Leveling kits
Old May 1, 2024 | 02:37 AM
Hwkns's Avatar
Hwkns
Leveling kits
I'm not a big fan of lifted trucks. I'm going to put 35's on the new Limited, but I'm not 100% sure I like the amount of lift the Tremor. That said, I don't like the nose-down stance at all.
Who makes a good leveling kit, and how much does the front need lifted? I've see 1-1/2". I've seen 2-1/2", and even 3".
TIA
Old May 1, 2024 | 05:28 AM
Quad Racer's Avatar
Quad Racer
There are many options for this. Your best bet would be to run some searches here on the topic for the most info.
Old May 1, 2024 | 06:08 AM
Rwhjr's Avatar
Rwhjr
I did 17-19 f350 rear blocks and a 2.5 front level and I like it
truck also has rear airlift so regardless of the load it’s carrying it sits great
Old May 1, 2024 | 07:06 AM
WXboy's Avatar
WXboy
The 17-19 sat higher than the 20+ trucks, and even still I found that a 1.5" level in the front was perfect. I have no idea why guys are doing 2.5 and 3.0 kits. That's going to give you the "Carolina Squat". You need *some* nose down stance so that when you haul and tow your headlights aren't shining into space.
Here's my $20 eBay 1.5" level kit which installed easily and has worked flawlessly for the last 9 months towing, hauling, on and off road.
Old May 1, 2024 | 01:32 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I like those wheels. They look great on that Blue Jeans color!
Old May 1, 2024 | 01:53 PM
Rwhjr's Avatar
Rwhjr
I have a 2.5 kit on mine and haven’t had any such issues. In fact I actually had those issues when it was completely stock with just a 16k trailer on the back. But not anymore.
I simply put airlift in the rear of mine with their automatic compressor kit.
let’s meetup and load up a few thousand pounds or more of tongue weight…..in your truck and mine….and see who’s squats more and who’s headlights are pointing into outer space more.
Old May 1, 2024 | 03:19 PM
Hwkns's Avatar
Hwkns
What wheels and tires do you have on that? Those look good. I've been considering Modern wheels and snow rated BFG KO2's or Toyo AT3's; we travel the mountain passes in the winter. I want something that's rated at 3500+ pounds to so it's at least as much as the truck's 12,200 GVWR.
Old May 1, 2024 | 05:24 PM
FishOnOne's Avatar
FishOnOne
Right on queue..
Old May 1, 2024 | 05:25 PM
FishOnOne's Avatar
FishOnOne
Good looking setup..
Old May 1, 2024 | 05:53 PM
Phillbo's Avatar
Phillbo
Originally Posted by FishOnOne
Right on queue..
I take it he's a know it all......
Old May 1, 2024 | 06:27 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
His signature says "Vision Ojos wheels"
Old May 1, 2024 | 06:56 PM
honda250xtitan's Avatar
honda250xtitan
sits nice! the carli springs i run add 1" of lift to the rear. almost like they know a 2.5" front coil spring is too much height lolol. I've asked them to build a 1.5" spring but they said they cant change the ride quality because its too short of a spring
Old May 1, 2024 | 08:51 PM
Quad Racer's Avatar
Quad Racer
TIA
one thing to keep in mind is if it’s a later build 2024 with the non selectable passenger hub you’ll need to get that remedied before you level your truck. Leveling with that dummy hub causes potential issues. To the point where FoMoCo sent out a TSB on it.
Old May 1, 2024 | 11:28 PM
Hwkns's Avatar
Hwkns
Is there a TSB number I can reference on that?
Old May 2, 2024 | 12:08 AM
4wd6.7L's Avatar
4wd6.7L
First post has some info on it.
https://www.ford-trucks.com/forums/1...noise-ssm.html
