CCV Mod
Old Feb 20, 2009 | 12:00 AM
Ratkat's Avatar
Ratkat
CCV Mod
Have just done the ccv mod and have found at idle I get a bit of smoke not puffing just a constant stream sometimes it looks worse than others like if there is a cars headlights shining on it. Is this normal?
It has been very humid around here
Has anyone ever run the vent tube into the exauhst pipe via a one way valve?
Old Feb 20, 2009 | 12:18 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I have been told that they tested running it into the exhaust and it created to much back pressure. It just looks worse at night and in high humidity. it is more steam than smoke. What oil you use also changes it too. I just ran it underneath so the only time you can see it is if you look way under the truck.
Old Feb 20, 2009 | 03:52 AM
ernesteugene's Avatar
ernesteugene
See posts #52 & 59 here...
CCV Mod, Done!!
https://www.ford-trucks.com/forums/7...ml#post7122368
...for a complete explanation of why running your CCV hose to your exhaust is a VERY bad idea!
See post # 12 here for the best way to do a CCV mod...
Oily CCV mod hose
https://www.ford-trucks.com/forums/8...-mod-hose.html
Some brands of oil steam and smell more than others. I use Rotella and it seems to be one of the worst offenders. It sounds to me like your oil fumes are about typical.
Old Feb 20, 2009 | 05:25 AM
Ratkat's Avatar
Ratkat
Got it Thanks.
Old Feb 20, 2009 | 06:45 AM
beanhead6D5's Avatar
beanhead6D5
Here is the set up I did it does steam but not to bad.Welcome to guzzle's CCV mod web page.the steam is norm.
I add a drain in the bottom to drain out the water that will accumulate for the steam.It works good for me .
