Babe the Blue Ox is SICK! - Ford Truck Enthusiasts Forums
Old 07-06-2018, 04:41 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
On the freeway today the OX started shaking badly with white smoke pouring out. I have the SD mod valve covers and when I unplug one at a time on each side it dies. At high idle it will stay running but struggles. I was about 4 miles from a Walmart so with my foot on the floor make it there. My side step was covered with oil on the drivers side, about where the CCV mod tube ends. Called guru Aaron and he suggested I run a cylinder contribution test and I came up with 0284, cyl 8 contribution/balance fault. The motor and weather is to hot to work on it tonight. In the morning I'll pull drivers side valve cover and see if #8 injector got unplugged. Any suggestions?
Edit: Walmart is only for a place to park this 5th wheel. Glad I have generators!!
Old 07-06-2018, 04:59 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
z31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to behold
That sucks Glenn, any way you could of gotten a bad batch of fuel?
Old 07-06-2018, 05:42 PM
tshrager's Avatar
tshrager
tshrager is offline
tshrager has a very good reputation on FTE.tshrager has a very good reputation on FTE.tshrager has a very good reputation on FTE.
Dang it! Which state are you in? Start with the easy stuff first and go from there.
oldbird1965
I guess that's possible but what would cause all the oil coming out of my CCV hose?
Old 07-06-2018, 08:02 PM
nateairman's Avatar
nateairman
nateairman is online now
nateairman is gaining momentum as a positive member of FTE.
Maybe you dropped the tip on 8 and holed the piston which is blowing all that oil out the exhaust and ccv.
Old 07-06-2018, 08:21 PM
oldbird1965
I'm in Nebraska and in the morning I'll see what I can see pulling drivers valve cover.
Could be!
Old 07-06-2018, 08:35 PM
nateairman's Avatar
nateairman
I was hoping you were gonna say Vancouver,BC
Old 07-06-2018, 08:38 PM
97-psd's Avatar
97-psd
97-psd is online now
97-psd has a good reputation on FTE.97-psd has a good reputation on FTE.
Did it happen all of a sudden or get worse as the day went on?
Old 07-06-2018, 09:18 PM
oldbird1965
Fourteen years ago I could have said that! Beautiful place we went thru on our way to Alaska.
Ben, it just happened all of a sudden. Running great then it started vibrating and missing.
Old 07-06-2018, 09:45 PM
nateairman's Avatar
nateairman
Do you think you burnt the Beans HFHV IDM?
Old 07-07-2018, 05:36 AM
logcruiser
logcruiser is offline
logcruiser is starting off with a positive reputation.
You could ohm out the injectors from the IDM connector before going into the valve cover. There is a PDF file that is great for this. I can't find the link of coarse but someone may be able to link it.
Old 07-07-2018, 06:24 AM
867.309
867.309 is offline
867.309 is starting off with a positive reputation.
Is it adjusting for altitude? Are you climbing to altitude for the first time in a while?
Old 07-07-2018, 08:13 AM
farmert
farmert is online now
farmert has a very good reputation on FTE.farmert has a very good reputation on FTE.farmert has a very good reputation on FTE.
He is probably loosing altitude, Nebraska is pretty flat.
Old 07-07-2018, 08:44 AM
867.309
867.309 is offline
Seems flat but it is deceptive. 5000ft at the west end and maybe 800ft at the east end. Long slow climb. New Mexico and/or west Texas is like that too.
I would expect a false altitude reading to affect things across the board. Maybe one injector could hit its limit if it was struggling to keep up. Worth checking if you can scan it.
Old 07-07-2018, 10:29 AM
BBslider001's Avatar
BBslider001
BBslider001 is online now
BBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud ofBBslider001 has much to be proud of
What part of Nebraska Glenn? I'm in the NW corner. Holler if you need anything. I have a shop with lots of tools. Just ask Jarrett...LOL
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
