truck bogging down
Old Mar 6, 2018 | 06:16 PM
Derick Stephens's Avatar
Derick Stephens
truck bogging down
I have a 2005 f350 6.0 flatbed that we use for a shop truck. Lately it will be driving perfectly fine, then lose power. No matter what I do to the pedal, no power, then all of the sudden it takes off and runs fine for awhile. In the search for the solution for this problem, we have pulled the tanks and checked the strainers, replaced the fuel pump and both filters as well as a local shop replaced the egr valve. Still doesn't seem to help. Last weekend we noticed the gauge light started blinking and the transmission gauge read zero. Checked it and the tranny was low. No leaks anywhere. Filled it up and again, a week later it shows low again. Is there any way these two problems could be one in the same. Again, no leaks anywhere. Any suggestions would be appreciated.
Old Mar 6, 2018 | 08:13 PM
bismic's Avatar
bismic
What transmission gauge are you referring to (reading 0)?
Do you have access to a good code reader? If not, the Forscan app and a bluetooth ELM327 device is a pretty good start at reading most codes.
Old Mar 6, 2018 | 10:21 PM
Derick Stephens
The gauge i am talking about is the upper right dash gauge. When it goes to zero a gauge light comes on and a flashing tow light.
Old Mar 6, 2018 | 10:22 PM
Derick Stephens
I do have access to a good reader.
Old Mar 7, 2018 | 07:21 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Dead TFT sensor inside the pan. It will cause shifting issues and make the truck seems like it lacks power.
How to change:
https://www.ford-trucks.com/forums/1...l#post16412474
Are you checking fluid level with the truck running? If it was low and you filled it to the dipstick with the engine off, you probably under-filled it and when it started running it pushed fluid form the pan out and it's reading low again.
Old Mar 7, 2018 | 12:12 PM
Derick Stephens
Don't know if this helps or not. We were just running across town to pick up some parts. Ran great going, then on the way back, it started loading up and would barely idle. No response to acceleration. Pulled over for a few minutes. After several tries, it started right up and ran great all the way back. Just thought that I would throw this in. Thanks
Old Mar 7, 2018 | 12:18 PM
texastech_diesel
Token Redneck
This is a low-power cause not related to transmissions:
https://www.ford-trucks.com/forums/8...procedure.html
Old Mar 12, 2018 | 04:48 PM
Derick Stephens
still stuttering
I checked the ficm. All is good. 49.4V. pulled egr back out after it having been replaced. It was pretty gunked up and a little wet. The mass airlow sensor was also dirty. Cleaned it all and put it back in. First day, ran with one small stutter. The next day more, and today, even worse. Not sure where to go from here.
Old Mar 12, 2018 | 04:55 PM
bismic's Avatar
bismic
Did you even check the transmission temp (actual TFT reading w/ a scan tool) as suggested in post #5?
Any codes?
Chester_field
Mar 3, 2019 07:48 PM
Chester_field
Mar 3, 2019 07:29 PM
WatsonR
Dec 17, 2015 11:26 PM
01raptor
Aug 5, 2011 07:55 AM
whjco
Nov 5, 2008 09:44 AM
