Ac compressor compatibility?
Old Jun 20, 2021 | 12:03 PM
  #121
Mayham7.3's Avatar
Mayham7.3
A failed orifice tube is the only thing I can think of that would prevent the hi-side from building pressure assuming everything else is working as it should.
everything is new as far as components go. ac compressor, expansion valve, orfice tube, accumulator , condenser all have been replaced you think too much oil could be the be a factor ?
Old Jun 20, 2021 | 12:16 PM
  #122
SkySkiJason's Avatar
SkySkiJason
I’ve put that orifice tube in dozens of trucks. I doubt that is the issue.
The low side is very high. Either the system is overcharged (or possibly too much oil??? ) or there is an obstruction somewhere.
Were you able to flush all the lines and evaporators/condenser/etc out?
Old Jun 20, 2021 | 12:38 PM
  #123
FordTruckNoob's Avatar
FordTruckNoob
Yes it could be too much oil or too much refrigerant but the problem only started for your wife after it ran okay for awhile, right? Did you fill refrigerant by mass or by watching the pressure? By mass is most accurate. Also like SSJ said, how did you evacuate the system?
Old Jun 20, 2021 | 01:44 PM
  #124
Mayham7.3's Avatar
Mayham7.3
from what my temp scale shows it seemed to be in check with it I charged by pressure & it said it takes about 68oz of freak so I bought 6 12oz cans and the last can I put about half in so if anything it was short and I flushed everything I took both evaporators out of the truck and flushed them all the lines and everything very very throughly
Old Jun 20, 2021 | 01:49 PM
  #125
Mayham7.3's Avatar
Mayham7.3
well iv been doing field ops for the past 4-5 months and haven’t had the chance to really figure out what’s going on with it . the temperature outside getting hotter everyday and when I started to drive it so has my wife she said it wasn’t getting as cold I filled by mass and pressure and I blew the lines out and everything completely
Old Jun 20, 2021 | 02:17 PM
  #126
FordTruckNoob
What do you mean “filled by mass AND pressure” and “blew the lines out”?
When filling by mass, you weigh the bottle of refrigerant as you fill the system and stop when the bottle is lighter by the mass of refrigerant specified for the system. If memory serves, ours calls for 42oz. It also calls foe 9oz of PAG 46 oil.
When you evacuate a system, you’re supposed to pull it down to as close to a perfect vacuum as possible.
Old Jun 20, 2021 | 02:26 PM
  #127
Mayham7.3's Avatar
Mayham7.3
What do you mean “filles by mass AND pressure” and “blew the lines out”?
it said 68oz of Freon to fill the ac system up so I got 6 12oz cans and the last can I used about half of it so it should have put me under 68oz by a little that’s what you mean by “mass” correct ? And “pressure“ I was checking the gauge set just to make sure I didn’t over charge the system. And “blew out the lines out “ I meant by flushing it . I took everything apart within the ac system and blew out all the lines and evaporators with my flush kit and air compressor
Old Jun 20, 2021 | 03:19 PM
  #128
FordTruckNoob
I forget your history. Is this for an Excursion with rear air? Did you purge the refrigerant supply line each time you swapped cans? Also, you cannot simply blow the system out with compressed air. You have to use a vacuum pump to evacuate it.
Old Jun 20, 2021 | 04:04 PM
  #129
Mayham7.3's Avatar
Mayham7.3
yes it does have rear ac . to be honest that didn’t even cross my mind to purge the air out In between can change and that’s what I used a vacuum pump to evacuate the system and I vacuumed it down for roughly two hours . I had to clean the lines and evaporators out cause the previous owner cut the compressor lines off and left the system open for over a year
Old Jun 26, 2021 | 05:28 PM
  #130
RA101725's Avatar
RA101725
Banned
So I should use one of these 38639 orifice tubes rather than the motorcraft one I just ordered this morning? (lol, oops)
https://www.rockauto.com/en/moreinfo...&pt=6936&jsn=3
Have Rock Auto sending me a new Motorcraft compressor/clutch assembly and accumulator. I took the old compressor out about a year and a half ago and put a bypass pulley on but need to get the A/C going again. I'm not going to bother buying the special tools needed to fix it myself one time so I will take the parts to a shop and let them do it but still am trying to get an idea what is going on. I did seal the lines going to the back of the compressor with rubber plugs and wrapped it tight with duct tape. Looks like a mess but it should have kept the crud out of. One part I don't understand is how to know how much oil to put in. Basically I am just replacing the compressor, accumulator and orifice tube. The condenser is newer (front end was wrecked and the whole cooling stack got replaced) and I assume the evaporator is the original one.
Old Jun 26, 2021 | 09:09 PM
  #131
SkySkiJason
Yes. No reason not to use the colder orifice tube.
I don’t know the scientific answer about the oil charge.
Old Jun 27, 2021 | 03:34 PM
  #132
RA101725's Avatar
RA101725
Banned
Looks like a Motorcraft part number YG-343 orifice tube for a 2001-2012 Ford Escape (among many others) that cross references with a "38639" tube?
https://www.partsgeek.com/ctxg24r-fo...=Ad+group+%231
https://www.ebay.com/itm/28425907343...0049#vi-ilComp
I guess this one has a smaller opening than the stock one?
Old Jun 27, 2021 | 07:01 PM
  #133
01__Excursion's Avatar
01__Excursion
The orifice diameter on the orange one will be smaller, it's designed for a smaller evap coil. Used in the larger Excursion evap coil, it in essence, is slightly starving the coil of refrigerant, therefore creating a greater drop in coil pressure and temperate, which also creates a risk of the coil freezing over because it's under saturated.
I tried it last year, didn't like it, took it out and installed the OE.
The smart VOV is available too, but I've never tried it.
https://aircondition.com/vov/benefit.htm
http://www.frostycool.com/standard-d...n-replacement/
Old Jun 27, 2021 | 07:20 PM
  #134
FordTruckNoob
I have one and it has been working well.
ACDelco 15-50120 Professional Air Conditioning Orifice Tube
Amazon Amazon
Old Jun 27, 2021 | 08:44 PM
  #135
RA101725's Avatar
RA101725
Banned
Okay I ordered one of those 15-50120 AC Delco's from Rock Auto. (That Amazon link said they didn't have them in stock right now). Quite a bit more expensive than the standard Motorcraft ones but if that's the ticket...I've got a standard YG-346 coming with the order also so I'll have an extra I guess. Thanks for the advisement on this one. If the performance is still inadequate after all this repair work ill look into adding the valve onto the heater hose but that can be added later obviously.
bigrig62
Jul 20, 2018 10:16 AM
fishdaddymoe
WTB - Parts & other
Sep 24, 2015 06:51 AM
Future_LEO
Oct 26, 2011 06:24 PM
wheelie31
Jun 20, 2010 10:36 PM
