What part do I need?
Old Apr 16, 2010 | 01:05 PM
redman84's Avatar
redman84
So I got my truck running. Turns out that the POS CPS by BWD won't even let it start. Got one from international and had her runnin shortly. I did notice a small bit of smoke coming out from the engine though. On the driver's side valve cover there is another small cover that has a hose running to the intake tube. The smoke is seeping out around that small cover. What is this called? I expect I need a new gasket for it huh? I just need to know what to ask for. I'm almost there thanks to yall. A little more help and I may have it whipped.
Old Apr 16, 2010 | 01:27 PM
redman84's Avatar
redman84
Also could this leak cause a low rpm rough idle or minor power loss?
Old Apr 16, 2010 | 02:00 PM
JamesHajek's Avatar
JamesHajek
I believe you are talking about your ccv which is your crankcase vent. It vents the oil vapors back into your intake. I think there are two orings on the underside of it but am not 100% so someone else will have to confirm that. And no i dont think that will cause a rough idle or minor power loss. This might also be a good time for a ccv mod if you want which basically means you just vent those vapors through a hose under the truck towards the rear. Do a search on here for ccv mod and you will come up with alot of writeups on that.
Old Apr 16, 2010 | 03:03 PM
redman84's Avatar
redman84
thanks so much bud. You've been a huge help. Slowly I am getting my rig fixed back up.
Old Apr 16, 2010 | 03:08 PM
cowmilker08's Avatar
cowmilker08
Yes, there is two o-rings.
Old Apr 16, 2010 | 03:09 PM
JamesHajek's Avatar
JamesHajek
No problem, Im just glad I can help out.
Old Apr 16, 2010 | 07:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
X2 on that, and in the OEM style they are not round, and IIRC they are triangular shaped, and also there are another 2 o-rings in the upper part with the screws.
I repleaced all of them with a regular (rounded) o-ring and not problem at all.
I would investigate something about Blow bye like this links
https://www.ford-trucks.com/forums/8...questions.html
https://www.ford-trucks.com/forums/7...-dipstick.html
Mt. View
1978 - 1996 Big Bronco
Feb 20, 2014 06:35 AM
Zwalters
Oct 2, 2013 08:09 PM
redlinecoatings
6.4L Power Stroke Diesel
Feb 18, 2012 05:20 PM
musstag
Aug 16, 2010 05:42 AM
dallas32
Jan 9, 2004 12:18 PM
