The led lines on the side of the light match the led lines on the factory mirrors well.
Congrats man! Looks awesome. Do you have a good picture of the side markers with the lights off? I'm supposing you haven't had a chance to see how the headlights perform at night
I'll have to get a photo tomorrow in the day light. Here is an attempt at a photo.
Here is what I did to plug into fuse 35. It's not pretty but it's far more effective than what they give you. Little connector on the end of the red wire, red wire through grommet, grommet through fuse box lid, and inline fuse. Works perfect.
I thought I read somewhere that someone couldn’t find any way to adjust the aim of these lights. Can anyone who just installed these lights report on whether or not the aim can be adjusted? To me, this is important, especially having a 2 1/2 inch level. When I first towed with my toy haulerand new LED bulbs I got flashes constantly before I aimed them lower. I can’t imagine these not having some kind of aiming procedure because not all trucks sit the same as we all know.
They're easily aimed. They can be aimed up and down and left and right. The driver's side is easily accessed and the passenger side requires you to remove a small air scoop. Both adjustments screws are on the back of the light.
Awesome man, thank you very much for the reply. I couldn’t imagine them not being adjustable! Now I can confidently unpack them out of the box and check them out. I’ll have to set aside more time than usual because I’ll have to pull my Fab Fours bumper with pre runner bar forward and downward on the mounting brackets to get the factory lights out and get the Morimoto’s installed. Right now the pre runner bar only gives me 1/4 inch clearance at the bottom of the light assembly. Bummer
Did you pull yours out of their box yet? If so what are your initial impression of them?
Yes, I pulled one out and my impression is that they are the same as OEM quality. Definitely not a cheapo knockoff. The tabs where in place and they where sealed well. So far I’m impressed.
