Forum update?
Old Apr 14, 2019 | 03:38 PM
  #211
Yahiko's Avatar
Yahiko
Paul I have seen the extra spacing too.
What OS are you using?
I did find a good workaround. When you copy/cut and your ready to past click the Source button.
That seems to take what ever is doing it out of the loop for me. I hope that works for you also.
Old Apr 14, 2019 | 10:52 PM
  #212
1TonBasecamp's Avatar
1TonBasecamp
Using Win10 with the Firefox browser.
I'll try the source button next time. Seems like a funny extra step (don't have any idea what the source button does, but I've heard you guys talking about it in the past) but willing to give it a try since re-formatting each post each time I make the mistake of cutting and pasting is even more of a hassle!
Now I wonder what it will take to get the cursor to follow normal protocols...
Thanks
Paul
Old Apr 14, 2019 | 11:42 PM
  #213
Yahiko's Avatar
Yahiko
What the source button dose is show you the HTML commands on the page.
Say you change the color of something. Try that and then hit the source button.
It will show you the HTML coding on the page. Being able to see the coding when
your trying to format something can be very handy. Also in addition to showing
you the coding it also turns off the inline display of commands. So the item you
changed the color on will not longer show that color and it will show the command
or that color.
Old Apr 19, 2019 | 12:16 PM
  #214
FORD COASTIE's Avatar
FORD COASTIE
Veteran: Coast Guard
For a while now, I have been getting a “Check Out What’s New” pop up with a dark screen when I click on the first thread after l log on. After I acknowledge it, the pop up stays off for the entire time I stay logged into that particular session. This morning, I started getting the same pop up every single time I click on a different thread. Is there anyway to stop this from happening, because it’s pretty aggravating. In case this helps to figure out the issue, I am using an iPad. Thanks.
Old Apr 19, 2019 | 05:03 PM
  #215
Yahiko's Avatar
Yahiko
Check your browser to see if it has the option to block popups.
Old Apr 19, 2019 | 08:37 PM
  #216
FORD COASTIE
I’m running IOS version 12.2, and my pop up blocker has always been turned on, yet I’m still getting this. It’s been going on for about a year now.
Old Apr 19, 2019 | 09:40 PM
  #217
Yahiko's Avatar
Yahiko
Try un-blocking things and restart the browser then block it again.
I think it was about a year ago that Apple updated Safari and hosed a bunch of people.
10.12.6 will be my last update I think.
Old Apr 22, 2019 | 06:18 PM
  #218
IB Jose's Avatar
IB Jose
Internet Brands
Are you using the full desktop view on your cell phone?
Old Apr 23, 2019 | 09:17 PM
  #219
FORD COASTIE
I’m using the full desktop view on my iPad.
Old May 19, 2019 | 09:18 PM
  #220
FORD COASTIE
I am happy to report that after a year, the issue has resolved itself.
Old May 19, 2019 | 10:16 PM
  #221
Yahiko's Avatar
Yahiko
This last update a few weeks ago seemed to have settled some issues.
One that is still there that I have not mentioned is if you use the color picker tool.
Here is an example of the issue I made the color green and it should of stopped
and returned to black at the end of what I had highlighted. The only way to end it with
out changing the color is to use the Source button and type some text after the [ / color ].
Here is the line as it looks when you click on the Source button.
[ color=#00ff7f ]Here is an example of the issue I made the color green and it should of stopped [ /color ]
[color=#00ff7f]and returned to black at the end of what I had highlighted. [ /color ] The only way to end it with
out changing the color is to use the [ i ]Source[ /i ] button and type some text after the [ / color ].
It is nice that is does use the proper formatting and is easy enough to work around. The two
ways to get around it are to use the Source button of edit the color once you have all the text done.
I guess one could also end any color selections with this command [ /color ]
Old May 20, 2019 | 02:27 PM
  #222
IB Jose's Avatar
IB Jose
Internet Brands
Huh. That's a good catch. Thanks.
Old May 20, 2019 | 11:05 PM
  #223
Yahiko's Avatar
Yahiko
I seem to be good at digging up obscure issues.
Old May 22, 2019 | 06:07 AM
  #224
Snowseeker's Avatar
Snowseeker
But the most annoying issue (the black bar) is ignored.
Old May 22, 2019 | 11:56 AM
  #225
IB Jose's Avatar
IB Jose
Internet Brands
Snow, I don't know how to make it any more clear that the black bar is now an integral part of site navigation, and will not go away, and we have no plans to remove it at any point in the future.
