Just got them delivered.... Box was pretty beat up... After inspection, were good to go. No problems, mid install now.
Ordered from LightWerkz in December.
Did you swap out your sport package halogens for the LED's? Man I wish they offered OEM LED's in the sport package blacked out style. You thinking of selling your halogens or hanging onto them?
I'd say about 2 hrs, with greasing all connections, taking the grill off. Realizing I wired them wrong... Then fixing it. I also ran some LEDs behind the grill so it took some time to wire those up to an uplifter wire. Ops checking....and then admire!
I do wish the sport package came with LEDs, but in all honesty...I bought this truck with the full intention of getting these!!!! Just had to be patient!!!
I will be letting the sports one's go here shortly. To help off set the cost of these!
What he said.....the lights look a little intimidating at first with all the connections.... But with colored directions with pictures. It was pretty easy and straight forward.
Do you have to tap into fuse 35 when adding to either Halogen or LED OEM? Has anyone found a better way to tap in rather than going in from the top of the lid?
I bought my Sport because of these lights too😂 Did they fix the fuse tap or do you still have to rig it up?
Shoot me a DM when you do if you don't mind, I'd be interested in seeing what you want for them. Thanks!
currenlty at work till tomm. Ill snap a picture of what I did. but the fuse tap itself fits fine, nice and snug. But, basically I ran the wire to the side of the fuse box towards the + - battery connections. and used a dremel and grinded a small wire size groove or channel and then sealed with sealent. cover closes fine.
If you contact TRS they are shipping a new fuse tap free. Not sure if later shipments include this. Mine did not. Still requires trimming to close lid.
Ok guys I installed mine today and took less that 2 hours. I'm sharing my pics since I hadn't seen any white or light colored trucks posted yet. Going to get smoked black clearance lights to replace the amber ones to round out the look.
