AC Refrigerant Booster Testing
Old Aug 9, 2021 | 09:11 PM
  #181
uglypitbull's Avatar
uglypitbull
Where do I sign up? Between AZ and UT....I could use all the help I can get.
Old Aug 10, 2021 | 06:29 AM
  #182
SkySkiJason's Avatar
SkySkiJason
Shoot me a PM or text if ya have my number.
I recommend changing to a 38639 orifice tube and removing and cleaning the evaporator core while system is discharged. The heater core supply shut off valve is also highly recommended.
Old Aug 10, 2021 | 03:41 PM
  #183
uglypitbull
Will do...I have no idea what that is, but I will look into it since I am taking it in to a shop for that.
I already bought the shutoff valve.....I can do that myself though. I put the Dieselsite version on my old Excursion....wasnt too impressed with that one, and didnt like that it had to be on Max to work.
Old Aug 10, 2021 | 04:51 PM
  #184
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I too bought and later removed the Diesel Site AC assist as I was unimpressed.
The evaporator coil/core can be cleaned easily by following the video I made and pasted below. Other FTE'rs (credit given in the video) were before me, but I felt a video would be better suited for following along.
Just so we are clear, I have monetization turned OFF on all of my videos. Although, a new YouTube policy allows them to insert ads for their own profit as they see fit.
Old Aug 10, 2021 | 05:47 PM
  #185
Bonanza35's Avatar
Bonanza35
If you tie into the red line it does not have to be on max to work. Robin posted this years back.
Old Aug 11, 2021 | 07:29 AM
  #186
SkySkiJason
Its still typically plumbed into the return line and it does not STOP the flow of coolant (heater core is still warm). It’s also a known failure point with a limited lifespan.
I close my manual valve in late spring when I stop using HEAT and open it on the first fall morning when I’m chilly. It’s not any more effort than checking the oil.
Old Apr 13, 2022 | 02:10 PM
  #187
mello3's Avatar
mello3
So are people still using this Cool Shot Ultra.....and do you still like the results?
Old Apr 13, 2022 | 02:17 PM
  #188
FordTruckNoob's Avatar
FordTruckNoob
I have not done anything to my AC system since injecting CoolShot in August 2019 and it still cools very well.
Old Apr 13, 2022 | 02:35 PM
  #189
jstihl's Avatar
jstihl
The cool shot and ball valve mod has worked well for me.
Old Apr 13, 2022 | 03:31 PM
  #190
Sous's Avatar
Sous
FTE Emeritus
Same answer from me as the two fellas above posted.
Old Apr 13, 2022 | 05:55 PM
  #191
helifixer's Avatar
helifixer
on my '97 I am pretty sure my evap is clogged with lint, dust leaves and what ever else can get in there as high on the fan feels like medium or low, but dang it is cold.
on my 2000 excursion huge difference cooling that monster.
haven't driven my parents '97 since the new compressor and the cold shot but my mom says it gets too cold.
haven't done the 2019 F450 yet, was waiting to get some miles on the others for my own sanity of weather it works or not or if it grenades the system. probably put it in this year when I see the box on my shelf and remember to do it.
Old Apr 13, 2022 | 06:39 PM
  #192
mello3's Avatar
mello3
Thanks for all the replies.
Was thinking about ordering some off of Ebay....but just wanted to get an update of what everyone currently thinks about it.
Old Apr 13, 2022 | 07:30 PM
  #193
helifixer's Avatar
helifixer
there might be a few guys here on this thread that still have some. I would wait a few days to order it! someone might hook you up.
Old Apr 13, 2022 | 08:04 PM
  #194
Wes444's Avatar
Wes444
Ball valve mod and cool shot here. Quite cold while towing heavy in summer
Old Apr 14, 2022 | 07:15 AM
  #195
SkySkiJason
I have a couple left from bulk order. Will share the discount I got for anyone wanting some of this.
