AC Refrigerant Booster Testing
Old Jul 29, 2020 | 03:28 PM
  #61
electryc_monk's Avatar
electryc_monk
Veteran: Navy
Hey Sous, I wonder what the addition of the foam wrap like I've been using for years would do to your math? Either close cell or open cell foam?
I'll be finding a thermometer soon and start to log my temps for comparison as raw data as well. North DFW area with many 100°+ days in a dark green crewcab with worn old tint that needs replacing (original owners installed)
Disclaimer:
A) my condenser has not been cleaned yet
B) EVAP fins need combing again
C) system *feels like* it is running really close to 100% oem AFAIK (kiddos sitting in rear with A/C max for 20+ minutes while I'm in Kroger they turn the fan down to 2 and the temp **** nearly into the red when its upper 90's afternoon & no shade)
D) the foam was installed 3 yrs ago when I got the truck
Old Jul 29, 2020 | 04:48 PM
  #62
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@electryc_monk , can you expand your thought and explanation of the foam wrap? My brain is telling me that I vaguely remember this, but I have slept and drank quite a bit of beer since then... I am open for trying all sorts of voodoo tricks to keep the AC performing well. A friend of mine is going to hook up his manifold and gauges to it when we visit next year, just to see where the pressures are at.
Did you see where I installed 99% UV blocking on my windshield that is nearly clear to the eye? That helped my in cab temperatures tremendously. We were so impressed with the performance of the tint on the truck windshield that we just had the same tint installed on our new to us 2016 Ford Escape. In the truck, in 100* heat with no clouds, you can put your hand on the dark part of the dash bezel and it is only slightly warmer than putting your hand on your arm or leg. It is amazing how well it works.
I just bought an IR gun, no idea why I haven't had one before. Even after 7 years of traveling long distance towing a camper...
Old Jul 30, 2020 | 01:06 AM
  #63
electryc_monk
Veteran: Navy
Geez that was difficult via my Android phone in Firefox browser.... Anywho.... Here's the link Sous:
https://www.ford-trucks.com/forums/1...-thread-2.html
Post #28 is the pictures on the foam wrapped a/c line. For what it worth, I'm planning to get a new section of foam as the current one is starting to disintegrate.
As for the window tint, DUDE! I want to know all the details as I have been re-reseaching that stuff. It came out about 15 years ago but, I lost track of it & last summer finally re-ran across some stuff that's only at 80% IR reflection & it had ~80-85% light transmission so it's not "clear" as your stuff you found for the front windshield. I sooooo wanna do that!
I have a couple IR/laser thermometers, their accuracy isn't as precise as my original was - before it broke. And they don't register as high either. What's your brand & max temp you can see?
I can try to upload a pic of mine but, no guarantee that I can upload tomorrow as our DSL has been horrendous the last 4 weeks.
Old Jul 30, 2020 | 10:36 PM
  #64
kbeefy's Avatar
kbeefy
I need to get some UV tint.
Sous, just checking pressures is pretty vague with r134. It can help pinpoint restrictions and failures, but isn't great at measuring.
R134 has the same static pressure at .5# as it does at 3.5#. Think of it like propane... liquid to gas phase shift etc.
The only way to accurately measure it is to recovery it and weigh it. Anything else is guesing.
From your description yours has been working but just not great. I assume it has just lost a bit of refrigerant over the years.
If you don't have a friend with a recovery machine, pay someone to do it. My recovery machine cost $5500, it's not something many people just have in their garage.
I charge $100 (an hour of labor) plus Refrigerant for a recovery, vacuum and recharge. $150 if it needs a pressure check.
Even a good system will loose 1/2# over 5 years, no compressor seals are perfect.
I would definately do it before adding the booster, the booster would probably be lost during the recovery process.
Old Jul 31, 2020 | 09:53 PM
  #65
RacinJasonWV's Avatar
RacinJasonWV
Sooo how bad would we be to just add 1 or 2 # to the system blindly? 20 years / 5 years x 0.5# = 2
I mean if they’re known to leak off and the system is 20 years old then wouldn’t just a little be ok? Not saying go crazy with it.
I don’t know any reputable AC place in our area but do have some R134 on the shelf....
Old Jul 31, 2020 | 11:04 PM
  #66
kbeefy's Avatar
kbeefy
Crap. The forum just ate a half page response.
Maybe I should have said COULD instead of WILL.
Your better going to a lube shop or a not reputable shop for AC service than just guessing and dumping R134 wherever.
Read about pressure charts (you need an AC manifold and guages to do anything) and start at static, cold pressure.
Underhood temps running will make your pressures useless.
Old Aug 1, 2020 | 06:57 AM
  #67
RacinJasonWV
Thank you for the reply and tips. And yes I hate it when the forum does that!
Believe I may have access to some gauges. I’m assuming the simple one (that I have) that just goes with the can on the low side isn’t good enough and I’ll need to read pressures on both sides.
Problem is mine still works, just not very well when really hot. Truly think it just needs a little recharge. But I’m a leary of letting someone I don’t trust mess with a 20 year old system that’s currently functioning.
I may do some digging to understand the charts you’re talking about and give it a swing if my uncle has the manifold gauges.
Now I’ll hush up so as not to de-rail Noob’s additive thread.
Old Aug 5, 2020 | 09:32 AM
  #68
sjbj's Avatar
sjbj
Originally Posted by jstihl
https://www.ebay.com/itm/254344233223
I was able to get these guys down to $20.00 on ebay but still have to wait a while for it to arrive since its coming from Italy. Just figured I would share since its a little cheaper. Looking forward to giving it a try, thanks for the heads up on this product FordTruckNoob 👍
I'm sure they will deny my offer of $20, but I didn't see where it listed the size of fitting used or sent with the kit?
Old Aug 5, 2020 | 10:03 AM
  #69
FordTruckNoob's Avatar
FordTruckNoob
It's a 13mm R134a port if memory serves. This is the adapter.
Old Aug 5, 2020 | 11:34 AM
  #70
jstihl's Avatar
jstihl
I was under the impression that the coolshot ultra came with the adapter. No?
Old Aug 5, 2020 | 11:38 AM
  #71
FordTruckNoob
Not always and if it does, not always the right one. When purchased directly from Errecom, they were ordered as separate line items.
Old Aug 5, 2020 | 11:42 AM
  #72
jstihl's Avatar
jstihl
Not always and if it does, not always the ight one. When purchased directly from Errecom, they were ordered as separate line items.
10-4 thanks for the heads up on the correct size, ill check it out when it comes in
Old Aug 5, 2020 | 11:49 AM
  #73
FordTruckNoob
My pleasure!
Old Aug 12, 2020 | 04:00 PM
  #74
jstihl's Avatar
jstihl
My pleasure!
Hey FTN, I got my cool shot ultra in today and it has a adapter for r134a but not sure its the right size yet. Will post back to confirm. My question is do you use the entire tube? It has a chart on the instructions but I am not that familiar with A/C systems and what capacity our system is. Thanks for any help
Old Aug 12, 2020 | 04:06 PM
  #75
Sous's Avatar
Sous
FTE Emeritus
I used the entire tube, discarded the instructions... Like I do with most anything until I break it, then I find the instructions in the trash and read them...
