Paint Issues
Old Feb 27, 2020 | 11:54 AM
  #91
rwilimo's Avatar
rwilimo
I used to get that on my 04 White, I had very good luck with a clay bar also
Old Feb 27, 2020 | 01:46 PM
  #92
Vautti's Avatar
Vautti
Thanks for the tips!
Old Feb 27, 2020 | 05:29 PM
  #93
6.2caribou's Avatar
6.2caribou
I found YouTube videos recommending ArmorAll Ultra Shine Spray Wash to keep the truck surface wet while using a clay bar. It works great. Can't find it locally so I order it from Amazon.
Old Feb 27, 2020 | 06:00 PM
  #94
ForCal's Avatar
ForCal
Yes, Clay requires a lube, that can be any number of clay lubes, detail sprays, wash mix etc. Clay bars are abrasive to a greater or lesser degree, depending on the clay used. It is understood that it can, and usually will mar the paint. Experienced detailers expect to polish after use.
Old Feb 27, 2020 | 06:03 PM
  #95
Icelink's Avatar
Icelink
Originally Posted by Vautti
Pictures I posted show the "rail dust." Salesman at our local parts store also knew about it and recommended a wheel cleaner (without any acid). I tried that as well and had no luck removing it at home. I suspect that I will need to use something with a mild acid, but I will let the pros clean it the first time. It has also been pretty sloppy driving up here, so I am not in a great hurry as long as there is no long term damage. Kind of freaky though when you see it on an aluminum panel!
Is this not a warranty issue?
Old Feb 27, 2020 | 08:28 PM
  #96
JHForman812's Avatar
JHForman812
look at car pro iron x for removing the spots
Old Feb 28, 2020 | 07:40 AM
  #97
Vautti's Avatar
Vautti
The Ford body shop will take care of this as my truck only has 32,000 mi. I also don't want to have to run back to the dealer every time I get these spots. Don't mind using a little elbow grease on my truck. Thanks, Vautti
Old Feb 28, 2020 | 07:43 AM
  #98
Vautti's Avatar
Vautti
Yes, and I will have them clean it up this time. I just think that it may reoccur in the winter with all the chloride on our roads. Thanks,
Old Feb 28, 2020 | 07:52 AM
  #99
Ding126's Avatar
Ding126
I see cars being transported by truck which just came from the rail yard. These cars are covered in white plastic to protect the finish during transport. I guess Ford doesn't take these precautions. WTH?
Thanks for the heads up,
JOB 1
Old Feb 28, 2020 | 08:07 AM
  #100
Vautti's Avatar
Vautti
Actually, I bought this truck used with 25,000 mi, and it was spotless. I kept it that way until mid winter when the rail dust showed up. The body shop guy say that it is caused by the material coming off the truck rotors (and probably mixing with the road salt, as it didn't appear in the summer). I will ask them how long I can expect this to continue and post that info. Problem is that I use my truck every day, and they work when I work. Thanks, Vautti
Old May 11, 2020 | 01:11 PM
  #101
bmbl-bee's Avatar
bmbl-bee
worth another look.
Curated Content Editor
Paint & Bodywork
Dec 27, 2019 03:14 PM
madcap78
Oct 9, 2017 10:41 AM
