I received my soundproofing material from Quad Dynamics LLC, Aaron recommended it to me. After doing some research I went ahead with them. The guy says that Ford buys some from them. My nephew came over and had the dash out in about an hour. He worked so fast that I don't know if I followed all of it or not. After he left I started to wonder how to get behind the vents because I want to sound proof it all. Found two bolts but there has to be more.
While I was waiting on him to come I did the roof. The dynamat you see on the floor I did last year but it was incomplete. It ended about where the back seat starts, I plan to do it all including the back wall, doors and under the hood.
Oh, I forgot. My nephew recommended that I shim up the cab mounts about 3/8". He said that it doesn't sound like much that it will give my up pipes a little more clearance and actually make them quieter. He pointed out that the cab lines are slightly lower then the bed lines and they would match up. He was saying that the mounts in the core support are studs and the body has to be lifted over them for the shims to be put in there. He said to hold the bottom of the bolt while I loosen the top. Sort of lost me there because looking up from the bottom it just looks like a bolt. Do you guys think this work would be worth it?
I wish I would have done my behind the dash when I had it all apart painting it. I did not take the dash out. I did sound proof the floor and the doors. My wife don't like the noise either Glenn.
I have been thinking of changing the mounts on my I have been told that they settle over the years. This is what I was looking at Body Frame Mount Bushings Kit (2)
Thanks Aaron for the tip, that's pretty good stuff. I also lied, I started on the roof yesterday after I couldn't get going on the compression check. Its time consuming putting it on, lots of cutting.
How much did applying the sound deadening mat to the seemingly little bit of surface area behind the dash really help? I've removed a dash in a Gran Marquis just enough to replace the heater core. Removing the whole thing to get to the firewall seems daunting.
