Kids just called, power is out at the house. We have out unvented gas logs running, they can keep everything at 70 degrees, I told them to wait to fire up the generator.
What area is your house located? We got snow and high winds but our power only flickered on the coast.
Fred isn't to sure about this cold white **** on the ground. He is 18 months old today so it is his first encounter with it. Walking around staging his ears and nuts in it.
If the diesel fuel wasn't around/above 40 it won't mix so it won't work worth a ****. Unless you're in negative temps the diesel shouldn't gel.
diesel starts to gel at 32*.. problem with my area here is we usually wont get the temps for the stations to get the wintery mixes.. i didnt just add it to the tank just to add it to the tank.. i threw it in before filling the tank..
We are in western Chatham County in the sticks, when a frog pees on the road the power goes out. We did get 3" last night, roads are slick as snot because there is a nice ice layer on the ground.
Afternoon, NC! No snow here in Henry County, VA, just the other side of the state line. Still cold af, but not as bad today as it has been the last few days.
My tolerance for the cold has apparently gone straight to hell the past few years. I've lived in the south too long
Nah it ain't gelling at 32. Closer to 10-15 when it actually starts to Gel.
We got a dusting here, I just stayed home, got some kind of bad cold/flu crap from work, and after the wreck my dad has last year, decided it wasn't worth it, I've got sick time, I'm using it.
