thinking its time!
Old Apr 26, 2020 | 07:37 AM
  #121
SkySkiJason's Avatar
SkySkiJason
Good luck!!!! Fingers crossed this fixes you up!
There will always be smoke after injector swap because some oil usually gets in exhaust manifolds. Don’t freak out.
Old Apr 26, 2020 | 08:19 AM
  #122
Listor's Avatar
Listor
yep i know not worred yet, LOL i am definatly going to have to get the hpop leak down thing fixed!
Old Apr 26, 2020 | 10:41 AM
  #123
Listor's Avatar
Listor
Left to right 1357 , orings are shot lol
ordered my new cac boots an plenum boots this morning for when I get to the turbo rebuild
Old Apr 26, 2020 | 11:03 AM
  #124
SkySkiJason
That is really bizarre. Those are not OEM o-rings, so they’ve been replaced at some point.
I wonder if someone used some some kind of lube that caused them to deteriorate like that?? Hard to imagine something in the fuel or oil that caused that degradation... I guess they could have been damaged during install???
Thinking out loud, maybe some kind of cheap o-rings?? I’ve never used anything but Motorcraft. No idea what the ‘others’ look like.
Old Apr 26, 2020 | 11:26 AM
  #125
Listor's Avatar
Listor
I believe i got some contaminated Fuel a few weeks back, that's about the time thins thing started running different and then started smoking, Everything i am putting in here now is from riffraff, so i am sure they are the good stuff!
Old Apr 26, 2020 | 08:52 PM
  #126
Listor's Avatar
Listor
i have good news for my final update on this particular episode!
after i finished my o rings on my injectors, I took it on about a 30 mile trek out to my buds house, figured i needed a cold beer!
after about 15 miles at say 55ish, i decided to heck with it i punched it in the Accelerator and pushed to 80, smokin like a freak the whole time, LOL its either going to run out of oil or burn it off!
I get out by my friends house and take a left down his little dirt road and look back , I see nothing , I am not fogging the place up like i am killin mosquitos! I stopped and let it idol out, get out of the truck and just stand there watching the tailpipe, i am at this point wanting to pat myself on the back!
BUT i have let myself down before, I turn it off, let it sit for a few minutes , fire it back up , it cranked instantly! OMG i am happy!
Go on over to my buds house we are talking about all that i had to do had a cold one or 2 , and decide i better head home, get in turn the ignition, Fires right up , No long crank , no hesitation!
So i drive the ole girl home, i drove her like i just stole her , not taking it easy at all ! Figure if it breaks it was already broken! LOL
I get it home and tested a bit of a theory , Because before i would have to crank uncomfortably long to get her to fire, I had checked the hopo reservoir many time and there was amost nothing in there, ( leading me to believe the lpop was going out) Or the check valve has gone bad
I let it sit for 20 mins and come back and check the hpop it was full!
so in my conclusion because the o rings where not allowing the system to hold pressure it was allowing the hpop to bleed out not down but into the oil rail?
causing the long crank to build pressure?
i am so damned happy to have it fixed not sure if i care why it's working now, just seems interesting that it can bleed in that direction.
OK now don't go crazy and beat me up , but i would love to hear what you all think about this! LOL remember i just spent the better part of 2 days taking everything apart and putting it back together and it actually works!
it is reasonable that the hpop bleeding down cured itself with just fixing the injector o rings?
LOL or is that common knowledge that i just figured out
Btw there are so many of you guys to thank for your help , opinions and great advise! Jason, sous, Brandon, i'm sure there are others , thanks tons!
Old Apr 27, 2020 | 07:06 AM
  #127
SkySkiJason
Good work man!
I don’t have an explanation for the draining HPO reservoir. I’ll give that more thought while my coffee kicks in...
Old Apr 27, 2020 | 07:08 AM
  #128
Listor's Avatar
Listor
Good work man!
LOL good morning! I was thinking just a siphon effect?
I have not tried to start it yet this morning, i will here in a bit, can't hardly wait!
On another note i still get to rebuild the turbo! lol
Old Apr 27, 2020 | 08:05 AM
  #129
SkySkiJason
There is really nowhere for the oil to ‘go’ if it leaked past the injector o-rings.
Old Apr 27, 2020 | 09:30 AM
  #130
Listor's Avatar
Listor
i understand what you’re saying but there must be some reason for it right?
btw cold start this morning cycled the wts once fired up right away !! You are looking at a happy old man here!
Old Apr 27, 2020 | 10:23 AM
  #131
Bonanza35's Avatar
Bonanza35
Way to go. It always feels good when you fix something for the first time and it worked out great. This is know different. Except it is your daily driver. God bless,
Old Apr 27, 2020 | 01:38 PM
  #132
Listor's Avatar
Listor
i was a little nervous that it would take more the the weekend but if all worked out waiting for jy up pipe and boots so I can do the turbo
Old Apr 27, 2020 | 02:38 PM
  #133
Walleye Hunter's Avatar
Walleye Hunter
Does it make you feel like this?
Old Apr 27, 2020 | 03:00 PM
  #134
AubieTN's Avatar
AubieTN
Hunter, ya got too much time on your hands to have found that “dancer”. LOL!!
Old Apr 27, 2020 | 10:14 PM
  #135
Listor's Avatar
Listor
omg walleye that was great, and yes i was doing a little dance!
boots6868
Sep 2, 2011 09:17 PM
Jbrown8988
107
Jul 20, 2011 04:07 PM
onelionhunter
Jul 19, 2011 08:36 PM
4wheeling79
Oct 8, 2010 10:47 PM
wreckinball
Dec 15, 2009 12:06 AM
