7.3 no start
Old Dec 8, 2019 | 01:52 PM
AllaboutMPG's Avatar
AllaboutMPG
Go down to page 2 of the following link. It's the Tech Folder found at the top of this forums list. Look under Misc Information & Modifications and click on PSD Diagnosis On The Cheap -
https://www.ford-trucks.com/forums/1...-7-3l-psd.html
Old Dec 8, 2019 | 01:54 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by rjdj1186
I am not familiar with any scanner, which would you recommend?
I just answered a similar question on the Excursion forum.
https://www.ford-trucks.com/forums/1...look-like.html
Torque Pro is a good program to use as well, but it can be much more picky and "sensitive". Forscan is not pretty to look at, but very reliable.
Old Dec 8, 2019 | 02:05 PM
rjdj1186's Avatar
rjdj1186
I will check it out, go to town tomorrow and get what I need, then let you know what it says. I will get an oem cps, too. (All the abbreviations on these forums just kill me.) I appreciate your advice. Please tune in tomorrow for the next episode...
Old Dec 8, 2019 | 02:14 PM
Sous's Avatar
Sous
FTE Emeritus
There is a list of abbreviations, acronyms and terms at the link below. It is not 100%, but it is fairly good resource.
https://www.ford-trucks.com/forums/1...tml#post645203
Old Dec 8, 2019 | 02:27 PM
rjdj1186's Avatar
rjdj1186
That is the most usefull information I have yet received on a truck forum! This should be an attachment to every thread! It's the english-greasemonkey dictionary! I love it! This would have saved me hours of google searches when I was truck shopping.
Old Dec 8, 2019 | 02:34 PM
Sous's Avatar
Sous
FTE Emeritus
Coincidentally, it is included in the 7.3L PSD Tech Folder which is a sticky thread at the top of this sub-forum.
Old Dec 8, 2019 | 02:51 PM
rjdj1186's Avatar
rjdj1186
Having learned many abbreviations in my seemingly endless search for a diesel truck, I find that knowing and using them makes me feel like I actually know something about it, when in fact I am just as clueless as ever! Most of the things I can name in a truck I would not recognise if you handed them to me, nor be able to find under the hood. But I can throw out 3-letter combos like a pro!
Old Dec 8, 2019 | 03:18 PM
rjdj1186's Avatar
rjdj1186
Is there a way to test the cps? It is a 3 wire connection, magnet switch. Can I run a continuity test on the sensor circuit and trigger it with metal or a magnet to see if is functional?
Old Dec 8, 2019 | 04:29 PM
Walleye Hunter's Avatar
Walleye Hunter
Originally Posted by AllaboutMPG
Does anyone remember is it the early models or later models that don't get tach movement during cranking???
Later models but I'm not sure how late.
I do not have a scanner, but will need one sooner or later if not now. Trying to get some input before I make the 2 hour trip to the dealership. Will likely get a scanner while in town.
Avoid dealer at all costs, more often than not it's a costly mistake.
Old Dec 8, 2019 | 04:32 PM
Walleye Hunter
I had a particularly hard time with the acronyms but now I can visualize the part by it. I have to think hard about what it stands for but I know what part is being referenced instantly.
Old Dec 9, 2019 | 01:10 PM
sunuvabug's Avatar
sunuvabug
My 2001 has a build date of 12/00 and the tachometer does not move while cranking.
Old Dec 10, 2019 | 11:34 AM
rjdj1186's Avatar
rjdj1186
So... I got a cheap plug-in non bluetooth code reader, as I could not find any bluetooth in my small town. It says it is powered by the vehicle, but it does not turn on when I plug it in. Any suggestions? Is there a fuse for that?
Old Dec 10, 2019 | 11:58 AM
  #28
rjdj1186's Avatar
rjdj1186
Nevermind, found the fuse. #12, 20amp.
Code reader says no codes stored. Truck still almost starts but not quite.
Old Dec 10, 2019 | 02:21 PM
  #29
rjdj1186's Avatar
rjdj1186
My research suggests that there are many possible causes for my power loss turned no-start. Do any of you guys (or gals) know which of the possibilities would not cause any codes?
Or perhaps I need a different code reader. I have read some don't work with these trucks, for some reason.
I am about to go try to climb my old, damaged *** on top of that rediculously hard to reach engine to find and remove the ipv (injection pressure valve, I believe) to clean it and check the solenoid. I would welcome any suggestions, as I am just making a barely educated guess, now.
Thanks.
Old Dec 10, 2019 | 03:29 PM
  #30
rjdj1186's Avatar
rjdj1186
I removed my fuel filter, thinking I might need to remove the fuel bowl to get to that ipv, and found some rusty black gritty sludge on the bottom of my fuel bowl. Is that normal?
