Another cellphone mount option
Old Feb 17, 2020 | 05:00 PM
  #61
Section179's Avatar
Section179
Originally Posted by Brian Exline
Please report back with how it works. I hate having to keep my phone plugged in and charging all the time just to use CarPlay.
I’ve been seeing ads for that everywhere. The google advertising gods clearly have my number.
Yes, REPORT BACK HOW IT WORKS WITH YOUR FORD!
Old Feb 22, 2020 | 05:38 PM
  #62
cbrxxrider's Avatar
cbrxxrider
I now have wireless CarPlay!!!
It took 25 days to arrive. The adapter is small and powers up nicely. Setup is a little strange but easy enough. After connecting the phone to the adapter via Bluetooth you then scan the QR code to open safari to the address of the adapter. Safari will then send the latest update to the adapter and once that completes CarPlay will work correctly.
if you don’t do the update your radio will only show connecting and the screen will never go further.
Old Feb 22, 2020 | 06:22 PM
  #63
Chimpo's Avatar
Chimpo
Does that allow carplay over BT?
Old Feb 22, 2020 | 06:30 PM
  #64
cbrxxrider's Avatar
cbrxxrider
it is actually over WiFi. BT is only used to create the initial connection to the adapter.
Old Feb 22, 2020 | 06:46 PM
  #65
Chimpo's Avatar
Chimpo
Is there a version for Android phones?
Old Feb 22, 2020 | 08:19 PM
  #66
cbrxxrider's Avatar
cbrxxrider
I know this particular model is only listed for Apple. So android auto requires a cable as well? I thought it was supposed to use Bluetooth.
Old Feb 22, 2020 | 09:16 PM
  #67
Chimpo's Avatar
Chimpo
The Sync3 in my 2019 requires a cable to use Android Auto. Sync is running v3.0
Old Feb 24, 2020 | 07:54 PM
  #68
powersrp's Avatar
powersrp
I agree 100%,👎 Your in that seat to drive, let the passengers play with the toys.
Old Feb 24, 2020 | 08:01 PM
  #69
hdzrt1SD250's Avatar
hdzrt1SD250
looking to install USB ports along with builtright mount in top center dash, questions is do i just extend the USB ports that are in the front of the center counsel under the sliding door? or can i add new ones? I use android auto and need to be plugged in.
Thanks for any help
Old Feb 24, 2020 | 08:18 PM
  #70
Section179's Avatar
Section179
Aren’t there some kids on your lawn you need to go yell at? The purpose of a cellphone mount is not to create a distraction. In many places they are required by law to take calls.
Thanks for any help
you will need to use the ports from the center compartment. My approach to this with my mount on the left was to remove the ports, reattach them behind the console, run a usb cable from there, and put a small plastic cover out of the now empty hole.
Old Feb 24, 2020 | 09:28 PM
  #71
hdzrt1SD250
so is it possible to just leave 1 of the 2 ports in center compartment and disconnect the other 1 and extend wire to new added port up top center dash? or leave both (so no need to plug hole) and purchase 2 new and extend wire from center compartment to top center of dash?
Thanks for your help
Old Feb 24, 2020 | 09:42 PM
  #72
Section179's Avatar
Section179
The 2 USB ports are in a single module that follows a pigtail back to the APIM. The Sync system does not support USB hubs, so as far as I can tell (or anyone else I’ve seen comment on the forum) you are stuck with the MAX 2 usb ports.
Since the 2 USB ports are on a single module, you’d have to get creative with some USB extensions to extend them.
You’d be looking at two of these, and making an infill plate for the hole left behind when you remove the bigger module.
Amazon Amazon
Old Feb 24, 2020 | 10:13 PM
  #73
hdzrt1SD250
OK that looks good, i will try the ones in your link. Thanks a lot
Old Feb 25, 2020 | 10:35 AM
  #74
Tunaahelper's Avatar
Tunaahelper
I'll do a write up when I get around to doing it, but till then I was thinking of installing a wireless charging pad under the center console sliding cover or under the armrest. I purchased a couple wireless pads to take apart and it's not much more than a thin copper coil less than 1mm thick. With some silicon or possibly tape, you could install one nearly anywhere that is flat.
Old Feb 25, 2020 | 12:29 PM
  #75
Chimpo's Avatar
Chimpo
Seems like I've seen them for sale online as just the coil and plug. They are for projects like you suggest.
