as you can see by the title this is what i am trying i went to the junk yars and got another valve cover with the ccv and am going to put it on the pass side so both heads can be vented what do you guys think of this good/bad do dont do let me know your thoughts on this thanks
It's a good idea. You will like the results. When you vent both sides to atmosphere there is almost none of that annoying blue smoke drifting out from under the truck.....probably because the rings are sealing better.
2 of them work good on gassers, should be OK on diesels too, I've done 3 CCV mods (single) on our diesels. I haven't noticed any difference except under the hood & the IC boots stay clean. The gassers I've done showed an extra 10-20 HP on the dyno.
well here is my response that I tried to send earlier this morning but didn't go through
An easier way would be to get the extented oil filler neck from a superduty then just drill a hole and put a threaded barb fitting in the side to hook your hose to. The valve covers are double walled and it might be kind of hard to work with to get the holes right.
Superb idea tj. That seems like it would be the easiest. I may try that and T it into my other hose that runs to the back. Hmmm I wonder if the wife would miss hers?
as long as she doesn't change her own oil she will never know!
that extension threads right into the valve cover and they are all the same. 94.5-03 7.3 and the 6.0 even (got one on my truck after the IC install). then the cap threads onto the extension. I even put the superduty extension on my 95 with no IC just to make it easier to get to after the coolant filter was installed.
Do you have the part number? and also for the dipstick? (I want to know because Im thinking to put an IC in my PSD)
