Forescan and fixing the 34 gallon tank issue with miles LEFT TILL EMPTY
Okay now that Im familiar with the forescan this week i will be altering the fuel tank size on my 34 gallon fuel tank because when my gauge says ZERO miles i still have 5-6 gallons in the tank.
2017 6.2 liter Crew Cab 4x4
I will be going in small steps though. Adjustment will be to make it a 37 gallon tank in FORESCAN by entering LINE 45 in the Forescan Codes spreadsheet to the HEX value of 579.
Basically 37 gallons converts to 140.06 US liters . Round it down to 140.1 liters. This converted to HEX value is 579.
(You can do this conversion by a decimal to HEX converter on google which would be 1401 (decimal value) to 579 HEX)
I will be carrying a 5 gallon gas can this week during work just in case the miles left is wrong and will drive until it says about 10 miles left and see how many gallons i can fit into the tank after this new value is used in FORESCAN on an empty tank.
I'm not sure this qualifies as an issue.. to me this is a very important feature!
More info: https://www.ford-trucks.com/forums/1...l#post18288007
HTH,
Jim / crewzer
I bet if you run it dry you will only get 120 litres in it. My 2005 was listed at 119.6 litre total capacity. I had one occasion where it died towing rolling into a pump and it literally took 119 liters. (diesel mind you) If you review your manual for your truck, I highly doubt its a 140 litre tank, its a 120 in your manual. Look up the hex code and start with that. Or, even, leave 4 liters in reserve to empty, use a hex code for 116 liters would be safer.
My 48 gallon, 181 liter tank is also accurate on my 2017 diesel. Literally almost ran dry, got 180 liters in it. Serious pucker factor towing the RV and whole family on a long trip. (I cross three provinces)
