thinking its time!
Old Apr 15, 2020 | 07:30 AM
SkySkiJason's Avatar
SkySkiJason
I’m not sure lpop is going to solve your problem. It is not responsible for keeping oil in the HPO reservoir. The only thing you need to remove is the belt so you can pull harmonic balancer and lpop. You can ‘rent’ harmonic balancer puller/installer at the autoparts store.
I would almost never change a water pump as PM. Water pump is a 45min job and basically is never a catastrophic failure, giving lots of notice it needs attention (leaks).
There is a check valve in the front of the valley and another in the oil cooler that prevent oil from draining out of the reservoir.
Can someone post a pic of the lpo routing diagram??
If you are leaking that much oil, is be inclined to fix that first. Most oil leaks are cheap and easy to fix. I would also replace up-pipes if removing turbo. See my thread about up-pipe replacement for tips on removing turbo/up-pipes and how to DIY delete EBPV.
Old Apr 15, 2020 | 09:19 AM
Listor's Avatar
Listor
I hear what your saying , I wish I was leaking oil , I am burning at it at an alarming rate! I am hoping that I can get away with orings on the injectors, I will check out the check valves you pointed out, daily driver so have to do things in stages, Sous actually posted a link earlier that showed somebody else with the L pop so I think that had a diagram and I still got that link saved, Any suggestions for a reliable rebuilt injectors
Old Apr 15, 2020 | 09:25 AM
SkySkiJason
Burning oil ‘at an alarming rate’ with no blow-by is likely injector internals or maybe failing turbo.
If you dont find obvious failed injector o-rings - I would not waste the $$ on new o-rings.
Old Apr 15, 2020 | 09:43 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Here is the only oil flow diagram I can recall at this time. It can be found in the 7.3L PSD Tech Folder for future reference.
Old Apr 15, 2020 | 11:56 AM
SkySkiJason
Perfect Sous!
I think the ‘short circuit valve’ as it is labeled here can cause leak down on SuperDuty trucks.
Old Apr 15, 2020 | 12:56 PM
Brother Les's Avatar
Brother Les
"Burning oil at an alarming rate"....
What does your smoke look like when the truck is running at the tail pipe?
Old Apr 15, 2020 | 01:55 PM
Listor's Avatar
Listor
looks white smoke and smells like oil, tried to attach a little video but not working from my phone
Old Apr 16, 2020 | 07:00 AM
Listor's Avatar
Listor
only one way to find out , going to have to get in there and start looking at things!
Old Apr 16, 2020 | 07:09 AM
Listor's Avatar
Listor
Ok folks i need to clarify a few things, reading over the post seems i'm a little scattered, I had planned on rebuilding the fuel bow , grabbed a few other items to have just in case scenario.
then the ole girl start puffing some smoke, i wasn't to concerned , figured turbo pedestal or maybe injector rings , 248k things wear out.
Now she is burning oil as i said at an alarming rate, put 2 gallons in her yesterday, yes 2 gallons! no leaks any where, all going out the exhaust!
so all i need to do is stop the insanity, been working my tail off trying to finish a couple jobs and worried about this thing leaving me stranded has got me a little stressed!
so can a bad turbo burn that much oil, if so what do i need to do, can i rebuild it, or do i get another?
lol help me help myself i can do the work just don't want to be throwing parts at it!
Old Apr 16, 2020 | 07:37 AM
SkySkiJason
Have you checked turbo shaft for play???
Yes, it can literally dump liquid oil into the downpipe and smoke out small villages. Usually smoke is BAD after idling at red light and not so visible while driving under load.
Old Apr 16, 2020 | 08:53 AM
Listor's Avatar
Listor
I was going to ask if a bad turbo would smoke at idle, that is exactly what is going on , smokes bad at start up , driving not so bad the while idling smoke gets increasingly worse, need to deal with this pronto, can I rebuild it if there is no shaft play?
Old Apr 16, 2020 | 09:24 AM
Dan V's Avatar
Dan V
Unless the compressor wheel has contacted, and damaged either/both the housing and wheel, when you get the rebuild kit you will get new shaft seals, bearings and thrust bearing...and some install o-rings. Should fix you right up.
Old Apr 16, 2020 | 11:54 AM
  #28
SkySkiJason
There will almost certainly be shaft play if that’s what’s causing your smoke. Like Dan said, if the wheels have contacted the housings you will need another turbo.
Old Apr 16, 2020 | 12:33 PM
  #29
RA101725's Avatar
RA101725
Banned
I’d pull the hot side intercooler pipe off and see what kind of mess there is in there. My original turbo was starting to leak oil pretty badly into the compressor side. Hot side into the downpipe wasn’t quite as bad if recall correctly but I know the piston ring on the hot side had very little tension left in it and putting the new one on seemed to clean up the exhaust and cut oil consumption a small amount. There is quite a bit of oil that can be lost in that area with the upper and lower pedestal seals, EBPV actuator, and all the internal turbo seals.
Old Apr 16, 2020 | 02:15 PM
  #30
Listor's Avatar
Listor
Thanks everyone for your help, I will pull the turbo tubes off tonight so I can see what’s up, truck is running fine otherwise
File Type: mov
