controller. It refused to close the vanes down to 0% when commanded. I spent an hour and a half with their tech Brett trying to figure it out before he told me to send the controller and entire wire harness in. It's going back today. Stay tuned for more news.
  #69
Old 07-24-2020, 12:02 PM
Bonanza35's Avatar
Bonanza35
Thanks for keep us updated. Lot of us really watching this.
  #70
Old 07-24-2020, 11:14 PM
sjbj's Avatar
sjbj
sjbj is offline
Subscribed to this one. Very curious on the Turbonator. Be kind of nice to have exhaust brake. Although if my research is correct, is this looking like roughly a $2500 additional price tag (if getting exhaust brake option on Turbonator) to the already "close to $2500" price of upgrading to the T4/SXE? So close to $5000? If so, ouch.....
  #71
Old 07-31-2020, 12:24 PM
FordTruckNoob
Performed a quick, uncalibrated reclocking for another mockup today.
  #72
Old 08-01-2020, 08:22 AM
FordTruckNoob
Heard back from DPS. They were able to reproduce my issue. I apparently fat-fingered the keyboard and somehow managed to get the controller to accept an implausible value. They have fixed it and it's on its way back to me.
  #73
Old 08-01-2020, 01:10 PM
Bonanza35's Avatar
Bonanza35
Glad that got it fixed and it's on the way back. Can't wait for the review of this. Is that the carson T4? Is it stainless steel?
  #74
Old 08-01-2020, 01:14 PM
Sous's Avatar
Sous
Sous is online now
I too am really looking forward to the results of this. This is simply not in the cards for me, but I fully support your adventure into the unknown and hopeful for incredible results.
  #75
Old 08-01-2020, 01:25 PM
Dan V's Avatar
Dan V
Dan V is offline
I don't see that orientation fitting under the cowl.
Quick Reply: FTN's T4/SXE Build/Conversion Thread
