Babe the Blue Ox is SICK!
#242
The early model has that long plate if I remember right. But like the later block I used in my truck when I built it has a smaller 2 hole plate that will unbolt and only holds 2 lifters in
Thats the only way that part would come out. But I haven't looked at the lifter itself in awhile
#243
Thanks everybody for sure. Went 400 miles today, I ran it hard at times but not to hard. Tried to vary the rpm's as much as possible to help break in. I was impressed with the boost and egt's. I could just flick the pedal and boost would just jump up there to 40psi. I had to run the ox before WOT to about 90mph before I saw 38. I contribute that to gaskets on the exhaust manifold, tight engine and the sxe turbo. The egt's were the best I've ever seen them but of course could still get them up there. I will not let them over 1200° ever again if I can help it.
Negatives, I know its just breaking in but I think the old motor had a little more power. I'm sure with time it will get better. The oil pressure wasn't as high as before but I have no idea what oil they put in after they dumped the break in oil. He said to run dino until 10K. I can't wait to get it changed as soon as possible. The last negative is when I get after it, it seems like I feel a vibration and slight miss. If I back off a second it goes away the power comes on??
#245
[QUOTE=oldbird1965;18106531
<snip>...
Nate, if Jasper see's the ARP's, springs and push rods they will void the warranty. If I blow it up near this shop, the shop said they would take care of it without telling Jasper. Will another Jasper shop do that? I doubt it! I've been delayed three weeks and don't know what else to do except to go for it.
Thanks to all of you for your help and concern. As always, this forum is the BEST!
If anybody wants to look at Jim's pictures I'll post them.[/QUOTE]
If you lose a headgasket or something related to your parts getting installed they might be able to claim their warranty is void, but I don’t think they could or should void the entire warranty. But then I’m not a lawyer. Hopefully it’s all a moot point and you won’t need any stinking warranty.
<snip>...
#246
Thanks, hope so too!
Thanks a lot, hope it keeps going.
Yeah, hopefully that is a moot point.
#247
Thats just upsetting Glenn, but glad your bad on the road. I have a feeling that guy took you for a long ride on his story, and like Jim said its imposible to remove a lifter with out lifting the head on the older style 7.3 powerstroke on the later ones theres a slight chance that it can be done without removing tge head but the head gasket has to be destroyed in order to reach that center hold down bolt and plate holding the lifters and even at that its hard to align the lifter to the plate even when the heads off, cant imagine doing it with thehead in place.
#248
Made it another 350 miles and it ran good. I'm so impressed with boost and egt's, something I have never had but read about and was jealous! Got the holy crap scared out of me in Chicago where there was a traffic jam. I've gone thru that place 100 times and I think only once made it thru without a traffic jam. Saw the brakes lights start coming on and I hit the brakes and felt the 5er come onto me. Looked down and my brake controller said I wasn't hooked up to a trailer! I slammed on the brakes and the poor OX had to do all the braking until I got stopped, barely! It was time to get new shorts on. The cord got wrapped around some stuff and pulled loose. I wrapped a bungee cord around it so it wouldn't happen again. That's all I would have needed, a smashed new motor! The thrills of traveling, lol. Horrible, horrible roads!!! Its a wonder anything is in one piece in the 5er.
#249
Glenn, what is it about the boost and EGTs that you're impressed with? How high the boost and low the EGTs? And why are they so good compared to your older equipment?
Great to hear your only problems are a disattached brake cord, horrible traffic and potholes galore. Back to normal things again. The glory of RVing!
#250
#251
#253
I'm glad it's running good Glenn! Chicago is a pain. Took me 3 hours to go 7 miles on interstate once. Never again. Ok. Here's to verify no way to change the lifter without pulling the head. In the one head I checked there was only one pushrod hole the lifter even fit through. Besides that you'd have to get in there to get the bolt out that holds the lifter plate in place. Then get the plate out or at least out of the way. Then IF you somehow got that, you have to get the lifter out. Then you have to get a new lifter in, have it turned the right way to fit the plate back on, and reassemble. Not gonna happen.
#254
#255
I would love to Bryon but I will be back thru there in Sep and if I'm having any problems I want to stop there. I also told them I wanted all the old turbo parts and the exhaust housing is missing. James Barder told me that I could get a reducer boot and maybe gain a little more, if I heard him right and understood him correctly.
