thinking its time!
Old Apr 18, 2020 | 07:53 AM
  #76
SkySkiJason's Avatar
SkySkiJason
Originally Posted by Listor
wow that turbo looks like it ate a rock
Just dirty air. Teeny, tiny ‘rocks’ (dust).
Compressor wheel spins up to like 50k rpms. Any Impact = damage.
Old Apr 18, 2020 | 08:57 AM
  #77
Listor's Avatar
Listor
just some FORScan info
Adapter: ELM327 v1.5
Min.delay: 31 ms (Good)
Errors:
- CAN ERROR: 3 ( 3.4% )
Model: Ford F-Series Super Duty
Engine: Direct Injection - Turbo
Capacity: 7.3L
Generation: 2002 MY
Fuel type: Diesel
Transmission gear: Automatic
OBDII - On Board Diagnostic II
Bus: PWM
IC - Instrument Cluster
Bus: PWM
Part number: 2C3F-10849-HJ
Software version: 2001-06-15
Odometer: 396085.0 km
PCM - Powertrain Control Module
Bus: PWM
Part number: 2C3FDF
Strategy : TNAA7S3
Hardware type: DPC-462
Copyright Ford Motor Co. 2002
RCM - Restraint Control Module
Bus: ISO
Part number: 1C3ABD
Software version: v5
GEM - Generic Electronic Module
Bus: ISO
Part number: 2C3T-14B205-AA
Software version: v1
ABS - Antilock braking system
Bus: ISO
Part number: 2C34-2C346-BE
Software version: v3
Old Apr 18, 2020 | 08:58 AM
  #78
Listor's Avatar
Listor
===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC===
===IC DTC ===
Module: Instrument Cluster
===END IC DTC===
===PCM DTC P1280===
Code: P1280 - Injector Control Pressure Failure
Module: Powertrain Control Module
Diagnostic Trouble Code details
Injector Control Pressure (ICP) circuit out of range low.
--Possible Causes--
- Open or grounded ICP circuit.
- Open VREF circuit.
- Damaged ICP sensor.
- Damaged PCM.
===END PCM DTC===
===PCM DTC P0478===
Code: P0478 - Exhaust pressure control valve malfunction
Exhaust pressure control valve high input.
--Possible Causes--
- Plugged EBP sensor line.
- Stuck butterfly.
- Restricted exhaust.
- Misadjusted EPR linkage.
- Damaged EPR.
- Damaged PCM.
===END PCM DTC===
===PCM DTC P1212===
Code: P1212 - Injector Control Pressure Lower Than Desired (engine crank or run)
This DTC may be caused by :
No ICP detected during cranking
Possible causes are:
An incorrect oil level
High pressure oil pump
ICP Sensor
Injector Control Pressure Regulator
Follow the routines in the service manual to resolve the DTC listed.
Note: This DTC may set after a high pressure oil system repair. Drive the vehicle to clear the air from the system after completing the repair and clear the DTC.
===END PCM DTC===
===PCM DTC P0470===
Code: P0470 - Exhaust Back Pressure sensor circuit malfunction
Exhaust Back Pressure (EBP) sensor circuit malfunction.
--Possible Causes--
- Open signal return.
- Damaged EBP Sensor.
- Damaged PCM.
===END PCM DTC===
===PCM DTC P1211===
Code: P1211 - Injector Control Pressure Higher/Lower Than Desired (engine running)
Low fuel pressure.
Poor oil quality
High pressure oil system leak
ICP Sensor
===END PCM DTC===
===RCM DTC ===
Module: Restraint Control Module
===END RCM DTC===
===GEM DTC B1359===
Code: B1359 - Ignition run / accessory circuit failure
Module: Generic Electronic Module
===END GEM DTC===
===ABS DTC ===
Module: Antilock braking system
===END ABS DTC===
Old Apr 18, 2020 | 11:30 AM
  #79
Listor's Avatar
Listor
I was going to take off the down pipe and this is what I see before I even get started
Looking up to the turbo
think theres a problem?!?!
Code: P0266 - Cylinder #2 Contribution/Balance
Internal engine components
Fuel Injector
Valve train assembly
Compression rings
Refer to the vehicle Powertrain Control/Emissions Diagnosis (PC/ED) Manual for specific diagnostic steps.
Note: The A/C must be off when carrying out the KOER cylinder contribution test.
Old Apr 18, 2020 | 12:43 PM
  #80
Walleye Hunter's Avatar
Walleye Hunter
Have you given it the cap on the oil fill tube blowby test yet?
Old Apr 18, 2020 | 12:49 PM
  #81
Listor's Avatar
Listor
i have done that in the past but not recently, just did the blow by test none present
Old Apr 18, 2020 | 01:02 PM
  #82
SkySkiJason
I don’t have a good explanation for all that oil at up-pipes.
What are perdels? No.2 is appears to have an issue.
Old Apr 18, 2020 | 01:42 PM
  #83
Listor's Avatar
Listor
I can see oil running all the way down from the turbo, I could not the Perdels to respond but the cylinder contribution test showed me #2 was having an issue, not sure what that means
Old Apr 18, 2020 | 02:11 PM
  #84
Listor's Avatar
Listor
So I am going to still pull the down pipe but what does it mean that there is oil on both of my up pipes drivers side is much worse, are my injectors leaking so much oil that it’s pulling it into the turbo? Head gaskets ?
Old Apr 18, 2020 | 02:48 PM
  #85
Bonanza35's Avatar
Bonanza35
More like a turbo seal then injectors. Also check the plugs on the back of the heads to see if they are leaking. No oil in the valley?
Old Apr 18, 2020 | 03:38 PM
  #86
Listor's Avatar
Listor
No oil in valley no leaks anywhere
No oil in the down pipe some caking, plugs are good
Old Apr 18, 2020 | 05:40 PM
  #87
Walleye Hunter
You got a good one here.
Old Apr 18, 2020 | 06:19 PM
  #88
SkySkiJason
Something is up with cylinder 2.
You can try swapping 2&4 injectors and see if problem moves to 4.
Might see something obvious when pulling injectors.
Old Apr 18, 2020 | 08:33 PM
  #89
Listor's Avatar
Listor
i am at a loss as to what to do, i see oil coming down from the y on the up pipes , but nothing really distinctive in the down pipe, Now i have #2 showing issues , i am shaking my head, to confusing to consider tonight gonna sleep on it
Old Apr 19, 2020 | 06:04 AM
  #90
Listor's Avatar
Listor
well good morning, after sleeping on it, think i am going to crack open the passenger valve cover and see what i can see
Hoping just a loose connection
ordering a rebuild kit for my turbo too
Your Cart (4 items)
Item Price Quantity Total Riffraff Diesel
RDP Plenum Reinforcing Inserts™ 99.5-03
Part Number:RDPPRI $29.86Decrease Quantity: Increase Quantity: $29.86 Riffraff Diesel
GTP38 360º Bearing Rebuild Kit 99-03
Part Number:RDPGTP-360 $59.3ecrease Quantity: Increase Quantity: $59.38 Garrett
Garrett GTP38 Turbine Wheel / Shaft Assembly
Part Number:445604-0601 $178.67Decrease Quantity: Increase Quantity: $178.67 Riffraff Diesel
Intercooler Boot Complete Clamp Kit 7.3L 99-03
Part Number:B005-7.3-L99-03Model Year:Late 99-03Change $47.99Decrease Quantity: Increase Quantity: $47.99
hope this is all i need!
