Babe the Blue Ox is SICK!
  #316
Old 09-05-2018, 02:09 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,191 Likes on 817 Posts
That sucks Glenn, but I too had a problem with an injector that Jimm rebuilt, he said it was good but when installed on the truck there was a miss on low RPM, Jimm explain something internally worn that wont show in a flow bench or something like that maybe he can shime in annd explain.
  #317
Old 09-05-2018, 05:57 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Awww, let me think Eric............NO, lol. That's really good boost with a bad hole etc. Are you sure you didn't Y that boost gauge line and blew into it to help the numbers
Adam, I hear what your saying and anything is possible. I'll pretend I'm in Vegas and I'm going to bet the odds that it was a good injector. Jim is a out standing guy and I trust what he says and does. Well, we are all human and anything is possible though.
  #318
Old 09-05-2018, 06:08 PM
z31freakify
It's more likely the mechanic messesed up when installing the pushrods.
  #319
Old 09-05-2018, 06:34 PM
oldbird1965
Agreed 100%!
  #320
Old 09-06-2018, 05:28 PM
Hit Man X's Avatar
Hit Man X
Hit Man X is offline
Received 1,193 Likes on 972 Posts
Thumbs up
LOL no no. I did about 17psi on the stock tune, saw 1psi by ~1200rpm (fourth gear pulls). Not bad I think, I really like this 1.0 turbine housing and no uppipe leaks! Truck acted a bit odd at that much boost on tow tune, I may get one of those bleed off things and see if numbers improve and/or power.
Trying the 'street' tune is pointless with my clapped out HPOP. Just belched black smoke. I think I would still rather retint it and install sound deading on the floor before messing with a fresh HPOP.
  #321
Old 09-06-2018, 07:54 PM
oldbird1965
  #322
Old 09-07-2018, 09:10 AM
867.309's Avatar
867.309
867.309 is offline
in a couple weeks I’ll be in that area again. I might stop in and try in my most diplomatic way possible to tell him what he probably doesn’t know. If he doesn’t want to hear it I’ll do a write up on his website.
I'd wait until the warranty is up on that engine. Just in case you need them again.
  #323
Old 09-07-2018, 05:56 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Exactly what I was thinking. LMC has some nice drop in stuff for the non crew cab trucks, I may put down that Dynasplat first. LMC's stuff. Then some fresh carpet with that rubber on the back. I bet the difference with that alone would be day and night. Doors will be done when I reinstall tow mirrors.
  #324
Old 09-07-2018, 06:42 PM
oldbird1965
I'll be back and forth from Michigan to Arizona with a limited time in his area. That's why if I say anything I want to walk on egg shells, lol.
I did top, bottom, back, inside the doors and pulled the dash to do behind it. I expected more then I received. Its hard to keep a 7.3 quiet!!
redman84
04-16-2010 07:01 PM
turtletalk
63
12-27-2009 02:58 AM
Ratkat
02-20-2009 06:45 AM
smoky_diesel
46
11-06-2007 08:12 PM
bigbadwolfe
13
06-25-2007 07:00 PM
Quick Reply: Babe the Blue Ox is SICK!
