Morimoto SB LED Headlights
Old Apr 5, 2019 | 07:37 PM
  #316
tuff4rd's Avatar
tuff4rd
Originally Posted by atkinjr
If you had stock halogens make sure you turn off day light running lights in your cluster settings. it will flash if you dont
Did that correct the issue you were having?
Old Apr 5, 2019 | 07:41 PM
  #317
moynihan1129's Avatar
moynihan1129
I am on the fence between these, the anzos and waiting for recon. Honestly a little disappointed to hear of all the issues with only the first few shipments for the price. I don't know how I can pass up this deal I found on eBay though!
Old Apr 5, 2019 | 08:34 PM
  #318
atkinjr's Avatar
atkinjr
No still shakes on bumpy terrain. Did you fix your lights?
Old Apr 5, 2019 | 10:47 PM
  #319
TxRandell250's Avatar
TxRandell250
I installed mine on Thursday and noticed my passenger light would shake when closing the doors. Took for a test drive and rough roads made it jiggle also. Today I tore it all down again and and adjusted aim down and retightened all bolts. Still shakes. Not very happy about it also
Old Apr 5, 2019 | 10:48 PM
  #320
tuff4rd's Avatar
tuff4rd
thankfully me adjusting the beams eliminated the vibration. You may want to try adjusting it all the way down till it stops then adjusted to its normal position, maybe something pop loose and this might get it back in its groove. Just a thought
Old Apr 5, 2019 | 10:57 PM
  #321
TxRandell250
Can these lights be adjusted without tearing everything down?
I saw in the instructions were supposed to be able to but what I see and what’s in the picture is different
Old Apr 5, 2019 | 10:59 PM
  #322
Alaskan_Warbird's Avatar
Alaskan_Warbird
Sorry to hear that, guys. As a possible future buyer, I'll be watching this issue closely to see what the cause is and to see how you're taken care of. For that kinda $, I wouldn't expect that kind of QC issue.
Old Apr 5, 2019 | 11:17 PM
  #323
tuff4rd's Avatar
tuff4rd
You're supposed to adjust them with them mounted and installed. I was able to adjust both of mine with an extension and a 8mm socket, I didn't use a ratchet but was fairly easy to adjusted by hand. I only adjusted the up-and-down adjustment which are the top adjustments on the outside corners of the lamps.
Old Apr 5, 2019 | 11:23 PM
  #324
TxRandell250
I’ll look at them again tomorrow but I didn’t see a 8mm adjustment on top
Old Apr 5, 2019 | 11:30 PM
  #325
tuff4rd's Avatar
tuff4rd
sorry, it's not on the very top. The up down adjustment is the one towards the top on the back side kind of at the corner of the lamp towards the fender.
Old Apr 5, 2019 | 11:48 PM
  #326
TxRandell250
Oh ok. Then I felt where the driver side one was. The passenger side I couldn’t see or feel for it
Old Apr 5, 2019 | 11:54 PM
  #327
atkinjr's Avatar
atkinjr
The only one that can't be reached once mounted is the left to right on driver side. On a side note, they have a cool factor, but not happy with final product and service for the price.
Old Apr 5, 2019 | 11:59 PM
  #328
TxRandell250
Yeah they are cool but build quality is lacking at the price range. Hopefully return policy is good cause I’m thinking I should of just did the oem led
Old Apr 6, 2019 | 12:05 AM
  #329
tuff4rd's Avatar
tuff4rd
do you have diesel or gas? If it's gas you need to remove that little air intake to get access to the adjustment bolts. I'm not sure on a diesel though
Old Apr 6, 2019 | 12:10 AM
  #330
TxRandell250
Yeah it’s a diesel
