Another cellphone mount option
Old Apr 22, 2019 | 07:33 PM
Section179's Avatar
Section179
Figured I’d throw this out there. Did some truck work this weekend and got around to a left hand mount for my cellphone. I had the idea a few months back and had the parts but only got around to truck projects this weekend.
Ram makes bolt through ***** designed for motorcycle triple clamps. If you remove the Jesus-handle bolts they are M6x1.00. Bought a longer bolt and a few washers and walla! No-cut A-pillar ram mount.
This is a wireless charger with a lightning cable hanging below going back to the center console for when I want to use CarPlay. For anyone interested in CarPlay all the time I’d highly recommend the Proclip phone holder. If you want to plug in to CarPlay every time their phone holder can’t be beat. The built right bracket and this ram mount I’m showing are better than the Proclip mount, but their holder can’t be beat.
And in case anyone was wondering about the other location....
Old Apr 22, 2019 | 08:45 PM
Concretecut's Avatar
Concretecut
For the oh crap handle I am assuming a b ball. How long of an arm to clear dash?
Old Apr 22, 2019 | 09:00 PM
Section179's Avatar
Section179
Old Apr 23, 2019 | 09:34 AM
RoversCMR's Avatar
RoversCMR
Trailering
Like your power point setup in the center dash tray, haven't done mine yet. Is there plenty of clearance below the tray for the wiring? Would you provide links to the power points you used? Thanks.
Old Apr 23, 2019 | 02:14 PM
Section179's Avatar
Section179
usb:
https://www.amazon.com/gp/aw/d/B07LCBKZSG?psc=1&ref=ppx_pop_mob_b_asin_title https://www.amazon.com/gp/aw/d/B07LCBKZSG?psc=1&ref=ppx_pop_mob_b_asin_title
note - I disassembled and removed the lcd so it wouldn’t shine light on the dash. I would consider just doing cigarette liter sockets and using plug in adapters - that’s worked fine.
cigarette plugs:
https://www.amazon.com/gp/aw/d/B0772D9915?psc=1&ref=ppx_pop_mob_b_asin_title https://www.amazon.com/gp/aw/d/B0772D9915?psc=1&ref=ppx_pop_mob_b_asin_title
they are lighted, but the light is blocked with the cover or when something is plugged in, so has not been an issue. I’d also consider finding one that isn’t lighted instead.
There is room but not a ton. You will need to put the ports all of the way to the back to clear the metal brace in the picture. If you want breathing room, consider just two ports instead of three.
Old Apr 23, 2019 | 03:40 PM
RIPbiker13's Avatar
RIPbiker13
Great write up and thank you for the links. I'm saving these and will look into them in the VERY near future. I was hoping to find something like this.
Where do you obtain the M6x1.00 bolt and when you say "longer," how much longer?
Old Apr 23, 2019 | 05:47 PM
RoversCMR's Avatar
RoversCMR
Trailering
Section179, Thanks for the links and the underside pictures, that helped a lot.
Any chance you remember which fuse you tied into?
Old Apr 23, 2019 | 05:54 PM
Section179's Avatar
Section179
Lowes, 35mm. You could get a couple sizes depending on how many washers you plan to stack.
https://m.lowes.com/pd/Hillman-6mm-1...ount/999994920
I tied into the heated steering wheel fuse (switched to ignition) with an add-a-fuse. Can’t remember which # - it’s in the manual. Folks on the forum without heated steering wheel have reported the fuse is there anyway.
Old Apr 24, 2019 | 10:43 PM
Eweezy01's Avatar
Eweezy01
Use a magnetic mount
Still works for wireless charging
Ran a USB cable from the front storage drawer, through and into center console. Sliding door always stays closed now. Android auto. All the time!
Old Apr 25, 2019 | 01:47 PM
Sarge261's Avatar
Sarge261
What mount and radar detector are you using, that's a clean set up.
Sarge
Old Apr 25, 2019 | 02:21 PM
Section179's Avatar
Section179
Sarge
Thats a Uniden R3 with a poorman’s blend mount (blend mount is the premium mirror mount... that’s a knock-off available here):
https://www.amazon.com/gp/product/B0788XRBTV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0788XRBTV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I just swapped the Uniden out for the newly released Uniden R7 which has a few more features. The R3 and R7 are the most sensitive (long range) detectors on the market. They are not as user friendly though as some other units like the escort max360c. After fumbling through the learning curve and figuring out what was common in my area I’m really in love with the Uniden. It gives me fantastic advanced warning.
They’re not cheap unfortunately.
Old Apr 26, 2019 | 09:11 AM
Sarge261's Avatar
Sarge261
I have an old passport 3 Ive been using for years and was thinking about an upgrade. Not that I drive fast as I usually have the 5th wheel in tow.
Sarge
Old Apr 26, 2019 | 10:28 AM
Section179's Avatar
Section179
Sarge
I’m not all that fast but I really value an early warning. The Uniden r3 that just had a price drop with the introduction of the r7 is a great detector. I’d recommend filtering k and x band and using it for Ka, laser, and stoplight cams.
Old Dec 24, 2019 | 11:44 AM
daletodd2's Avatar
daletodd2
reviving this thread cuz I'm copying your set up just ordered all the supplies
Old Jan 7, 2020 | 06:19 PM
daletodd2's Avatar
daletodd2
Made some progress on this today. Bought the wrong add a fuse though. I thought I needed mini but they are all micro .😪
