Another cellphone mount option
Old Jan 25, 2021 | 04:31 PM
  #91
OffRoadRN's Avatar
OffRoadRN
Originally Posted by ATC Crazy
I doubt it. In order for it to work with your phone, the USB would have to be wired into the SYNC/radio harness. I believe the USB's you are seeing in this thread are just straight 12V power for charging purposes only.
I wonder how hard it would be to relocate the USB that has the data connection to the sync 3 unit to the location OP has his charging, and then put a regular 12 volt charging outlet in place of the OEM sync 3 hookup.
Old Jan 25, 2021 | 05:25 PM
  #92
MKrenn's Avatar
MKrenn
WeatherTech CupFone
The best!
Old Jan 25, 2021 | 06:24 PM
  #93
Section179's Avatar
Section179
Originally Posted by OffRoadRN
Do any of those USB ports work for carplay/andoid auto?
This is discussed at length earlier in this thread around post 69. As others have stated ports will not work unless you push the ports through your center console and get an extension cable, which I ultimately did. Some recommended parts around post 69.
you could also potentially relocate the entire set of USB ports but I chose not to. One goes to my center tray and the other goes by cable to my left mount for my cellphone, which I use most often.
Old Jan 25, 2021 | 06:39 PM
  #94
OffRoadRN's Avatar
OffRoadRN
Thanks! I skimmed the thread but must have missed that, thank you for pointing me in the right direction.
Old Apr 6, 2021 | 12:02 PM
  #95
speakerfritz's Avatar
speakerfritz
Originally Posted by tortue71
What's the point of all these phone holder ?
so true and not true.
I dont need a phone to make calls , nav, texts, etc since it all can be done thru the ford software.
but, sometimes i need to see forscan or ODBII wiz bang software and having a mount to monitor select guages at eye level make it easy.
my goal is to mount a mini ipad for select guage use.
THOM/CJ KR 350
Mar 22, 2022 05:43 PM
bobf350
Jul 20, 2019 10:05 PM
Amicus
Apr 30, 2017 11:34 PM
Yama4fitty
Apr 22, 2017 06:49 PM
Popeyedc65
Apr 13, 2017 06:05 AM
